Question about Apple iMac G5 MA064LL/A Desktop
Apple mac mini/Mistar Midilink
I too can't get my MIDI keyboard - a Yamaha PSR500 - to talk to the Mac using this device. I've tried all 16 channels to no avail. Does it need a driver? The only device the Mac sees is some oriental-sounding name beginning with T. Is this the Mistar Midilink?
  • catxxx Dec 09, 2008
    i have a mac mini and am trying to use GarageBand from iLife to record my music from a yamaha keyboard. I've plugged it all in, but GarageBand doesn't register. I've noticed that MiStar seems to have no website. Does anyone know contact details?
When I first used it I had the same problem. But if you make sure the midilink OUT is connected to your keyboard IN and the IN to the OUT it might well work - mine did! It worked a treat in garageband. I am having problems now when the mac tells me that the usb device i.e. the link is taking too much power and is disconnecting it! oh well...
Posted on Aug 28, 2008
I bought an old Mac Mini Intel Core 2 Duo, 2 GB Hard Drive, OS X Yosemite, with serial # C07CS2TPDD6H. What adapter cord could I use to connect it to an iBox C1752, TFT LCD Monitor?
That Mac has a hdmi port and a mini display port. The monitor has a saga port. So ether a hdmi-svga. Or miniDisplay port-svga.
Any usb keyboard will work. So any Mac keyboard newer than 12 years should be good, and newer pic keyboards will work. Beware of older keyboards that have round plugs. On macs these were ADB ports. On PC's, they used PS2 (ADB, ps2, usb are all different, you want the flat rectangle USB)
U.S. pc keyboards also have two modifier keys wired different than the U.S. Mac keyboards, but this can be adjusted in the system preferences. Can't say for non U.S. KBs. They are the windows/alt keys. Vs Opt/Command keys. That is, if you are soused to using a Mac, the key that is closest to the spacebar (command key) is applied by the second key over rather than the first. Again, this can be modified in the Sys Prefs.
Jun 06, 2015 | Apple Mac Mini Desktop
PSRE323 - is there a way to specify what midi channel is used for midi out, how do you do it. Manual didn't seem to specify anything.
How they expect you to find the information is beyond me!!! I downloaded the manual and it appears that the information you want is on page 57.
Near the bottom, and the only way I spotted the parameter of MIDI channel number setting is seeing the range as 1 to 16.
They list this as L part and R part channel/track setting... these will be for the left and right parts of the split keyboard... that is you can set a MIDI channel to between 1 and 16 for both the left and right division of the split keyboard.
I don't think many people would find this... AND shame on Yamaha, there doesn't seem to be a MIDI implementation chart, which you should get familiar with for any MIDI devices you might have... the chart is a quick access to the MIDI capability of MIDI devices and they didn't include one in the documentation for this unit...
Dec 31, 2010 | Yamaha Survival Kit B2 for PSRE223,...
Have a casio px 320 and trying to use it in GarageBand on my Mac OS X. Connecting USB cable from USB output on Casio to USB input on Mac doesn't work. Any help?
use the audio output to send the keyboards internal patch sounds, or use a usb midi adapter to use the keyboard to trigger the garageband midi sounds, if the keyboard has a midi output, that is. the usb output requires software drivers to use, and IS NOT mac compatible. You may have to select a midi source in garage band preferences or settings if you are using midi.
Nov 14, 2010 | Casio Privia Keyboard Case
Trying to run a mac mini to philips flat tv
Hi Ralph
Normally it's either one of the AV channels OR the channel marked RGB.
What connector are you plugging into on the TV?
Jan 21, 2010 | Apple Mac mini
How to get IMac 10.6 to recognize YTP300 keyboard via UX16
Try turning the I Mac of and on when you do refresh the list try that it should work
Nov 02, 2017 | Apple Computers & Internet
Roland RD-700SX as MIDI keyboard
Theres a good article at recordingreview.com. If you join which is free you have access to a lot of great information. You can download Midiox to troubleshoot your midi connections etc. Make sure that your transmit channel on your keyboard matches up with the receive channel in your program. Hope this helps.
Jul 16, 2009 | Music
Mistar midilink is a plug and play device but it's not working ?
You probably need the proper driver to install this. Go to the products website to find one.
Apr 25, 2009 | Computers & Internet
Mac Mini Keeps ejecting Only OS X disk, how to install OS X
I had the same problem, but with Windows and Ubuntu I had to make two partitions. I can't remember exactly how I did it but I had to have reference to Ubuntu in each partitions. I hope this helps. mysleuth
https://help.ubuntu.com/community/YabootConfigurationForMacintoshPowerPCsDualBoot
Mar 10, 2009 | Apple Mac Mini Desktop
Notes don't stop even after I release the key
The keyboard  is not sending a note off instruction after the key is released. Try checking midi preferences in reason.If your using a Mac check that the edirol is present by launching Audio MIDI Setup utility located in the utilities folder. You can download the latest Mac driver from Roland below: EDIROL PCR-300 32-key MIDI Keyboard Controller :: Download
Jan 18, 2009 | Propellerhead Reason 4.0 - Windows and Mac...
Connecting Yamaha piano (YDP-131) to imac g5
You want to go into your AUDIO/MIDI set up in OS X. Selet the unit. YOu have a MAC so most itmes dont needs drivers, its one of the many great things that separate that operating systems from say windows. Also your yamaha may be CLASS COMPLIANT, which means plug and play no matter what computer you are using.
What you should do is make sure the keyboard is set to send on the same channel as garageband is set to receive.
Keep me posted.
Dec 02, 2007 | Apple iMac G5 MA064LL/A Desktop
Apple iMac G5 MA064LL/A Desktop Logo
1,657 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
