Question about GE Washing Machines
What year did you make this washer WBB4500E1WW
    Novelist:
  • 161 Answers
Call the GE hotline and ask. The age is coded in the serial # not the model #. It repeats every 15 - 20 years so you will have to have a rough estimate to be sure.
Posted on Jul 03, 2008
Wbb4500e1ww
Looking for Ariston AV51 manual.
Jan 26, 2014 | GE WBSR3140DW Top Load Washer
I have a WBB4500E1WW washer that started to make noise when in the wash cycle. Could a bearing be going out or what should we be looking for?
http://applianceassistant.com/repair/sounds/ddWasher_noises.php pa 1schmidt, without hearing the sound it is hard to say. Here (above) is a wonderful link for strange sounds made by washers and the parts to check for them. Wonderful site as well.
I would bet that something is stuck in the pump and needs to be removed, but it could be several other things.
Hope you find this link helpful; if you need any further help, dont hesitate to contact me.
thanks,
Mike
Jul 19, 2011 | GE WBB4500EWW Top Load Washer
Ge # wbb4500e1ww stops during fill, wash,spin and rinse cycle intermitenly there is no regular pattern we can follow. We are lost as to what to do
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Feb 27, 2011 | GE WBB4500EWW Top Load Washer
Washer is filling too much and water is coming out overflow
you need to clean the pressure swith hose on the lft side of tub small rubber hose stop use in liqid soap
Jan 30, 2010 | GE Washing Machines
My GE Model # WBB4500E1WW washer not spinning
the washer is on but not spining and the machine is about 6 month old
Dec 19, 2009 | GE WBB4500EWW Top Load Washer
Check your hose end. On your hoses there are screens at the end that goes on the washer, and that screen could be plug enough to intermitent.
Dec 07, 2009 | GE WBB4500EWW Top Load Washer
GE washer won't fill with cold water
Cold water pipe had become frozen. FYI this model of washer has a nice feature whereas you can test each component i.e. valves, by setting the timer and reading the LED's on the front panel. Instructions are in the schematic.
Jan 17, 2009 | GE Profile WPRE6100G Top Load Washer
Washing Machines Logo
100 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
