Question about Dell Inspiron 710m Notebook
Dell 710M Problem
Recently when I powered up my Dell laptop, a black screen came on and the message "Loading PBR Descriptor 2...Done." came up. I tried to F11 the thing on the next start up, and its telling me to back up fiels, and "SMART failure predicted on Hard Disk 0" - i dont have any files i need to save, can you help me restore to factory settings?
  • mod220 Jul 02, 2008
    Any help would be greatly appreciated!!!
  • mod220 Jul 03, 2008
    Thanks, Map. Unfortunately after a recent move, I no longer have any of the discs. I do have a second computer, could I download the info and burn onto a disc then load?
There are 47 drivers available, which ones do i need? thanks for all your hlep
MOD220
Posted on Jul 07, 2008
    President:
  • 2,351 Answers
Hi mod22, click on this link for the latest driver software for the Inspiron 710M notebook.
http://support.dell.com/support/downloads/devices.aspx?c=us&cs=19&l=en&s=dhs&SystemID=INS_PNT_PM_710M&os=WW1&osl=EN
You most likely received restore CD & windows CD with the dell. If you didn't than the download site above will be a must for drivers.
The error message SMART = Self-Monitoring, Analysis & Reporting Technology. It is not the same thing as drive testing. It’s actually a part of the drive electronics & it tests its self. There is a 50/50% chance after turning off SMART in the bios you're drive will continue to function.
We do not want to wipe you're drive because there are other partitions that dell has in place.
This partition is needed to restore you're drive & OS.
Try this.
1- Start up the computer & press F8 or F12 every two seconds to give you windows boot-up options.
2- Insert Windows Installation / Recovery CD into cd-rom drive, high light the cd-rom drive & press enter.
3- Let the installation process continue until it prompts you to "Press R to repair". . This should then take you into the DOS mode.
4- Type in FIXBOOT & when prompted, press "Y" to start creating the new boot partition. If everything goes right, you should get a message saying the partition was corrupted and a new one was created successfully.
5- Remove the CD and reboot your system, everything should be ok now.
If not than put you're Windows CD or recovery CD into the cd-rom drive. Again press the F8 or F12 key every two seconds at boot up until the windows boot device window loads. Choose the cd-rom drive. If you are using the recovery cd follow the prompts on you're screen. (Best choice).
If you're using the windows CD choose to format the C:\ & install windows fresh. Last option. If you know or can find the name & model of the hard disk drive, you can go to their web site & download tools & utilities software. There will be software for you to make a bootable CD that can test & fix the hard disk drive. The object of doing this is to keep the drive running rather than going through this again or buying a new hard drive. The Mfg's software will also let you know if the drive is going. (Chances are the software will repair the drive).
Good Luck!
If you have a problem with anything above just let me know & I'll try to clear up any issues.
Mike
Posted on Jul 03, 2008
  • Mike Peluso
    Mike Peluso Jul 03, 2008
    Sure mod220!
    Burning the drivers to a CD will work. Before you create the CD download each driver into its own folder. Name each folder so you know what driver is inside. Than uncompress each driver within its folder. Sounds a little tougher than it is but the advantage is every driver will already be uncompressed allowing you to install directly from the CD.
    Again good luck mod220!
    Mike
  • Mike Peluso
    Mike Peluso Jul 07, 2008
    Hi MOD220, only you can tell what drivers you need for you're system. When you open the CD/DVD +. There are 18 downloads. When you enter the bios the CD/DVD's model should be listed. Only download the proper firmware for the correct cd/DVD. This device can wait untill windows is installed.
    It will still function. You do not need the bios download. There is only one audio driver. You do not need any applications in order to install windows. (Remember you can alway come back & get the correct driver software). You do not need the diagnostics software or the modem software yet. Durring windows install, windows will find most devices & install its software. Wheat it does not find correctly is what you download & install.
    The video you can download. The chipset download. Input device drivers you download. Network (9), you sould dowload all unless you know which one you'll need. Still have the manual? Everything should be mentioned in there. (Hopefully)!
    That is all you need. After windows is installed be sure to update it. Windows will find hardware devices & updates for the system.
    Hope this answers you're question.
    Mike
My Dell Inspiron 6400 (Windows XP Home) won't reboot. It's giving me a "Loading PBR for descriptor 1 ... done" line on a black screen. What can I do to fix it. Can I salvage my content / files
Before you use the Recovery CD you need to backup your data because to restoring your laptop will wipe your data off the hard disk.
To backup your data when you cannot boot up your laptop, remove the hard drive and connect it to an USB hard drive adapter. Connect this hard drive/USB adapter into the USB port of a working computer. The computer will see it as an external storage device, you can then open the folders and backup your data.
You can then fit the hard drive back into the Dell laptop and boot up with the Dell recovery CD to reinstall Windows etc.
Mar 04, 2013 | Dell Inspiron 6400 Laptop Computer Core 2...
My Dell says loading pbr descriptor
1)Try F8 safe mode and follow directions.
2) Insert installation disk and use repair option.
Apr 04, 2012 | Dell Computers & Internet
Screen says" Loading PBR for descriptor
And again and again and drives you up the wall.OK-boot sector is corrupted, or hard drive is going south.What you can try is system restore.On boot see which button is designated for that-usually f10 or f12.Start tapping that button and follow instructions. If that failed, the only option is to reinstall OS.If you have a lot of stuff that you want to save, install Windows in different folder, say WindowsA.All your stuff will be saved on the Hard drive-My Documents.Good luck and keep us posted.
Jun 14, 2011 | Computers & Internet
I have a dell inspiron 1300 and I accidently shoot down the PC during the runing program when I restarted again what I get just a black screen and a message Loading for PBR for descriptor 2 ...done. I...
Start the PC and run diagnostics (Fn + Power) then run the hard drive diagnostics. If this fails then chances are the Hard Drive has errors which probably means you would be lucky to get your file back Im afraid.
Sep 08, 2010 | Dell Inspiron 1300 Notebook
Loading PBR for descriptor 2... MODEL DELL DV051
That is the boot loader message to boot to the NTFS Primary boot partition (Primary Boot Record for Descriptor 1 is the Utility partition)
Normally, this message flashes and the system boots, since it is not there is a failure in the boot process.
#1 run diags on the Hard Drive (CTRL+ALT+D at boot) and see if it passes
If it does
#2 Boot to you XP CD, press R for recovery console, and run the COMMAND CHKDSK /R see if the system will boot
If no go, go back to recovery console, try the command BOOTCFG /Rebuild then see if the system will boot
If That fails, try reinstalling Windows
If Diags Fail or all the above fail, replace the hard drive
Jun 24, 2010 | Dell Computers & Internet
Start up gets to "Loading PBR for descriptor 2... done"
I suspect that the viruses had infected some of the files that windows needed to boot up. The moment you ran the Mcafee, the scanning might have deleted or quarantined those files. That is the reason you're having this Loading PBR message because it is now trying to boot from the network and not from the hard drive. You will need to repair windows using the CDs that came with the computer (the Operating system CD/DVD) and run CHKDSK /R at the screen where it says 'repair your computer using the command prompt". If this does not work, chances are, you may need to reinstall windows and everything and that all information in your hard drive will be wiped out.
Jan 03, 2010 | Computers & Internet
When I first power up the notebook, it says " loading PBR for descriptor 2...done" pleaseadvise what to do next?
hii
This problem which you are facing is a hardware problem so you can go to vendor or you can visit our senoir technician at----http://tinyurl.com/nznbpm
Jun 20, 2009 | Dell Inspiron 2200 Notebook
Loading PBR for descriptor 2...done
Boot to the Diagnistics FN+POWER at boot, run hard drive diagnostics. The PBR Descriptor 2 message is part of the normal boot process (directing the boot loader to Primary Boot Recond 2, the C: Drive) but usually flashes on an off so fast most people never notice it. Since the boot process is not going past the re-direct it is indicative of a bad hdd (Since the re-image process crashed)
Most likely you are looking at a hard drive replacement.
Regardless you are going to need an XP CD (you'll have to reinstall windows or run recovery console at a minimum)
Apr 01, 2009 | Dell Inspiron 6400 Notebook
Loanding pbr for descriptor 2 done
hi there.. i'd really hate to say it but you have to reinstall your operating system.. honestly even if your're gonna try running chkdsk/p or /r it still no good it will just waste your time.
Mar 12, 2009 | Dell Computers & Internet
Dell Inspiron 710m Notebook Logo
609 people viewed this question
Alun Cox
