Question about Amana Heating & Cooling
Just want to verify low voltage for 18 seer amana heat pump
  • 828 Answers
Control circuit voltage is normally 24-27 Volts from the transformer.
Posted on Jul 02, 2008
Amana furnace has turns on for a minute then off, it may stay on for a few minutes or seconds and repeats...we have heat, but blower is intermitten...what do i do???
You will need to verify that you have constant high and low voltage AT THE MOTOR. If the voltage remains constant and the motor still running intermittently then the motor is bad.
Dec 06, 2017 | Amana Heating & Cooling
Amana heat pump 13 seer split system when in heat pump mode once the thermostat is satisfied the head pressure on the high side shoots up to 600
410 a runs at a much higher pressure then r-22. that is still very high. it would take a temperture over 150 degrees to produce it on a idle system.
Feb 15, 2015 | Amana 3.5 ton 13 Seer Split Heat Pump...
I need the low voltage wiring diagram for this condenser model 10pjb24a01 weather king
That 10 seer heat pump is typically wired.
These were typically installed as the cheapest thing available to a homebuilder, mainly installed in rentals and affordable housing. Naturally, they cost the most to run. A higher efficiency unit will pay for itself in a couple of years and then save money every time it runs after that. Of course, replacement parts are inexpensive, so this is ideal for a rental property.
Jan 12, 2015 | Protech Rheem Ruud Weatherking Factory OEM...
Amana heat pump doesnt come on.
sooo many possibilitys. turn it to heat NOT EM HEAT. usually a low voltage issue. unless experianced i say leave this one to the pro's
Feb 19, 2014 | Amana Heating & Cooling
Dear Sir,I have an Amana Distinction 2.0 Ton heat pump, SEER 14 installed in my department about 4 months ago. I've noticed that the AC has a regular pattern running in the on/off cycle and that i
You need a tech. All 14 seer units have an X13 motor which speeds up and down on start up. A tech will adjust your tstat programing. Fan stays on after unit is done cooling to help drain water in cooling and cool off heat strips in heating,
Jun 15, 2013 | Heating & Cooling
Where is the reset button on an Amana ASZ14 unit?
I don't think the Amana ASZ14 Heat Pump has a reset switch, but you can still reset it by resetting the power (when it's not running... turn your thermostat OFF first).
To reset the power, locate your circuit breaker box. There should be a double-breaker for the Heat Pump and another double-breaker for the Air Handler. Turn them both off for at least 2-3 minutes. Then flip them back on and turn your thermostat back ON.
You're thermostat may also have a RESET button that you can push. I have to reset mine every time I change the batteries in it.
Here are some more repair tips...
Heat Pump Troubleshooting & Repair:
Heat Pump Troubleshooting Repair
Amana ASZ14 web page:
ASZ14 Heat Pumps
Amana ASZ 14 SEER Technical Manual
(45-page PDF):
Amana ASZ (and ASX) Service Instructions (66-page PDF):
Jan 11, 2011 | Amana PTH123B25AJ Heat Pump Air...
Amana Ultron 12 seer home air condition stopped working got electric to unit. checked out side fuses/ok. can anybody help. unit is only 2 yrs old.
Check low voltage or your control voltage. If your transformer is bad this will cause the unit not to work.
Aug 05, 2009 | Heating & Cooling
verify that the contactor rely is closing. if not possible low or high pressure switch has tripped. some are push button resetable some not. does the outdoor fan run?
Sep 16, 2008 | Amana PTH123B25AJ Heat Pump Air...
1997 Amana 2 or 2.5 ton heat pump, 13 seer - air handler only blows 4-5 min
do you have a totaline t-stat. they and some other brands have a fan recirculation setting in the installers menu.
this is assuming that this happens in addition to the heating or cooling normally
Jul 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
37 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Shehu Pro
Shehu Pro
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
