Onkyo 705 has no center channel when digital input is connected...
Hello all,
for some reason my onkyo 705 has no center channel when digital input is connected...
it was working fine and all the sudden this problem occured...
analog in has no such problem...
i tried reseting/rewire it.. still the same...
any ideas?
i'm running bi-amp on my front speakers tho.
thx
  • 682 Answers
Try with another digital cable.and confirm that your source assigned to digital signal.
Posted on Jul 04, 2008
Receiver says center channel unavailable
It may be the surround mode you are in. Some modes do not use the center channel. Try changing to a pro logic mode, these will almost always use the center
Jan 23, 2013 | Onkyo TX-SR304 Receiver
Cant get tv audio through receiver directly (without satallite, Game, DVD connection)
If your TV doesn't support audio return channel (ARC, which is your TV audio routed back to the receiver through the same HDMI cable), you then need to connect your television audio-out to your Onkyo TV audio input, using a digital cable or an analog one according to the connections on the back of your TV. If you use a digital connection (optical or coaxial), make sure you have the proper digital port assigned to TV on the onkyo I/O assign menu/digital inputs.
In case your TV does support ARC, you need to activate it in the Onkyo's hardware/HDMI setup menu, either by turning on HDMI control (tv or receiver control each other via cable), or by turning ARC on (you'd probably need to activate ARC on your TV as well).
Hope this help,
M G
Jan 03, 2013 | Onkyo TX-NR609
I am using Onkyo HT-R320 for past 6 years. It was working fine and i connected via digital cable. suddenly i couldnt hear the audio, but the video is working fine. i verified all the setting (audio select...
I don't have a fix but I think the general explanation that could explain both issues would be that the memory for your settings isn't being retained. Check to see if the digital audio source you're having trouble hearing still has its input assigned to it. I'm thinking all your settings go back to 'factory' when you turn it off.
See this entry:
http://www.fixya.com/support/t3692493-onkyo_receiver_memory_power_backup_not
Page 36 of the manual discusses the Memory Preservation theory.
http://www.retrevo.com/support/Onkyo-HT-R320-Receivers-manual/id/367dj085/t/2/
You COULD also try a forced microcomputer reset once just to see if that resolves the issue (same page).
Jul 12, 2011 | Onkyo HTR500 Receiver
Center channel stoped working on onkyo Dr-S2.2
Have you re-run the speaker definition and level steps? I can't find the manual. Perhaps you could flip a few pages in the Troubleshooting Section.
Mar 19, 2010 | Onkyo LS-V955 System
Sound disappears when channel is changed
try connect a rca cables to ensure sound , the tv has scart port or audio output rca? the digital input on receiver is non priority level, so every time you change chanell the receiver jumps to next Line input present. (receiver output security)
Jan 17, 2010 | Onkyo TX-DS474 Receiver
I have 1 center channel pre-out on back of my kenwood receiver. how do i hook it to the inputs on onkyo m-282 amp and then to center channel speaker?
Unfortunately can't connect it that way. The pre out is only meant to go directly into an amplifier that has all of the same inputs (front/rear, center and surround), not a standard receiver. (Pre amp to amp only, not pre amp to receiver) If your Onkyo doesn't have all the same inputs as your Kenwood preamp has outputs you will just use your standard left/right outputs from the Kenwood to your Onkyo input (CD, Tape, Phono,DVD etc) then use the outputs (front/rear, center and surround) from your Onkyo receiver and connect directly to your speakers..
Jan 01, 2010 | Onkyo M-282 2-Channel Amplifier
Describe your Onkyo TX-SR875 7.1 Channels Receiver Problem All right channels are not working. Left channels including center channel speaker is working. Please advise.
Recommend changing your FINAL drive AMP IC most house BOTH right and left channels, your drivers right channel input is good cuz it is used to make the left channel signal
Nov 22, 2009 | Onkyo TX-SR875 Receiver
Audyssey won't initialize the left rear channel speaker input during set-up
had the same problem found that the rear speakers were connected to the wrong inputs on the receiver, try changing them i think you will find that this will work
Aug 28, 2008 | Onkyo TX-SR605 Receiver
Onkyo TX SR 875 HDMI switching
Hello, do the receiver inputs work with other HDMI sources? Thank you, Onkyo USA
Apr 07, 2017 | Onkyo TX-SR875 Receiver
Onkyo 705
You have probably done this, but have you changed the video settings in the setup menu to have the tv using HDMI out? I believe it is under the first option when the menu comes up.
Dec 23, 2007 | Onkyo TX-SR803 Receiver
91 people viewed this question
 Grubhead
Grubhead
