Question about Konka K2001UM TV
Konika k2073um tv how to remove a parental block
Hi I need help, for some reason the parental block must be on and I cannot get more than 3 channels. I no longer have my original remote contro and don't remember the code
/ How can I add more channels.
  • David E. Colglazier Jul 28, 2008
    I have a Konka k2001umt that when plugged in, goes to channel 3. No buttons on the front panel work so I can only use it as a switched monitor. Any ideas?
Posted on Jul 03, 2008
Remove child lock
See the instructions beginning on page 40 of this manual:
Jul 17, 2013 | RCA F32650 32" TV
I cant reset parental controls
Activated by a PIN number, you can set Parental Controls on your TV and/or cable set-top box to control the programs that can be viewed on your TV. There are three ways to block programs:
  • By Channel
  • By Rating
  • By Time Period (Not available in all areas.)
The V-Chip understands television program ratings and blocks programs based upon the rating level selected. All TV sets that are 13 inches or larger are required to incorporate the V-Chip technology. Parents set rating levels so that certain TV shows need a password to be viewed. For more information on the V-Chip and program ratings visit the FCC V-Chip site.
Several cable and satellite companies offer parental control options. They allow specific channels to be blocked so that they cannot be viewed.These companies also offer the ability to block shows based on language, violence, nudity, and rating levels. This offers more flexibility than the V-Chip.
Hope it helps ;-)
Jan 25, 2011 | Syntax LT20HVK 20 in. HD-Ready LCD...
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
You can set the following options to block
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
My tv has parental lock on it and I dont know the code could you help me
you can go into the menu of the tv and try to restore to original defaults or try 0000 or 1234, those are factory defaults, will work unless someone changed it but your parents blocked the porn channels for a reason.
Apr 06, 2010 | Sharp 27R-S50 27" TV
I have a toshiba standard tv 27A33. it has one
This television uses a feature called a V-Chip which allows parental control and consequently blocks channels of your choice. This set is approximately 7 years old and the owners manual is no longer available on line. You can over ride any blocked channel by entering the menu, select parental controls and enter the "secret" code. How one channel got blocked is a mystery. I suspect someone was exploring it's features when they accidentally blocked a channel. Normally the system control works flawlessly and if you have no other symptoms you need to reset that channel. That info is in the owners manual that came with your set.
Mar 30, 2010 | Toshiba 27A33 27" TV
Magnavox child lock help
hello The parental control menu enables
you to limit access to programs that
may contain objectionable material
or are not suitable for viewing by
children. The default access code is
The following table provides details
about the menu items:
Component Function Range / Options
Lock Enable
Enables the parental control lock. When
enabled, channels with objectionable viewing
content are blocked and can only be
accessed with a password. You can block
channels according to the movie or TV ratings
of the channel’s programs.
Off, On
Movie Rating Helps you block programs based on their
movie ratings. See “Movie Rating” on
page 25 for more details.
TV Rating Helps you block programs based on their TV
ratings. See “TV Rating” on page 26.
Change Code Changes the password for the parental control
Press the number keys to
change the password.
Reset Resets all channels and programs to their
default factory settings.
Parental Control Menu
Lock Enable
Change Code
Main Menu
Parental Control
Channel Setup
Press Right to Enter
Press New Code
Off On
TV Rating
Mar 13, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Child lock
From the main menu choose "Parental Controls;" it's option six.
  • Step 2 Choose the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK button on the remote, scroll through until the TV-MA rating appears. Press the right arrow button to move the highlight over to the "Status" field and toggle to "View." Press the OK button. This will set the age-based ratings to Mature.
  • Step 3 From the Parental Controls menu, select the second option, V-Chip Movie Ratings Limit and change the rating to TV_MA and the "Status" to "View."
  • Step 4 From the Parental Controls menu select the third option, V-Chip Unrated Program Block and select item one, which will be "View."
  • Step 5 Select the fourth option, which is "Channel Block." Highlight the Channel field and using the channel up and down buttons, go through and check they are all set to 'View." Any set to "Block" will need to be toggled back to View.
  • Step 6 Lock the controls to activate the changes using item six on the "Parental Controls" menu.
  • Nov 30, 2009 | RCA Mikomi 5290925 15 in. LCD TV
    Fpa lock on how do i get this offf
    hello Lock/Unlock Parental Controls
    Selecting this option lets you lock and unlock parental controls settings
    using a password.
    If you do not lock parental controls, none of the settings for V-Chip,
    Channel Block, or Front Panel Block will take effect.
    If you forget your password, press the MENU button, then select Parental
    (the password entry screen appears). Simultaneously press and
    hold CH+ and VOL+ on the front panel for 8 seconds. Parental Controls
    unlock and the Parental Control menu appears. You can enter a new
    password by locking the Parental Controls again.
    Front Panel Block
    Selecting this option lets you block (disable) or unblock (enable) the TV’s
    front panel. The remote still tunes to any channel. When using this as a
    Parental Control method, remove access to any remote that is capable of
    operating the television while you have the front panel blocked.
    Don’t forget to lock parental controls after you change the status. If you
    don’t, the front panel block will not take effect .if this don't work get back to me i've got manual good luck
    Sep 19, 2009 | RCA R52WH73 Projection Television
    Parental control codes
    Please state make & model of your tv set ?
    Dec 30, 2007 | Televison & Video
    Most of the stations are blocked!
    Welcome to the wonderful world of the vchip. Making better babysitters through tecnology. From what I understand the control if placed in a ram and cannot be reset without the password. I would call RCA and talk with a tech there might be a generic unlock code like on the old playstations. You may have to prove you are the rightful owner and over the age of 18.
    Jul 30, 2006 | RCA E13319 13" TV
    Televison & Video Logo
    161 people viewed this question
    Top Konka Televison & Video Experts
    Computer Repairing
    Computer Repairing
    Are you a Konka Televison and Video Expert? Answer questions, earn points and help others
