Question about Garmin StreetPilot c550 GPS Receiver
Garmin nuvi 300/350
I charged my unit with the PC and it turns on, but there's no instruction screen.
    Scholar:
  • 162 Answers
Try doing a reset. The button is located under the face plate. Pry off by lifting just under the Garmin name.
Posted on Jul 25, 2008
I don't know how to register my new Garmin nuvi so we can receive the free map updates when our machine is turned on
If the unit is new you get a free map update within the first few months after that they will charge a fee, but you can still update the unit for software and fixes.
Here is what you need to do to update the map your Garmi nuvi; first make sure the unit is fully charged, then go to the Garmin web site and register your product. Next download Garmin Updater and connect your nuvi with a USB cable directly to your computer and not thru a USB hub. Let the update go directly to the GPS and not a folder. It will take a few hours even with a fast internet connection. When done follow the instructions on your screen. I have attached a link to the Garmin site. Thanks for using FixYa
https://my.garmin.com/mygarmin/registrationGettingStarted.htm?productType=auto&categoryType=AUTO
May 26, 2011 | Garmin GPS
Upon turning my Garmin Nuvi 1300 on it sticks on the screen that says "GARMIN".......Loading Maps. It never goes past this screen. I have had this unit since the end of December. It is fully charged and I...
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
Apr 23, 2010 | Garmin nuvi 1300 Car GPS Receiver
My Garmin nuvi 780 will not turn on. When I turn on, the Garmin logo shows on the screen. However, when "Loading Maps" is displayed, 1-2 seconds later the screen goes blank. This occurs when the unit is...
I had the same problem. When you have your nuvi plugged into your cigarette lighter it doesn't charge. Your battery is probaly near dead. I called Garmin and they told me to plug it into my computer via the usb cable. Turn the Garmin off and let it charge for several hours. That did the trick
Apr 03, 2010 | Garmin nuvi 780 GPS
Garmin Nuvi 200 not charging
I also have a Nuvi 200 that didn't charge. The problem is the charging port disconnected from the circuit board. You can disassemble the unit and reconnect the charging port but it takes a small torques wrench and a small screw driver. You will also need a soldering iron preferably with a fine tip and a very steady hand. Good luck.
Sep 24, 2009 | Garmin nuvi 200W GPS Receiver
Nuvi 250 will not turn on when charging.
There are two types of leads that you can buy.
The one supplied with the Garmin expects you to plug the GPS into the PC via the USB and if you use this to try and charge your Garmin in your car it will think it is connected to the PC and show the connection screen. it will charge the unit but you can't see the map.!!!
Make sure that you buy a lead specially for the Garmin for use in the car its the only type of SAT NAV that you will have this problem with.
LOL
Sep 12, 2009 | Garmin nuvi 250W GPS Receiver
Is m Garmin nuvi 200 GPS charging
Merritt, Your Garmin Nuvi does not have a charging indicator similar to say your Cell ph. Simply a battery charge indicator scale. Normal full charge time is approximately 3 to 4 hr. If you looking to ensure your unit is in fact charging Plug in & then remove the connection, Your unit will pop-up a screen to request if you wish to remain on battery power. I hope this helps you.
Mar 09, 2009 | Garmin nuvi 200W GPS
Charging doesn't display map when charging
I learned that with the unit off - hold the on button down - don't release it. A PRE-BOOT MODE message will appear at the bottom and may flash. Continue holding down the start button. The first time I did it a series of dots came on the screen and I was instructed to touch each one. After that it started as normal. I plugged into a wall charger and but git the pc and nuvi icons again. I repeated the process - holding the on button on and let the PRE-BOOT MODE appear and kept holding but this time a different message came on and then the PRE-BOOT MODE appeared again. I let it go and took the unit to my car and plugged it into the Garmin car charger and it worked as it used to - normal. However, when I plugged it back in the house to the wall charged I got the pc and nuvi icon again. It appears that I am using the wrong wall charger as a previous writes stated. But the nuvi still worked in the car plugged into the nuvi charger. I hope this helps.
Jan 24, 2009 | Garmin Nuvi 660 GPS Receiver
Without plugged in my garmin nuvi 200 will not work
That means that you have to replace the battery.
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Jan 21, 2009 | Garmin nuvi 200W GPS Receiver
NUVI 250w Show Black Screen with ICON of Computer and NUVI
I had this problem. I discovered that I was using the wrong lead in the car. The problem resolved itself when I used the lead that came with it.
May 24, 2008 | Garmin nuvi 200W GPS Receiver
Garmin StreetPilot c550 GPS Receiver Logo
61 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
