Question about Shuttle Computers & Internet
Sb75g2 shuttle x
Can anyone help the sound is clicking pointing to the sound on board chip, can the chip be replaced or is it a new mobo?
Can you advise please
Harvey
  • 2,427 Answers
Well actually this means a new motherboard, however you can purchase a sound card and install it. the card is a few $$ but a lot cheaper than a main board.
Posted on Jul 20, 2008
Computer not giving output to screen
Looks like a BiOS chip problem.
The bios on your board is the lifeline when starting your computer.
Pull out the bios chip and clean the contact points.Pull out the mem battery back up and flash the bios memory.Pull out all the hardware board on the PCi socket.
Put back the bios chip and flash jumper back after wards.
Restart......If BiOS shows up on screen you got a chance to revive the MoBo, if not.....Check the capacitors near the processor and look for any bloated caps. and replace it w/ the same value.
If no bloated caps.......... Sorry to say, you have to replace that board and upgrade to a higher type.
Hope that helps!
Dec 01, 2011 | Asrock P4I45GV...
Problem: No display everything running including cpu fan, pci card everything. No error sound. Anyone please help. its a x58 chipset. I also checked that the motherboard getting hanged. like after running...
You will remove the CMOS battery and wait for 5 minutes .
Hope it will solve.
If the problem is same please change or clean the RAM with eraser and install it again.
If the problem is same please ,
http://www.techspot.com/review/129-asus-p6t-deluxe/If the mobo is in warranty should change .If period expire Now you will create a identity mark on BIOS chip and ,you should remove resoiulder the BIOS chip from *********** board .and install it again tightly.
If all the procedure will fail think your mobo should change as new.
Hope this helps.
Jan 10, 2011 | ASUS P6T Deluxe Motherboard
I have a gateway 831gm. it has an Intel (Augsburg) 915G Motherboard and a Pentium 4 630 cpu 800MHz fsb & 2MB L2 cache. i've been looking for a cpu upgrade and saw that the Pentium E5200 Dual Core has...
If both motherboards are LGA775 socket, then the next concern is whether or not the case is capable of having the new motherboard installed into it. Disconnect all power cables to all dv drives or cd drives and hard drives. Disconnect all ribbons from drives to the mother board. If you can get to all of the screws that hold the motherboard into the case, you get away without removing drives. Once you've got the motherboard then you can disconnect the power cable from the motherboard. Remove the memory chips, disconnect the sound cable from the old motherboard. install the memory chips onto the new mobo, Connect the power cable to the new mobo, then install the new mobo into the case. Replace the ribbons from the drives to the mobo, replace the power cables to the drives and reinstall the sound cable to the cd or dv drive. You should be done now.
Dec 13, 2009 | Gateway 831GM PC Desktop
Video Cards Supported by Shuttle MV42N Motherboard
Hi Brian!
Your Shuttle supports APG cards, ther is one APG 4x slot on that mobo.
Here is the spec for your mobo:
http://eu.shuttle.com/archive/en/mv42n.htm
Good luck to you
Please take a moment and rate my answer
Nic
Feb 10, 2009 | Shuttle MV42N (SHUTMV42N) Motherboard
P4vmm2 v8.1 bios checksum error
Try to reset your Bios by remove the CMOS battery
if it's just same
you can to replace your CMOS chip in your board with the same type ( you can get it from useless or junk 'same type' motherboard)
Nov 05, 2008 | EliteGroup P4VMM2 V8.1 Motherboard
Power wont turn on with M957G mobo
try and check the manual you will see the picture there thanks
May 16, 2008 | Pc Ware PC CHIPS: PC-Chip M957G...
AN35N Ultra MoBo doesn't boot.
hi,
First  u check the k/b numlock status  if it is glow (on/off ) while pressing numlock, motherboard giving display but  ur display adaptor giving problem.
Change the vga adaptor and  try it
Thanks
Was this soultion helpful ? show ur appericiation for it
Mar 21, 2008 | Shuttle AN35N Motherboard
No sound from speakers anymore
Open your controll panel & open Sound & audio devices. Click the Audio tab. Is there a audio device listed? Click on the Voice tab, is the same device listed there? Next open the System icon click on the Hardware tab than click the device manager button. Scroll down to Sound, video & game controller. Do you see a yellow ! point? If you did see a device listed in both Audio & Voice. That is OK. If you saw a yellow ! in device manager. Reinstall your audio software from youe motherboard CD. Lastly try another speaker system. If still no sound than your intergrated sound chip is defective. RMA the board through ASUS it has a three yyear warranty. You can call tech first and get a case number at 812-282-2787. Than ask to be transfered to the RMA dept.
Jan 04, 2008 | ASUS A8N32-SLI Deluxe Motherboard
Shuttle ae22
u need da manual for this board? let me know the full name + model number of ur board!
but still some r listed if they r helpful so well n gud if not so reply me
http://www.oempcworld.com/PDF/Shuttle.pdf
http://meyersrv.tripod.com/shutlmap.pdf
Nov 15, 2007 | Shuttle Socket370 AE22 (MBAE22)...
Computers & Internet Logo
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
