Question about GE Refrigerators
My temperature control panel will not light ?
  • dluehr Sep 24, 2008
    My GE Side by Side water filter indicator light came on so I replaced with a new water filter, now the whole control panel does not light up or work at all. The fridge is still working other than that???
  • 61 Answers
Do a Google search for "how to replace control panel light on ( fill in your make/model unit" ) you may get lucky. Good luck
Posted on Jul 03, 2008
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Temperature control panel
CHECK THE ON/OFF SWITCH ON THE INSIDE.
Jun 17, 2015 | GE Refrigerators
IF THE MACHINE START IT SHOWS FLASH AFTER 2min
test this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 22, 2013 | Dishwashers
Whirlpool quiet partner iii pots & PANS LIGHT flashing
test the steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
G1022
follow this steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jun 13, 2013 | Miele Dishwashers
Flashing start light
see this causes and fix it. God bless you
Drain Pump If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective YOU'LL need to replace it. Drain pumps are not repairable.
Heating Element If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced
Touchpad If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Check Fault Codes If the display lights are flashing and there is an error code in the display window, check the Error Codes guide on our website to determine which component has failed or is failing
Oct 03, 2012 | Dishwashers
We have a whirlpool quiet partner iii. It was working fine and was opened mid cycle. Then it wouldnt drain. Then all the lights started blinking. At some point it drained the water out. We flipped the...
see this causes and fix it. God bles you
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Oct 02, 2012 | Dishwashers
Selection Buttons on GE Cafe Dishwasher
How do I take the dash apart to change the blower switch on a 2001 Mustang? I can not find a diagram or maunual that shows how to do this, can you recomend?
  1. Disconnect the negative battery cable.
  2. Remove the control panel assembly from the instrument panel.
    A special tool, such as the one shown, is necessary to disengage the temperature control cable from the back of the control panel
    Temperature control cable component identification
  3. Carefully lift the lock tab to detach the temperature cable from the control door shaft.
  4. Note the cable routing, then remove the cable from the vehicle.
To install:
  1. Route the cable behind the instrument panel, then engage the alignment pins and attach the temperature cable to the control door shaft until the lock tab snaps into the groove on the shaft.
  2. If necessary, install the instrument panel.
  3. Engage the cable end with the cable actuator on the control assembly. Install the control assembly in the instrument panel.
  4. Connect the negative battery cable and check the system for proper operation.
  2. Remove the snap-in trim molding in the center console to expose the four control assembly attaching screws. Remove the four screws attaching the control assembly to the instrument panel.
  3. Roll the control panel out of the opening in the console.
    Exploded view of the heater control panel mounting
    Click to Enlarge
  4. Detach the temperature control cable from the control panel by using Ford Temperature Cable Disconnect tool T94P-18532-A, or equivalent, to release the side locking tube, and a small flat-bladed prytool to release the top locking tab. Pull the temperature cable away from the heater control.
  5. Remove the two mounting nuts, then separate the vacuum hose and wiring harness connectors from the back of the damper door switch.
  6. Detach the wiring harness connectors from the back of the blower motor switch and the light bulbs.
  7. Remove the control panel from the center console.
    To remove the control panel, first remove the trim cover and remove the panel mounting screws . . .
    . . . then disengage the locking tabs on the temperature control cable . . .
    . . . and detach the control cable. Detach all wiring harness connectors and remove the panel
To install:
  1. Position the temperature cable at the midpoint of its travel, directly between the H and C markings. Position the temperature control knob at the midpoint of its range, then connect the temperature cable to the geared arm on the blower motor wheel. Rotate the temperature control knob from maximum cold to maximum warm to verify proper range of motion.
    Prior to installing the temperature control cable, turn the control knob and the cable indicator to the mid-points of their ranges
    Click to Enlarge
  2. Install the electrical connector at the following locations: blower switch, control assembly illumination bulbs and damper door switch.
  3. Install the vacuum harness connector for the function selector knob and tighten the mounting nuts until snug.
  4. Roll the control assembly into position against the instrument panel and install the four attaching screws until snug.
  5. Snap the console trim molding into position, connect the negative battery cable and check the system for proper operation
Jan 16, 2011 | 2001 Ford Mustang
My oven light blew now my control panel on my stove doesnt light up but the burners work?
I have seen the control panel light fail while the temperature controller still operates. In many floor-standing stoves the control light is operated by a switch inside the temperature controller, so it can fail independently of the temperature control. The 'fix' is to replace the controller. The oven light blowing is more likely coincidental timing rather than being directly connected to the other fault.
Feb 28, 2010 | Kenmore Kitchen Ranges
Refrigerators Logo
99 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
