Question about Acer Computers & Internet
We're using an Acer 40x max tower, and using a cat5 cable for the internet. The problem is that we can't find the cat5 port on the tower.
    Problem Solver:
  • 17 Answers
Cat5 or ethernet port is a oversized phone jack to put it simply. You may need to purchase this PCI ethernet card and install it of you do not see it installed.
Hope this helped!
Posted on Jul 03, 2008
HDMI cable connects to monitor but not to tower
HDMI cable has a specific design for specific purposes, if your tower is supposed to be used through a different port, use it, the other device is the one that will have to adapt to it. An "HDMI to other port" wire shouldn't exist, since it wouldn't bring the advantages of an HDMI wire.
Sep 14, 2015 | Acer Computers & Internet
Acer aspire 5335 connects to wireless internet, but not with eathernet cat5 cable?? thanks
Make sure the Network Connection for the LAN is not disabled. Click Start/Control Panel and look for the Network Connections. Make sure the Network Connection for the LAN is not disabled. if it is disabled, right click on it and select enable.
Also the port could be bad on the computer. If it does not light up when you put the cable in the port might be damaged.
May 01, 2012 | Computers & Internet
Where to contact pc speaker in compaq despro
Look real good in the motherboard with a flashlight and normally you will see a port label SPKR. The cable will only fit in the speaker slot so you don't have much to worry about. Normally this cable runs from the back of the CD/DvD drive to the motherboard.
Apr 03, 2012 | Compaq Deskpro EP - Celeron 500MHz/128KB -...
Setup belkin wireless network
1.Connect a Cat5 cable into the Ethernet port on the back of your cable or DSL modem. Plug the other end of the cable into the "Connect to Modem Internet/WAN" port on the back of the Belkin Router.
2.Connect a Cat5 cable into the "Ethernet" port on the back of any desktop or stationary computers and then plug the other end of the cable into one of the LAN ports on the back of the Belkin Router. Start with port one and work your way up with subsequent computer connections.
3.Turn the Belkin Router on by plugging the router into a power outlet. Allow 30 seconds for the router to fully boot up. All computers tethered to the modem via a Cat5 cable have access to the Internet.
4.Open the Wi-Fi Wizard on your laptop and turn on the Wi-Fi antenna. Once turned on, the Wizard finds all network connections in your area. Connect to your network to establish an Internet connection. Complete this step for each computer not tethered to the Belkin Router with a Cat5 cable.
Thanks for using Fixya
Proton
Oct 04, 2010 | Computers & Internet
I have 2 buildings about 500 Ft apart connected with 2 conductor telephone cable, formerly used for a radio tie line. I would line to connect to the internet from the other building.
326 feet is a max run for cat5/cat5e cable. You would need a repeater for runs longer than that. Wireless will not work properly either without a singal repeater. You could look for outdoor repeaters and run a drop line to the 2 building but this will be costly
Feb 14, 2010 | 2wire (1000-400108-001) Router
How do I hook up a Berklin wireless router to my comcast internet
Use an Ethernet cable to connect the port on the Comcast modem to the WAN port on the Berklin (Belkin????) router.
Use another Ethernet cable to connect one of the LAN ports on the router to the Ethernet port on your computer.
Start Internet Explorer on your computer.
Connect to the web-interface inside the router.
Run the "network setup wizard".
Run the "wireless setup wizard".
Nov 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Phone to Cat5e cabling - How do I wire the wall plate
Wire your phone box using your Cat5 cable, use 4 wires instead of 8 wires of Cat5.
Nov 20, 2008 | Cat5e Unshielded Twisted-Pair Patch Cable...
CAT5e
The max distance that Cat5e or Cat6 can be run is 90 meters or 295 feet. As cnavarro stated, signal repeaters would be best utilized in your situation up to 590 feet otherwise fiberoptics are the next and more expensive route. You should also divide the run equally with the repeater as it would not be effective with an offset balance.
Sep 14, 2008 | Cat5e 100 Foot Shielded STP 350mhz Network...
Computers & Internet Logo
71 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
