Question about Panasonic KX-TG1033S Cordless Phone
Ringer ID, editing a caller 's phone #
How do i set ringer I D
why do need to editing a caller's phone #
    Problem Solver:
  • 12 Answers
See caller ID section on this Manual
You can edit the caller number if you are connected to a PABX system and require prefixing for outside lines, you can also remove area codes if you want to return a call just using the local code without the area code
http://service.us.panasonic.com/OPERMANPDF/KXTG1032.PDF
Posted on Jul 15, 2008
How do I turn the ringer on, on the handset?
Press program/mute button to confirm and you may program the following items: Set Language, Handset Name, Ringer Tone, Ringer Volume, Message Alert, Ring To Answer, Security Code, VIP Melody, Key Tone, Audio Predial, Vibrate Ringer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
Ringer Volume
From the Handset Setup Menu:1. Press the caller ID-volume ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press program/mute button to enter the menu. SET RINGER 1HI 2LOW 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2or 3, or use the caller ID-volume ( 6 or 5) button to scroll to your selection. HI is the default setting.
4. Press the program/mute button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
NOTE: If you turn the ringer OFF, the ringer off icon shows in the display.
May 27, 2016 | Uniden Cordless Phone
My t7316 is no longer ringing at my desk or showing the caller id
You can set the ringer volume by using Feature *80 and use the volume control to change the level. If this does not get your phone to ring again, then the line assignments will need to be reprogrammed.
Mar 19, 2013 | NorStar T7316 Corded Phone
My phone ringer is off and I don't know how to turnit on
You may follow the steps below.
2. Press mute/program button to enter the menu. SET RINGER 1HI 2LO 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2 or 3, or use the caller ID-volume
4. Press the mute/program button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
May 12, 2011 | GE Lands Phones
VIBRATE STAYS ON
Follow the below instructions and you can remove the vibrate state. I have included a link to download the phone's manual as a PDF file.
Sound Settings
Ringer Types
Ringer types help you identify incoming calls and messages.
You can assign ringer types to individual Contacts entries,
types of calls, and types of messages.
Downloaded Ringers can be downloaded right to your
phone.
Preprogrammed Ringers include a variety of standard
ringer types and familiar music.
Vibrating Ringer alerts you to calls or messages without
disturbing others.
Selecting Ringer Types for Voice Calls
Your phone provides a variety of ringer options that allow you
to customize your ring and volume settings. These options
allow you to identify incoming calls by the ring.
To select a ringer type for voice calls:
1. Select Menu > Settings > Sounds > Ringer Type >
Voice Calls.
2. Select With Caller ID or No Caller ID.
http://downloadcenter.samsung.com/content/UM/200708/20070824101259031_sprint_m300_ug.pdf
Mar 19, 2011 | Samsung SPH-M300 Cellular Phone
If I turn off the ringer does this also turn off caller ID?
Turning off the ringer won't affect the caller ID display. All that happens when you turn off the ringer is that the phone doesn't make noise any more. The ringing signal and caller ID information from the phone company still will reach the phone.
Oct 29, 2010 | Avaya 700340193 Corded Phone
Set call rings
From the manual:
1. Press the CALLER ID-VOLUME ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press mute/menu OK button to enter the menu. SET RINGER LEVEL 5 shows in the display.
3. Use the CALLER ID-VOLUME ( 6 or 5) button to scroll to your selection. LEVEL 5 is the default setting.
4. Press the mute/menu OK button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
Apr 26, 2009 | General Electric 28811FE2 Twin Cordless...
KX-TG6052 two handsets. Can't get Talking-Caller ID to turn off!
to turn the talking caller id off go to the menu press 0 then * then 4, then press 0 again to select off.
to turn the ringer on the handset back on, go to the menu, prees 1, 1, then press 1 for a low ringer, 2 for medium and 3 for high.
Mar 15, 2008 | Panasonic KX-TG6052B Phone
Ringer id
If you have an SD card it might be stored there. You might have to copy or move it to the phone storage from trans T-flash.
May 03, 2007 | Motorola Mobility RAZR V3
Change ring tones
TXgrl, To change your ringtone, try the following: 1. Press Menu 2. Goto and select settings 3. Goto and select ring styles 4. Goto and select style detail From there you should be able to find the ringtone option and you would select that to see other ringtones to select from. Also, your phone does have capabilities of having individual ringtones for different callers, but the contact has to be saved to the phone and not the sim. To change the contact from sim to phone, try this: 1. Goto Menu 2. Goto and select Phonebook 3. Goto the contact you want to save to the phone and press menu 4. Goto and select edit 5. In edit, there should be a option saying, "Stored", if it's saved to the sim, it will say sim, select edit or press left/right and it will change it from sim to phone. 6. When saved to phone, some options should appear. One of them is ringer id. 7. Select edit on ringer id and that's where you'd select the ringtone to use for that contact. If you have any questions, please feel free to contact me. Let me know how it works out. thanks. John
Jan 03, 2007 | Motorola Mobility V220
Panasonic KX-TG1033S Cordless Phone Logo
191 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
