Question about HP DeskJet F380 All-In-One Printer
Hello : i have a sever problem - 0x8010003
My plotter is HP design jet 500
  • 61 Answers
Please can your problem in detels
Posted on Jul 21, 2008
I need solution on this Problem, HP DesignJet 500 Plus Error: Severe Error: 0x8010003, Thanks Biar R
Turn off the power ->open the cover and manually move the Cartridge carrier to the middle of slider bar that's all , it will fix your problem. Most of the time it is due to friction in the slider rod so lubricate the slider rod if necessary. If the carriage is stuck at the right hand side of the printer and cannot be moved out to the center of the print platen it is because the service station cannot uncap the print heads. in this case replace the service station/aerosol fan assembly.
Feb 13, 2013 | HP DESIGNJET 500 InkJet Plotter Printer
Hp design jet 500 error code 5613?
System Error: 56:13
Problem
Description:
Error in the Drive Roller Encoder Sensor quadrature.
Corrective Action: Try the following:
Switch the Printer Off and wait a few minutes. Switch the Printer
On again and check if the Error Code has disappeared.
If the Error Code continues, replace the Drive Roller Encoder
sounds like the media motor encoder is dirty or has failed , there are videos on you tube on how to get to the sensor ,OR if your not up to it I would recommend Belmonte Business equipment as being much cheaper than HP to resolve your issue
Nov 29, 2012 | HP Hewlett Packard Designjet 500 42" Wide...
Hp designjet 800 ps plus system error severe errora: 0x8010003 task: tmech file: sequence.c line: 636
Notate the error and put it in a search. Since it appears to be a server error, remove then reinstall the driver software.
Jul 09, 2011 | HP DesignJet 500 InkJet Printer
Designjet 500 comes up with error code: severe error 0x8010003 and the belt looks slack. What can i do?
Called a service company who are going to fix it on a fixed cost visit to our premesis.
Oct 27, 2009 | HP DesignJet 500ps InkJet Printer
Document failed to print
http://www.hp.com/#Support
Follow the link and get the correct driver and get installed
Jan 06, 2009 | HP DesignJet 90 - printer - color -...
Plotter needs recalibration
You need to enter the service calibrations menu, to do this select the set up menu, once inside the set up menu press the up arrow & enter keys together. This will take you to the service tools menu, from here select service calibrations (printhead alignment and colour calibration are both in this menu). If you still here problems after you have calibrated your machine or the calibration fail replace the printheads.
Oct 16, 2008 | HP DesignJet 500ps (42 in.) InkJet Printer
HP Design Jet 600 Plotter
The problem the 'alignment error' this causes is car desalignment, is need repair phisical.
May 29, 2008 | HP DesignJet 1050c plus InkJet Printer
HP DeskJet F380 All-In-One Printer Logo
576 people viewed this question
Ben Johnson
