Question about Amana Washing Machines
Amana washing machine
When i turn the washing machine on and it fills with water, the water starts coming out the bottom of the washing machine when the wash cycle starts. What do you think?
  • 25 Answers
Prob faulty door seal or iff really bad hole in outer tub
Posted on Jul 03, 2008
My Amana washer model#NAH6800AWW will not fill with water during rinse cycle.
Check cold water coming or not if you can check volts check volts at fill valve . if power there . change fill valve
Posted on Oct 08, 2017
Apr 18, 2017 | Amana Washing Machines
Model NFW7200TW Washer wont fill with water
Are you sure you have both hot and cold water connected? Try turning the water valve on, if you don't have hot water make sure you choose cold cycle. That's the first place I'd start.
Dec 02, 2015 | Amana Washing Machines
Clean filter washing macine
With any washing machine the filter is located at the bottom front and under flap unscrew plug.Beware water will come out.
Sep 27, 2014 | Amana Washing Machines
Machien starting
Is water turned on?? If so may be water valve faulty
Jun 15, 2013 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
The amana washing machine model lw6501w2 fills with water and starts agitating and spinning at the same time during the wash cycle. This causes the water to spill over the top and run out the bottom.It...
Sorry that does not sound right,,. there should be interlocks that stop agitating and spinning from happening at the same time. go to the dealer you bought it from and tell them and there may be a recall for your problem and they may replace your machine at no cost or low cost to you no matter how long you have had the machine,at least in theory..
Oct 19, 2009 | Amana Washing Machines
Amana washer won't fill with water
1st I checked the power, compressor in garage had tripped the breaker to the washer circuit. This model has no bells or whistles to tell you if the power is on to the unit. Reset the breaker and unit works.
Thanks FixYa
Dec 22, 2008 | Whirlpool AWM5125/1 Front Load Washer
Water in my washing machine
it sounds like you have a leaking water valve, you will have to replace the mixing valve, For now turn the water off at the wall suppling water to the machine. When you want to use the washer turn on water, when its done with the cycle turn the water off.
Note: unplugging the machine will not stop the water from running
May 13, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Amana washer
take the front panel off, two screws at the bottom of the front panel, probably a 5/16 nut driver will work. You will need a flash light. partially fill the washer with water and then turn it to spin.
Look up underneath the tub and see where the water is leaking from. If its coming from above the bearing you need a seal job.
Bearing, seal kit, not cheap, how old is the machine, time to buy a new one?
T
May 12, 2008 | Washing Machines
Washing machine will not stop filling
somewhere attatched to the tub/lower water hose is something called a pressure chamber- this will need cleaning out. its identified by a plastic/rubber tube leading from it to a higher switch/unit. in the first instance you can blow some compressed air down the tube to see if that helps. it seems that you may need to do more hot washes. remember isolate machine.
Jun 04, 2007 | Amana ALW780QA
Washing Machines Logo
104 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
