Question about Whirlpool 15.2 cu. ft. / 430 liter Upright Freezer EV150FXKQ
Need to add freon
I need to add freon to my 1996 upright freezer. Which line is used.
  • 481 Answers
  • if you are tapping into a sealed system, then you use the larger of the two copper lines coming out of the side of the compressor (this is the low pressure line, the compressor pulls from this side).
  • clean off the copper tubing with some fine sandpaper before installing your tap.
  • it is very easy to over fill a system with freon, so i would recommend pulling down the system to -30 psi and holding for at least 20 minutes. then add a known amount of freon to the system.
  • let it run for a while, it will take a little time to get the temperatures down.
Posted on Jul 02, 2008
How to add 134a to magic chef deep freezer
First your freezer does not use R-134a. That is for auto air conditioners only. It uses R-12. You need refrigeration compound gauges, R-12 refrigerant and a two devices that connects to and punctures the lines and gives you a port to connect the hoses from the refrigeration compound gauges. You must have a refrigeration leak if you need to add refrigerant. The leak needs to be repaired or you will lose the refrigerant in a short time again.
Nov 08, 2015 | Magic Chef Chest Freezer MCCF5WBX
Whirlpool freezer cool air but not freezing?
Check the seal first. Then check the freon. If it's R-12, you can go to the auto parts house. They have a bottle with a hose to add freon. You put it in on the "suction" low side with the unit running. you can tell when it has enough by feeling the low line be cold and teh high pressure line is warm to hot
Jun 06, 2014 | Kenmore 14.1 cu. ft. / 399 liter Upright...
How to refill R134 Freon
you have first put in a line tap. If the freezer system has been open it must be put in vac. to get moisture out. Then with interior coil exposed put in a few oz and start compressor. with compressor running add while watching interior coil/ you add slow til coil frosts to 3/4 then your done
Oct 26, 2013 | Amana 19.7 cu. ft. / 558 liter Upright...
I have a Magic chef upright freezer i can hear the compresser running but it will not freeze meat
Has this happened suddenly? Look at the shelves to see if there is a frost line. If the shelves that also carry the Freon appear to have a frost line your freezer may have a Freon leak. If there is a Freon leak it will be better to begin looking for a replacement freezer. Let me know what you see, Thanks Sea Breeze
Nov 29, 2012 | Magic Chef 11.8 cu. ft. / 334 liter...
Where do you get tap to add freon
I always get my tap valves at The best ones to use are bpv-31 bullet piercing valves, because they are capable of piercing a variety of line sizes, so your not limited to your tap location and find the most accessable spot.
Apr 26, 2012 | Whirlpool 15.2 cu. ft. / 430 liter Upright...
What to do if you have a freon leak in the freezer
charge with detail (that is a Freon with Red dy solution to help locate your system leak) locate leak, repair using silver solder, evacuate system completely, pull vacuum down to 27" plus Lbs. vacuum, close system to hold vac pressure, monitor pressure for 30 minute or so, if vacuum hold pressure then you have successfully fixed your system leak, next hook up your system to the manifold gages assembly to a Freon supply source, all this while retainning your vacuum pressure, slowly crack open the valve on the manifold to allow the new freon to enter your system until you see pressure building up in you system, next monitor the discharge line i.e. the bigger line until you see frost extending outside of your freezer unit toward your compressor assembly, then close the freon supply valve, wait for a while to see if the frost line recede into the unit box, if it does not recede but stay out of the box or extend some more then you must must release some freon slowly a very small amount at the time until the frost line has regressed into your freezer box. this should complete your repair, good luck
Apr 24, 2012 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Where and how to add freon to upright freezer
I did one earlier this summer. Took some pix. Check this out: Freezer recharge
Oct 23, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
I cannot find the location to add freon to my frigidare uprifgt freezer model number-ffu16f9cw1
Most freezers do not have a tap from the factory to add aditional will need specialized equipment to be able to do that...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Aug 02, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
"High wind" sound following defrost.
Freon running through the feon lines can make some odd noises, usually a gurgling or higher pitched noise. If your freezer works fine with no more strange noises, then don't worry about it. If you have temperature problems or continue to have abnormal noises, then see if your freezer has the 5 year sealed system warrantee that most freezers have. If it does, and it is under 5 years, then call Frigidaire to come out to check it out for free. If it is out of warrantee you will need to live with it or replace the freezer, since a freon sealed system repair is very high. Good Luck, Appliance Specialists
Feb 04, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Food thawing in freezer
You may have a small leak in the evaporator. You could try to get a replacement freon with stop leak from the automotive store and give it a shot. If it is a R12 unit then it is too old to repair. But it is worth the gamble to shoot it with freeze 12 or an equivilent before you condemn it.
Apr 10, 2009 | Freezers
Whirlpool 15.2 cu. ft. / 430 liter Upright Freezer EV150FXKQ Logo
711 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Justin Duby
Justin Duby
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
