Question about Motorola Mobility MOTORIZR Z3 Cellular Phone
Memory card my memory card used to stop working but is now not acceptd by the phone, I tried re formating to Fat 32 type but this just apeared as un formated to the fone, i then tried reformating as a FAT using both the phone and my pc and the phone says "memory card conected" when i select safely remove hardware, but then when i disconect the cable it says " memory card removed" there is no way it has physicaly moved however, after restarting the phone it just believes not to have a memory card atall can u help? thanks guys
  • pinkttrez Aug 28, 2008
    My Memory Card Slot got slack while trying to take out the Memory Card but works fine should I get assistance or leave it
    Brigadier General:
  • 7,752 Answers
You should reflash the phone
Posted on Aug 28, 2008
My lg pop wont read the memory card , and my other phones all read the memory card, no matter what memory card i insert to the lg it says" format memory card" then i do and still nothing, could...
I had the same problem with an HTC Aspire ( I think that's what it was called :} Anyway I formatted the micro SD card in fat 32 through my laptop using a micro sd to sd adapter and the sd card slot on my laptop. I then stuck the micro sd card back into the HTC and it worked. I heard formatting through another phone works too. Try it and let me know.
Nov 07, 2011 | LG GD510 Cell Phone
In Phone show error "memory card corrupted" &
1) Insert your card in the mmc reader.
2) Find the drive in which it is inserted from your pc.
3) Right click the selected drive and select FORMAT but NOT quick format.
4) Now, in the file system selection part, select the file system to be FAT and not FAT 32 or NTFS file system.
5) Start formatting.
Nov 03, 2011 | Nokia 7610
How do i fix format error C:13:01 from my sony memory card
CHANGE U R FORMAT MEDIUM FROM, FAT TO FAT 32....IF IT IS ALREADY IN FAT 32 THEN CHANGE IT TO FAT AND FORMAT.....
Feb 25, 2011 | Sony 1GB Memory Stick PRO Duo Memory Card
Helo dears i am a ripairman an s3600 has memory problem it donot recognize memory pls help me
hi i take it your talking about putting a memory card into the phone, what you need to do is try formatting the memory card into fat or fat 16 or fat 32 then try it again in the phone, if that fails you will need to get samsung pc suite and format it that way the phone wont recognise it if its in the wrong format
Jan 23, 2011 | Samsung S3600 Cell Phone
My phone is Samsung m620,I used 2gb memory card when I tried tranfer music from other phone to mine it said memory full while it is empty. It does not has songs at all. Ineed help please.
Your memmory card will be in FAT 32 format.You have to change the memmory card format to NTFS.Remove the card then connect the memmory card with memmory card reader and select property to format it
Sep 27, 2010 | Cell Phones
My Nokia N70 Memory Card Corrupted, Can I repair it
First, reformat your phone. Go to SETTINGS-Phone-General-Orig.phone settings. then type: 12345.
Be sure to remove your memory card, before doing it. And then, using a card reader, format your MMC on your computer. Right click the Memory Card Drive on MY COMPUTER, then look for Format. Click it and be sure to choose "FAT". Do not quick format. After that proceed. Put back the MMC to your phone, and check if it's ok. It worked for me so as i type.
Apr 10, 2010 | Nokia N70 Cellular Phone
While inserting the memmory card my nokia 3010 classic mobile is not working.it gets switched off.with out the memmory card its working properly.why is it so?
sir updating your phone software may fix this problem or just hard reset your phone hard reseting code is *#7780# put this code on your phone`s keypad.if this doesnt works try this format code *#7370# put this on your keypad it will format your phone........and your phone work good......
Sep 10, 2009 | Nokia 3110 Cellular Phone
Sidekick lx memory card
hi there,
well it happens some time, if you want to format the memory card, the best way is to
take your memory card out of the phone
put it in all-in-one card reader
and format through computer
be sure you selete "FAT" option not "FAT 32" when format via computer.
put the card back.
hope it will do for you
Mar 26, 2009 | Sharp Sidekick LX Smartphone
Formatting Memory Card
You must format your mmc's as FAT.............not FAT32 or NTFS
May 23, 2008 | Nokia 6233 Cellular Phone
Sandisk adapter will not work using my integral mobile card reader i am trying to store music on to the disk and it wont let me transfer any data whatsoever please advise of a possible cause and solution...
is the device recognised by the system ?
This will be seen in My Computer, As F:/ G:/ H:/ I:/ Or Similar.
If this is present on your computer, try Formatting The Card/Drive.
You may get options of Format Type:- FAT/FAT 32/N.T.F.S.
Try FAT Or FAT 32.
Finally try selecting the items for transfer, highlight them select/all right click on the mouse,And select Send to F:/ G:/ H:/ et,c. Or try the traditional drag and drop, from desktop to memory card, once located.
also ensure that the card does not have a write protect tab.
If this is in the Lock position, no data can be written to It.
Mike @ compurepair.
May 11, 2008 | SanDisk 2GB microSD Memory Card
Motorola Mobility MOTORIZR Z3 Cellular Phone Logo
26 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
