Question about Samsung HP-T4254 42 in. Plasma Television
Blue haze on my plasma screen
A blue "haze" develops on my plasma tv screen but only on the left side going from top to bottom.
  • Anonymous Jul 14, 2008
    I have the same problem only on mine it seems that anything in the picture where light is (sunlight on water for example), is where the blue shows up. It is usually in the bottom left corner and along the bottom but can sometimes be right in the middle. A technician came out and made some adjustments somewhere in the back of my TV and it helped for about a week but now its back.
  • 44 Answers
The driver boards on that side of the set need to be replaced, about $400 for parts.
Posted on Jul 03, 2008
About two months ago my flat panel plasma tv
Most like likely, this is a panel issue and it will be too cost to fix.
Other things you can try, reseating the ribbon cables on the buffer boards located running across either the top or bottom or both. If that doesn't do it, replace those boards and still no luck. Panel is bad.
Feb 16, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
My zenith D52WLCD has a blue haze going diagonally
This a Normal Intensive Use Defects, this a Screen Burnout. Sorry
Oct 31, 2009 | Zenith Televison & Video
Purple-blue haze and line across my Mitsubishi wd62530 screen
hi this fault could be the convergance ic also the resistors and capacitors need to be checked, thanks
shaun
Jun 26, 2017 | Mitsubishi WD62527 62 in. LCD HDTV
VIZIO P42hd PS42a plasma Picture has two vertical lines (one red/orange, one blue) going down the right-hand side of the screen. Lines are clearly visible
The panel is almost certainly bad. The only fix for this is to replace the whole panel which would cost more than the whole TV.
Mar 30, 2009 | Televison & Video
Sony KDF50 rear projection TV with a Blue tinge (haze) on screen
You have a problem within the light engine. This a hugely expensive. If the set is not too old you could contact Sony and see if they will help you out. Otherwise it is not eceonomical to repair
Mar 30, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
I had the same problem, I had to send it back to Philips to get a $900 part replaced. Thankfully I had the warranty with it.
Aug 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
Blue haze on screen
blue haze on both sides of samsung plasma screen when goes dark or bright pictures. white lines on football ground appear blue???
Jul 06, 2008 | LG Televison & Video
Blue Haze comes out the left side of screen top to bottom about 3 or 4 inches.
What needs to happen is three specific voltages need to be adjusted on the power supply, You need to set the Ve voltage to 100v, the Vset voltage to 188V and the Vs voltage to 190v. Monitor the set for 24 hours, if haze doesn't come back the unit is considered repaired. If haze returns, then the problem is with the panel itself and wouldn't be worth it to replace because it will cost more than the tv cost you originally
May 21, 2008 | Philips 42PF9630A 42 in. Plasma Television
Plasma TV technical difficulty
if you can still see the picture its most likely the control board that's going bad, you will still need a tech out to fix the issue.
May 19, 2008 | LG 42PX5D 42 in. Plasma HDTV
Samsung HP-T4254 42 in. Plasma Television Logo
497 people viewed this question
Jerry Greenberg
Jerry Greenberg
