The problem is likely in the high limit cutoff...to get the parts you will need to call Lasko directly so I would confirm that with their tech dept. when you order the part....
here is the info for Lasko
heatman101
I just fixed my Stanley Lasko 675900
FOR GOOD and would like to tell the world how to fix it!
1. Remove the front plastic grill.
The bolts are torx heads with a center pin. You may be able to find a
torx head driver with the center pin but I improvised. I Used a
dremel tool with a small rounded diamond bit to grind the center pins
out of each screw so I can use a standard torx head driver on the
screws.
2. Remove the heating element. These should be Phillips
screws.
3. Blow out the dust from the back side of the heating
element. (be careful with the fragile fins)
4. put it all back
together and it should work just fine.
5. (optional at your own
risk!) I believe the small gadget attached to the top of the heating
element with the white wire is the limiter. You can use pliers to
slide the unit out of the element and either move the unit further
toward the center area, or cut the device out completely with wire
cutters and then splice it back together. If you do this REMEMBER TO
CLEAN THE BACK OF TH HEATING ELEMENT EVERY MONTH TO PREVENT A DUST
FIRE!
I hope this work for you and good luck!
There is still dirt in element and fan, try compressed air and blow out lint until no more dust comes out of unit. If still shuts off, it is tripping high temp thermal protector.
