Question about Behringer EUROPOWER EP2500 Amplifier
Ep2500 I am looking fore a parts list for the transistors. I can not idenify the cq 530 g in a crossreference. Thank you
  • 1,512 Answers
Hey rye712000
Just go straight to the Behringer distributor in you country. they are pretty good on spares and information. If you have any dramas, I can help you though my contacts here in Australia.
Posted on Jul 04, 2008
I am a technician I had a challenge with EP2500 is not producing sound after I replaced bad transistor.I lack what to do next.
I would see what else that bad transistor was connected with. Electronic parts don't tend to fail in random areas. Whatever caused the transistor to fail will probably be the cause of your sound loss. Sometimes a static sensitive device linked to a transistor that has failed can go too. I had this Sony amp that the owner was always bringing in for repair, as he would work it too hard, or short a wire! He would have blown a transistor, but every time something went on it, it took out this CX IC, killing the pre-amp on it. It was just too sensitive to static!
Aug 13, 2015 | Audio Players & Recorders
My EP2500 keeps on blowing a fuse on the right channel and I opened it and realised that the two horizontal caps are a bit bigger.
They wouldn't blow the fuse. You are looking at the main devices that power the channel. If you put an ohmmeter on their terminals (assuming they are transistors) then it will show like you have touched the two test probes together. If it does replace the part(s).
Oct 24, 2013 | Behringer EUROPOWER EP2500 Amplifier
Behringer EP2500 drawing large current when powered up
If you are pulling the transistor that drives the final and the problem goes away, is the driver bad? Is the power supply a multi channel isolated unit? Could the channel for that side be bad?
May 18, 2013 | Behringer EUROPOWER EP2500 Amplifier
I have an EP2500, which burns speakers. I connect with a lamp in series, and when it receives high frequency signals, lights the lamp, the output looks correct, but consumption is increasing dangerously....
There was an suggested solution here for your problem.
There are electronic components which seems to be undiscoverable
for a moment.
• The fault could be anywhere from the differential input stage
to the VAS circuits.
• One has to check thoroughly components , and proceed
troubleshooting without the power transistors connected.
• Check for offset voltage on each of the main amp output.
• Check for idling current
A good amp never produce an over of 0.7V on its output.
Jul 30, 2012 | Behringer EUROPOWER EP2500 Amplifier
What are the Behringer EP2500's output stage transistors?
Faichild/Toshiba make the output transistors for the ep2500, part numbers 2SA1943 and the 2SC5200. Beware though there are a lot of dodgy fakes around on ebay. Profusion are excellent. Heres the links for them.
Nov 27, 2009 | Behringer EUROPOWER EP2500 Amplifier
Does anyone has overheat problem with Behrigher EP2500 power amplifier? We had the amp for abut a year. The amp. has recently become overheat (hand burning) after 30 minutes operation. We set the gain to...
The last time I had a problem like this there was a defective transistor in the from end that was generating noise in the 30K range. Too high to hear and too high for the speakers to reproduce, but enough to put quite a load on the amp. Does this occur even with no speakers attached? If so, then put an osciloscope on the outputs and look for signals. WIth no input, there should be no output at all except for a little noise. You can also see if there is any DC on the outputs as well.
Please update this with what you find.
Oct 13, 2009 | Behringer EUROPOWER EP2500 Amplifier
The circuit breaker on my behringer europower ep2500 keeps coming on when i turn it on after the posative and negative on one of the speaker outputs touched, is this repairable. thanks ben
Yes this is repairable, but there is no "reset" switch. There is a good possibility that the output transistors have failed. This unit requires service. If you have no experience with audio amplifier repair, take this to a service shop. Expect a parts cost in the $50 range.
Aug 24, 2009 | Behringer EUROPOWER EP2500 Amplifier
Mitsubishi VS45607 tv
Brief an d to the source. A high voltage speed switch is bad and we will cross reference it with an NTE 2361. But this is only the start. You can crossreference all of the transistors. Q531,Q532,Q533 Q530 , Q5ADO [Horizontal output transistor] and Q5A02 Looks like Q502 on board [also i think this is also an horizontal output transistor. Then by all means change the following capsC541, C551, C531, C562, C534, C402, an d C933 . It will take some time to do this, be patient my friend. Your Mishis will return!
Jun 13, 2009 | Mitsubishi VS-45607 45" Rear Projection...
SANYO AVM-3289G no vertical deflection
It isn't a transistor, It will be an I.C. with a part number that probably starts with an LA_ _ _ _ . It will be on a heat sink and be in the vicinity of the connector going up to the yoke. Try replacing that. But first, check all the electrolytic caps around it for testing dry (sorry - takes a special meter to do it in circuit) or just replace them. May have lost power to the I.C. as well. Look the I.C. up in the free NTE crossreference at get a diagram of its pinout to find what pins the power and outputs are on.
Dec 14, 2007 | Thomson 28VK25US TV
Behringer EP2500 no output on CHANNEL 1
check all op amps for correct voltage swing +-should be equal,test output of op amps no voltage should be present, use chasis gnd as tester neg.check voltage regulation especially 12v or 15v +-.note some amps show unequal led indications when only 1 channel connected to a load.I will try to get some more info on this specific amp because i don't know this circuit well,keep in touch as you update though.
Aug 21, 2007 | Behringer EUROPOWER EP2500 Amplifier
Behringer EUROPOWER EP2500 Amplifier Logo
112 people viewed this question
Top Behringer Audio Players & Recorders Experts
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
