Question about Sanyo Microwave Ovens
Sanyo Microwave EMS 8000W Turntable motor failed need a replacment?
This motor is round in shape.
Is there anything that might work?
I realized this motor is no longer available through Sanyo?
This motor was produced by JAE IL ENGINNERING CO. LTD
#'s Stamped on the motor.
ST 18F
2115
KX63MY2AS
AC 120V
F Class
60HZ
6 RPM
2.5KW
Thank You,
rvland@netins.net
Here is the part. http://microwaveglasstrays.com/shop/120v-microwave-turntable-motor-kx63my2as-p-425.html?zenid=49789d7ea1a65ff589462093dfab2c94
Posted on Oct 01, 2012
  • Sanyo Master
  • 9,086 Answers
About the only option is to carefully take the motor apart and see if one of the pins that holds one of the gears has broken.
If you're very careful, you can use super glue to glue parts back in place, but they have to be squeaky clean and dry before applying glue and they must be clamped in placed to bond.
Be sure you hold it shaft side down when you pull the outer cover off.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 06, 2008
My turntable doesn't turn
Sounds like the turntable drive coupling is broken. In the bottom of the microwave where your turntable is, underneath that is a small drive coupling that the motor shaft pushes into. if the motor doesn't turn or the coupling, which commonly has a D shape shaft to keep it from slipping, is broken, the tray will not turn. One quick test it to remove your tray and see if you can turn the coupling easily by hand, if you can you probably have a broken drive coupling. The turntable motor is very difficult to turn by its shaft. so if it turns easily it is probably a broke coupling. NEVER force your turntable around by hand or you can break that coupling.
May 12, 2014 | Panasonic NN-S963BF Microwave Oven
Turntable wont turn on my sanyo s7560w
Base on other microwaves I suggest that it is either the drive element or the turntable motor. If you hear the motor turning it is likely to be the drive element. To get to the drive element take out the glass plate and there will be a plastic part that engages the plate. You should be able to pull the drive element out with a little work. The receptacle of the element will likely be shaped like a circle with a flat spot. If the plastic looks deformed it is likely the drive element. Don't be surprised that they want $30 for a new one. Use glue on the drive element as a last resort. With the drive element in but the glass out run the microwave for a few seconds. Can you see the drive element turning? No? New drive motor needed. It may be expensive but it should be easy to replace.
Oct 23, 2013 | Sanyo Microwave Microwave Oven
I have a GE Spacesaver PVM1870 microwave - the turntable has suddenly stopped turning. I've tried the "Turntable On/Off" button, but it did not help. What else can I try?
Perhaps the turntable motor has failed. Replace it as soon as possible as if you don't the food will not cook properly.
Replacing the turntable motor.
The motor assembly is fixed to the base of the oven usually with two screws and access i obtained by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate and disconnect the motor. Remove the motor and go and get a new one. Re fit it and put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Jan 03, 2011 | General Electric PVM1870SMSS Microwave...
GE microwave oven squeals as carousel is rotating. Noise stops in a minute or so but begins anew when the unit is used again.
If it is the wheel on the turntable that squeels, wash the turntable in strong solution of washing up liquid and water.
If it does it without a turntable fitted, change the turntable motor.
Hope this helps.
Jan 01, 2011 | General Electric Microwave Oven
Sharp microwave (R-959m) turntable not moving
Sounds like a new turntable motor is required.
Hope this helps.
Dec 28, 2010 | Sharp R-930AK Convection/Microwave Oven
I have a CMW-100 microwave. The turntable has intermittently stopped spinning. Now, it has stopped spinning entirely. Is there a part I need to replace to fix this problem? Judie Snivley
Sounds like the turntable motor has stopped working.
Hope this helps.
Dec 15, 2010 | Cuisinart CMW-100 Microwave Oven
Turntable motor for Sanyo EM S 8000W microwave.
The best place to order Sanyo parts is Tritronics.
Aug 18, 2008 | Microwave Ovens
Microwave turntable does not turn
I have the exact microwave you do (ems8000w), the motor failed and I found this one worked perfectly as a replacement.
The original is impossible to find.
https://microwaveglasstrays.com
1 x 120v Microwave Turntable Motor 6RPM 4W # F63265G60AP (F63265G60AP) = $14.99
Good luck.
May 02, 2008 | Microwave Ovens
Microwave Ovens Logo
307 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
robert landry
Greg Cann
Greg Cann
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
