Entering chatrooms im trying to get into rooms on camfrog but it just says- could not connect to a server this server may be offline or behind a firewall/router
  • Anonymous Dec 26, 2008
    yes i have the same problem i cant log in on camfrog it just keep say could not connect to the server..ive got this problem 2days now and i dont know what do do??..can someone help plz?
What is hsa in ip350 checkpoint
Posted on Jul 04, 2008
How Unblock Fortinet ?
Fortinet can be unblocked using following points :-
  • Navigate to Ublocked Websites Proxy or Truly Unblock (see Resources). These proxies unblock filters originating from filtering platforms such as a Fortinet firewall. Your anonymity is also secure with these proxies because they hide your IP address behind their server.
  • 2 Enter the Web address that is being blocked by Fortinet in the URL bar you'll find on the middle or bottom region of the page, depending on the proxy you chose to visit.
  • 3 Click the "Surf" or "Go" tab showcased beside the URL bar. The website Fortinet was blocking will now be unblocked through the proxy's server. Your IP address will also be masked to keep your browsing anonymous.
  • Feb 25, 2015 | Fortinet Computers & Internet
    How connect cisco 5015 vpn with barracuda linkbalancer 330
    Your Internet gateway <--- primary router
    Port #1 on primary router <---> VPN server
    Port #2 on primary router <--> Load Balancer
    Load Balancer <--> web-server #1
    Load Balancer <--> web-server #2
    Load Balancer <--> web-server #3
    VPN traffic enters your network, through the router to the VPN server, and then VPN-server back through the router to your internal servers. Web-traffic goes through the Load Balancer, for distribution to the collection of servers.
    Jun 12, 2014 | WatchGuard Technologies WATCHGUARD TECH...
    We have an SBS2011 behind a Sonic TZ-100. A router with DHCP enabled is connected to WAN of TZ-100. We need to block DHCP in the TZ-100, as the SBS shuts down his DHCP when it finds the DHCP on the router....
    So I can understand better... You are trying to move DHCP off of your Small Business Server and on to a router that is connected to your firewalls WAN? I don't understand why you are trying to block the connection between your router and your server. Once you turn off DHCP on your server and remove the static IP on it, it should get a new address from your router.
    Best, -Mind
    Aug 04, 2011 | SonicWALL TZ 100 0101SSC8734) Firewall
    Question: I have a sonicwall CDP 1440i. Does it hold a firewall for my server as well serve as a back up device? or do I need an additional external firewall to support the windows operating system?
    It will act as a firewall for essentially anything that is "behind" it. As long as your server and PC are connected to it (or a switch/hub that is connected to it) it will act as the firewall.
    You don't need anything additional to support your windows machine.
    Feb 28, 2011 | SonicWALL CDP 1440i (01SSC6300) Firewall
    Where do i enter my code #
    Hello.
    Not certain of your question, but first, set up a single PC to connect to the SG565 unit. Information is entered from that PC.
    The initial steps are:
    1 Connect your administrative PC to the SG unit:
    - If you are setting up the SG560, SG565 or SG580, attach your
    PC's network interface card directly any network port on switch A
    (A1 - A4) using the supplied network cable.
    2 Modify your PC's network settings to enable communication with the
    SG unit. Click Start > (Settings >) Control Panel and double-click
    Network Connections. Right-click Local Area Connection and
    click Properties.
    Note: If there is more than one existing network connection, select the
    one corresponding to the NIC to which the SG unit is attached.
    3 Select Internet Protocol (TCP/IP) and click Properties. The
    Internet Protocol (TCP/IP) Properties dialog box is displayed.
    4 Select Use the following IP address and enter:
    - IP address: 192.168.0.100
    - Subnet mask: 255.255.255.0
    - Default gateway: 192.168.0.1
    5 Select Use the following DNS server addresses and enter
    Preferred DNS server: 192.168.0.1
    6 Click OK and Close
    Hope this helps.
    Jan 20, 2011 | SG565 (SG0186US) Firewall
    Unable to map server to storage media over the internet for back
    Virtual Private Network (VPN) endpoint and pass-through support. Additional firewall features include custom and policy-based filtering options. These options have to be configured properly.
    Check your configuration level and access policy.
    If its a public server you have to place it in DMZ.
    Check IP settings of the server. U may require a VPN tunnel
    Rate if this is helpful
    Thanks
    Good Luck
    Jun 01, 2009 | D-Link NetDefend DFL-200 Firewall
    Hello
    SOCKS is an Internet protocol that facilitates the routing of network packets between client-server applications via a proxy server. SOCKS performs at Layer 5 of the OSI model - the Session Layer (an intermediate layer between the presentation layer and the transport layer).
    Clients behind a firewall may connect to a SOCKS proxy server in order to access external services through the firewall. Such a proxy server controls the eligibility of the client to access the external server and, if the client has eligibility, passes the request on to the server. SOCKS can also be used in the opposite way, allowing the clients outside the firewall ("exterior clients") to connect to servers inside the firewall (internal servers).
    SOCKS software
    * Kernel SOCKS Bouncer ksb26 (Kernel Socks Bouncer) is a Linux Kernel 2.6.x Loadable Kernel Module that redirects TCP connection (to user-defined target hosts) through socks 4/5 chains.
    * SS5 Socks Server is an open-source SOCKS4/SOCKS5 server.
    * Dante is an open-source SOCKS4/SOCKS5 implementation with commercial support developed by Inferno Nettverk A/S.
    * OpenSSH allows dynamic creation of tunnels, specified via a subset of the SOCKS protocol, supporting the CONNECT command.
    * WinSocks is a light-weight SOCKS4/SOCKS5 server developed by Proxy Labs.
    * SOcat Multipurpose relay (SOcket CAT): includes socks4, and socks4a functionality (Linux / Mac)
    * FreeCap Socksifyer for Windows, any App can run its network traffic transparently via a SOCKS or HTTP proxy.
    * Simple Socks Server for Perl - SSS is a Simple SOCKS Server written in perl that implements the SOCKS v5 protocol.
    * Sun Java System Web Proxy Server is a caching proxy server running on Solaris, Linux and Windows servers that supports HTtp://S, NSAPI I/O filters, dynamic reconfiguration, SOCKSv5 and reverse proxy.
    * BarracudaDrive Web Server - commercial SOCKS HTTP HTTPS tunnel/server, available for Windows, embedded Linux and Mac OS X (PowerPC)
    * DeleGate is a multi-purpose application level gateway and proxy server which runs on multiple platforms. Beside SOCKS it also supports HTTP(S), FTP, NNTP, SMTP, POP, IMAP, LDAP, Telnet, DNS and many more.
    Jan 05, 2009 | Computers & Internet
    How to open outgoing tcp connection...... i'm facing errors in sending sms to mobile while connecting from internet........... the details are as follows Log Out...Could not Connect... Dear User, If you...
    Follow these steps:
    Start-> Run-> cmd
    In the black box type: ipconfig [enter]
    You should see some numbers like this:
    192.168.*.* IP
    255.255.255.0 Sub
    192.168.*.* Gateway
    Go to an Internet Browser and plug in your Gateway address like this:
    http://192.168.1.1
    or
    http://192.168.0.1
    Now your username and password will be like:
    admin:admin
    admin:1234
    admin: {no password}
    {nouser}:admin
    {nouser}:1234
    You get the drift.
    Once you are in you can manipulate the firewall and port forwarding settings...
    Nov 12, 2008 | D-Link DFL-800 Firewall
    Problem in proxy settings
    Dear User, If you are behind a firewall or within a company local area network (LAN), you will need to open outgoing TCP connections to Port 51215 on your proxy server.
    Oct 27, 2008 | Computers & Internet
    Computers & Internet Logo
    264 people viewed this question
    Brian Sullivan
    Brian Sullivan
    David Payne
    David Payne
