Question about Acer AL2416W 24 in. LCD Television
Mounting an Acer AL2416 to the wall
Dear Twenty:
I, too can not see a way to remove the stem under the Acer monitor. If I can remove the stem, then there are four holes in the back where I can attach a custom wall mount plate.
Can you email me? I am curious as to your thoughts. Reach me at
  • Anonymous Aug 27, 2008
    can it be mounted on the wall,? do u have too make a plate so you can mount it?
Hello Poet,
I recently purchased two of the Acer AL2416W to mount onto a monitor stand. I ran into the same problem, it looks as though you have to remove the entire rear of the Monitor to take the factory leg off. I believe I was trying to make it too complex, just gently pry the rear cover off of the hinge this will expose 4 screws remove these and you are all set.
Posted on Jul 15, 2008
The screen is blinking too fast to do anything I am on another computer now how can I fix it?
inputs are wrong. use the proper cable. Set up your video to extend displays. Change resolution.
Mar 31, 2014 | Chief Manufacturing Chief Flat Panel Dual...
How to you remove the monitor? we're trying to set up a standing work station
There are plastic covers where the hinges are, they will pop put to allow you to remove the stand mounting screws.
Sep 01, 2011 | Acer AL1717 17" LCD Monitor
Rehow could fix the sreen on wall?
Remove the LCD monitor stand, purchase a wall mounting bracket. There are several types, one is on an articulated arm which allows you to left, right, up and down. Another type mounts flat to the wall with limited up and down adjustment.
You need to check the mounting holes on the wall brackets so it matches the mounting screw holes on the LCD screen.
Nov 26, 2010 | LG 22" FLATRON LCD Monitor
I have the acer AL 1916w monitor behind the monitor there are four holes available . i want to mount this monitor on the wall . so pls help how will i mount on wall by using this hole or any possibilities...
They are Metric screw M4 or M5 from HD or LOWE's,
When you buy a wall mounting kit, it should come with the monting screw, do some research to what kind of mounting kit you are going ti buy that will have the mounting pattern that fit your monitor or if it has variable pattern that will accomodate your monitor.
User manula and support;
Watch out for caps going bad in your monitor also.
Aug 20, 2010 | Acer AL1916W 19" LCD Monitor
Is it possible to remove the monitor standfrom na Acer AL2016W monitor
Im under the impression you want to wall mount the monitor. Ive done this with a few monitors it should just unscrew and basically fall off? Have a look underneath the base for any screws they will be somewhere keep looking.
Oct 31, 2009 | Acer AL1916W 19" LCD Monitor
Stem on lcd monitor can't be removed
Usually the stem has a plastic cover that hides the securing screws from view. You must pry up the cover to reveal the screws securing the stem to the monitor. This is most easily done with a Plastic pry bar or plastic putty knife. Hope this helps you with your problem.
Apr 27, 2009 | Computers & Internet
Monitor stand
I have one or two nice used Original ones available.
Where are you located ?
email if you want pictures and costs
Mar 05, 2009 | Acer AL2017 20" LCD Monitor
How do I remove the stand?
Looking at the manual
It doesn't appear to accept a standard VESA mount to enable mounting on anything other than the supplied stand.
Jan 05, 2008 | Acer AL1913 19" LCD Monitor
Acer AL2416 LCD
About a year ago I encountered the same problem with an LCD flat screen. It turned out to be a bad driver board but the customer did not want to spend the money to repair it. A good computer repair shop should be able to fix it for you. would be a good place to start.
Jun 22, 2006 | Acer AL2032WD 20" Flat Panel LCD Monitor
Acer AL2416W 24 in. LCD Television Logo
382 people viewed this question
Top Acer Televison & Video Experts
Gareth Cockram
Gareth Cockram
Rommel Balcita
Martin Murray
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
