Question about Maytag Bravos MTW6600T Top Load Washer
I have a Maytag Bravo top load glass washer and a f51 code. Top wont open and machine has stopped
  • Maytag Master
  • 8,220 Answers
Defective hall sensor most likely, The cabrio bravos and Oasis machines are all basically the same.
MORE here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 19, 2010
SOURCE:
I can not open the door on my Maytag top loading washer
Many new washer use a lid lock instead of a brake to keep people from reaching into the spinner before it stops. You probably have a
bad lid lock. Have a repair man open the top cover and repair or replace the lid lock.
Jul 06, 2016 | Maytag Washing Machines
F51 maytag bravo error code?
The F 51 code, would indicate, the control board is not seeing the proper resistance on the motor circuit .
You should check and make sure there are not any articles, stuck between the tubs, or under the agitator.
Make sure you're not overloading the machine.and you have proper voltage to the unit.
Have you run the unit through a cycle empty ?
You may want to try that, before we have to get too involved in circuit and voltage tests.
Your technical data sheet should be on the inside of the front panel, you'll need to raise the top of the washer, using a putty knife to release the clips in the front seam, holding the top down .
Maytag washer Error Code F51 Appliance Repair Forum
Apr 06, 2015 | Maytag Washing Machines
Washer wont spin. F51 code
the f51 error indicates that your rotor position sensor) is not registering or it is just bad. try this, remove and reinstall the connector at the RPS at least three times to clean off any corrosion built up on the connector and RPS due to the intermittent connections. after that go ahead and try to run a cycle. if you continue to receive the error then you need to replace the RPS sensor. Here is that part to order. Whirlpool W10178988 Sensor AppliancePartsPros com
Oct 05, 2014 | Maytag Bravos MTW6600T Top Load Washer
UL bravo error code
Unbalanced load? Don't over stuff the washer. The load sensing moves the drum back and forth at the start. If it can't balance the load it will err.
Oct 16, 2013 | Maytag Bravos MTW6600T Top Load Washer
What does it mean f 51
http://forum.appliancepartspros.com/washer-repair/131926-maytag-washer-error-code-f51.html
Jan 30, 2013 | Maytag Bravos MTW6600T Top Load Washer
F51 error code on Maytag Bravo
To correct this, remove and reinstall the connector at the RPS at least three times to clean off any corrosion built up on the connector and RPS due to the intermittent connection. Confirm that the connector is fully seated onto the RPS control upon final connection and verify there are no damaged wires.Replace the electronic control. The upgraded control is less sensitive to intermittent RPS connections.
To learn more about your washing machine, or to order parts, click here.
Mar 06, 2010 | Maytag Bravos MTW6600T Top Load Washer
Maytag bravo quiet series 300: Stopped at spin:
We have a Maytag Bravo Quiet Series 300 washing machine, the door latch is broken. I have the replacement part ( the locking mechanism) but I need can not figure out how to get the top of the washer to flip up to give me access to top front of the machine to remove the old part and replace it with the new.
How do I flip back the top (not the door) of this machine?
John
Jan 15, 2010 | Maytag Washing Machines
My maytag bravo top loader washer is displaying a code of LF and
it meant "low flow" check water connecting lines. mine has the same problem.
Dec 02, 2008 | Primera Technology Bravo (Refurbished)...
Maytag Bravos MTW6600T Top Load Washer Logo
1,119 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
