Question about Xerox Phaser 8200 Laser Printer
Service code 07.005.47:57306 on xerox 8200
Printer print 4 copy,end stop service code pop?? PLESE HELP my company is UNITED COPY SERVICE @ADRES IS unitedcopier@aol.com telefon 281 550 4900 thank you wesley
  • Anonymous Mar 21, 2014
    the printer just stopped printing but the scanning and copying functions still work
    President:
  • 2,072 Answers
That is something to do with the drum maintenance system.
1 of 2 thinhgs is most likely. Remove the maintenance tray and look at the tabs the stick out from it. About 1 inch long or less and 1/4 inch high or so. Those will wear and have sort of a step shape to them. That can be the problem itself, but more likely, the maintenance kit clutch is bad and slipping. The timing of the maintenance kit movement is off. Here is that clutch part number
401-0871-00. You can call 1-800-835-6100 and order it from Xerox, or look on google for it. I have found better prices searching, although its not real expansive. It is on the left frame, looking at the front.
You remove the left cover, the clutch is lower on the frame on the front 1/3 of the machine. Really easy to replace and I would say more than an 80 percent chance that cluch will resolve your problem.
Posted on Jul 15, 2008
Xerox phaser 8200 laser printer leaves 2" blank strip on left hand side of paper, Fix?
Try a brand new document and cover the page in characters and test print. If the issue persists, then please call for service.
Nov 03, 2013 | Xerox Phaser 8200 Laser Printer
Our xerox workcenter 7235 fault code 024-360 and copy service is disabled
024 360 An error has been detected by the Controller during communications with the Printer. User intervention is required to Power Off/Power On the machine, Field Service is required if the problem persists. Printing is disabled.
http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=WC7228_WC7235_WC7245&Xlang=en_IN&Xcntry=IND
You will have to either get this printer repaired or replace it.
Aug 05, 2010 | Xerox Office Equipment & Supplies
Xerox XC1875 U4 Error on Startup
Give this a try. it may clear you code. Use program 14
To enter diagnostics: Turn on the power and within 4 seconds press the following sequence: ‘Clear’, ‘Exposure Mode’, ‘Clear’, ‘Exposure Mode’ (Exposure Mode is the button on the far left). The console will go completely blank.
To enter a code: Select the first part of the code using the copy quantity buttons, followed by the ‘Print’ button, then the second part of the code followed by the ‘Print’ button again.
To exit diagnostics: Press ‘Clear’ repeatedly or turn the power off.
*To clear a fuser code:(14) Enter diagnostics, select ‘14’ followed by ‘Print’… exit diagnostics.
**To Clear a U2 code:(16) Enter diagnostics, select ‘16’ followed by ‘Print’… exit diagnostics.
May 04, 2009 | Xerox Office Equipment & Supplies
Xerox Phaser 8200 Error Code 15004.45:18370
unless you know how to service preheater/drum heater then you have no choice but to ask the qualified person to do it for you....
YOu can read more details baout the failure at below link..
http://etech.maiila.com/xerox-phaser-8200-drivers-software-manual-and-troubleshooting
Apr 22, 2009 | Xerox Phaser 8200 Laser Printer
Error 15 004 45 37888
From the service manual:
15,004.45:
TCD_THERMISTOR_
SLOW
Most likely cause is a failed drum heater. The head to drum gap
should only be checked or adjusted on the Phaser 840. The
Phaser 850, 860, and 8200 have a pre-adjusted head.
In other words, you need to replace the drum heater.
Thanks and please take a moment to rate as fixya.
Mar 13, 2009 | Xerox Phaser 8200 Laser Printer
Xerox 8200 Fault code 15,004.45:35676
The drum temperature is incorrect as sensed by the drum
thermistor. Ensure that there is adequate clearance for airflow (at
least 4 inches (10 cms.) on all sides) and that the room
temperature is within specification
Jan 09, 2009 | Xerox Phaser 8200 Laser Printer
I have a Xerox 8200 printer that will not feed paper thruogh the print area
Do you get a specific code?
And where does the paper stop?
If it is not getting out of the tray, I would think you have a very smoothe feed roller.
Like trying to drive on ice. No traction .
That is if it is not getting out of the tray.
Let me know where the paper actually is stopping plese.
Apr 21, 2008 | Office Equipment & Supplies
Problem printing in color on Xerox Phaser 8200 from Mac
That actually should make magazine quality color.
What are you experiencing? Do the colors not match? Are there smears or light streaks?
I will gladly work with you to revolve your problem, I just need a frame of reference to start.
Let me know.
You may simply need to download and install a different driver.
They are on www.xerox.com you should be running the PS version of a driver for better graphics.
Apr 02, 2008 | Xerox Phaser 8200 Laser Printer
Phaser 8200
That normally indicated a heating issue with the print head. Could be the printhead itself or an issue with the electronics module providing the source voltage for that heater
Mar 12, 2008 | Xerox Phaser 8200 Laser Printer
Cranking noise when is turn on
We had this same problem.
A tech had to come in and replace a cog in the back.
Nov 20, 2007 | Office Equipment & Supplies
Xerox Phaser 8200 Laser Printer Logo
333 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
