Question about Gateway GT5032 (827103078121) PC Desktop
GT5032 W/XP Media Edition
When I started the computer up, the light on the harddrive came on and is solid yellow. The turn on (power button) is blue and the lights for the DVD and CD are sporatically blinking green. I did not hear the one beep that occurs when the computer first starts. I have a blank screen. I unplugged the computer from the wall, held in the power button for 10 seconds, released then plugged back in. Power came on and computer started normally.
I was thinking it was in hibernate, so I disabled the hibernate feature, turned off the computer, and now it will not boot up. The fans are running and I think the harddrive is running, but nothing happens. The light for the HD is solid yellow. This time, I did a hard shut down. Once the computer was off I unplugged it from the wall, waiting about 10 seconds, and plugged it back it. I did not hold down the power button this time. The computer started automatically even though it was turned off before I unplugged it.
I can not find the power supply light on the back of the computer. I can't see where it's located. I can hear the fan on it running though.
I then opened up the computer, and removed all the memory sticks, and put them back in. I unplugged everything and replugged them back in, thinking maybe something was loose. I restarted, and no change.
If this is confusing, I apologize. It was running fine last night, and was turned off normally. We had no power surge or any outage and we do have it connected to a surge protector.
  • jj-thompson Jul 04, 2008
    Thank you Shakydogg. I did what you said, but it still doesn't work. I took the harddrive out and hooked in on my other computer, and it works fine, so I know the HD is fine.
    I turned off the computer, turned it back on, and get a solid yellow light. It always blinks while the computer is booting until this issue came up. Would you know what that is telling me?
  • jj-thompson Jul 06, 2008
    I decided to take in the computer to have it checked. I found out that the motherboard is shot. Just thought I'd pass that info along in case anyone else has the same issues I had. Thanks for the help though. I appreciate it.
    Problem Solver:
  • 17 Answers
Try unplugging and opening the PC and removing the mainboard battery. *It's about the size of a quarter, a little thicker though" Hit the power button about 5 times. (Mind you this will reset ther board to factory settings and you will have to go into set-up and set the time back) plug the pc back up and you may be in buisness.
Hope this helps!
Posted on Jul 03, 2008
I have a pininfarina simpletech 500GB usb external harddrive that does not show up in the My Computer folder of Windows Explorer. Tried hooking it up to a different computer with the same results; no...
If it is a new hard drive then it needs to be formatted. You can do this by going into your start menu - control panel - administrative tools - computer management - disc manager. I could be a little off on the wording as I don't have my computer handy, but in the disc management you should be able to right click on the drive in here and choose format. This will format the drive to be used. I hope this helps.
Sep 10, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
Dimension 3100 wont turns no power button light there is also an green light on motherboard cpu and power suplly fans working but wont bot up
Contact technical assistance.They will most likely ask you to send it back to repair.
This chart is where I got my conclusion.
Power Light
Problem Description
Suggested Resolution
Solid green
Power is on, and the computer is operating normally. On the desktop computer, a solid green light indicates a network connection.
No corrective action is required.
Blinking green
The computer is in the suspended state (Microsoft® Windows® 2000 and Windows XP).
Press the power button, move the mouse, or press a key on the keyboard to wake the computer.
Blinks green several times and then turns off
A configuration error exists.
Check the diagnostic lights to see if the specific problem is identified.
Solid yellow
The Dell Diagnostics is running a test, or a device on the system board may be faulty or incorrectly installed.
If the Dell Diagnostics is running, allow the testing to complete.
If the computer does not boot, contact Dell for technical assistance.
Blinking yellow
A power supply or system board failure has occurred.
Solid green and a beep code during POST
A problem was detected while the BIOS was executing.
See "Beep Codes" for instructions on diagnosing the beep code. Also, check the diagnostic lights to see if the specific problem is identified.
Solid green power light and no beep code and no video during POST
The monitor or the graphics card may be faulty or incorrectly installed.
Check the diagnostic lights to see if the specific problem is identified. See "Video and Monitor Problems" in your Owner's Manual.
Solid green power light and no beep code but the computer locks up during POST
An integrated system board device may be faulty.
Check the diagnostic lights to see if the specific problem is identified. If the problem is not identified, contact Dell for technical assistance.
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
Bought a new network hard drive 1tb iomega. Operating system requirements is XP. Saleman said it would update on line & work with windows 7. doesnot happen for me . Is it compatible or not? CD will not...
The drive will not update itself automatically. You will have to download the firmware update and update it yourself. You may also want to get the latest Manager software that is Windows 7 compatible.
Firmware Version 2.064: https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/std_adp.php?p_faqid=21149
Iomega Home Storage Manager (Windows) https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/std_adp.php?p_faqid=21688
The blue indicator light is the Drive Capacity LED - Displays drive capacity information without logging into the administration tool.
a) Off: Drive is below 70% full. b) Flashing blue: Device busy. Drive Starting up or shutting down. c) Solid blue: Warning! Drive is over 70% full. d) Solid orange: Caution! Drive is over 85% full. e) Flashing orange: Critical! Drive is over 95% full. f) Alternating Blue/yellow: DHCP Server Unavailable. Your Home Media Network Hard Drive was not able to get an IP address. Check the network connections and router settings.
The white indicator light is the Status/Activity LED - Indicates the Home Media Drive's power and drive activity status.
a) Solid white: Drive powered up and ready. b) Flashing white: Drive in use, transferring data (reading / writing). c) Solid red: Drive not ready/Drive Failure. d) Alternating white/red: Boot device not found.
Dec 06, 2010 | Iomega 1TB Home Media Network Hard Drive...
Myvu Crystal Media Viewer cannot turn on
You may need a 1000ma high capacity USB wall charger. If the light is not blinking, and it is solid yellow the computer or regular USB wall charger may not be strong enough to fully charge the glasses . It worked for me.
Jun 09, 2010 | Myvu Crystal Personal Media Viewer Made...
I have a Dell Inspiron 1525 that won't start. The battery light would flash orange 4 times then blue once, and then start over with the same sequence. Pulled the power board and fixed the solder joints on...
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
Dec 27, 2009 | Dell Inspiron 1525 Notebook
Hp computer. hard drive light is solid yellow pc non working
What has transpired is the power supply is bad. Electrolytic Capacitors inside have failed. These capacitors relate directly to the voltage power rails of the power supply. They are filters.
Little more detailed.
Your computer power supply converts AC electricity into DC electricity. (A flashlight battery is an example of stored DC electricity)
AC comes into input Electrolytic capacitors. Goes to a rectifier bridge, and on through various other components. Along the way, this DC voltage is considered 'Raw'. It needs to be a steady, 'clean', supply of DC voltage. There are Electrolytic capacitors used in the final stage, to convert the 'raw' DC to 'true' DC.
In a computer power supply the Electrolytic capacitors are the weakest link. They are usually the first component to go out.
You computer power supply converts AC voltage into three DC voltages. 3.3 volts, 5 volts, and 12 volts. These are the power rails.
When one, or more Electrolytic capacitors are weak, they make a weak voltage rail.
To simplify explaining the construction of an Electrolytic capacitor, let's just state they are small aluminum 'cans', and have a seal at one end, or both ends. Inside there is an Electrolytic paste.
This paste can break down, and when it does it forms a gas. (Hydrogen gas) This gas expands inside the 'can', pushes up on the seal/s, and makes Electrolytic paste ooze out.
So much paste loss, and the capacitor can operate in a weakened state. Too much paste loss, and the capacitor fails.
ALL the lights in your computer use less than 1 Watt. EACH fan uses 2 to 3 Watts. A harddrive just sitting there spinning, may use up to 5 Watts.
A processor uses 55 to 125 Watts! Depends on the make and model.
Since the power supply is to weak to provide enough power to turn the processor on, the harddrive isn't activated. It just sits there and spins. No Boot record on the harddrive is found, so no Operating System is going to be running. (WinXP is an example of an O/S)
This essentially means No computer! Harddrive activity light indicates yellow, then goes out. There is no harddrive activity.
No signal from the computer, because the computer isn't working.
Monitor stays in Standby, because there is no signal from the computer.
Power supply failure is 70% of computer issues.
Why?
Owner neglects to keep the inside of the computer, and the power supply clean. Doesn't use a can of compressed air for computers regularly.
Also there is another issue that the owner has nothing to do with.
Capacitor Plague.
http://en.wikipedia.org/wiki/Capacitor_plague
Solution? Replace the power supply.
I know the above info may seem like a 'Hard pill to swallow', but as stated. A weak power supply will still spin fans, and light lights.
Harddrive may spin, or spin up, then stop.
The processor isn't getting enough power.
Apr 12, 2009 | Sony VAIO Digital Studio PCV-RX540 PC...
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Hard Disk Problem
bad power supply from on and off so much change that out
are u on labtop tho then u may have to redo it may gotten bug run trendmicro.com see scan for bugs do windows upidate
Jan 26, 2008 | Microsoft Windows XP Media Center Edition...
Windows Media center recorded TV playback
Some possible causes can be system heat causing the video card to freeze. Sometimes it can also be related to the video driver or MPEG2 decoder. Make sure to use the right decoder and filter for the video playback.
Mar 06, 2006 | Microsoft Windows Media Center Edition...
Gateway GT5032 (827103078121) PC Desktop Logo
200 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
