Question about HP Office Equipment & Supplies
Loaded the cartrridge in the printer when i closed the top the cartridge went to the right side and won't come back the printer keeps saying insert rirgt cartridge nothing is happening it won't slide back into place
    Genius:
  • 2,785 Answers
Plz resit the cartridge
Posted on Jul 03, 2008
How do i install mt inks
Please follow the steps below on how to install/replace ink cartridges on your model:
  1. Make sure the All-In-One is on.
  2. Lift the scanner unit until the scanner support keeps it open. The print cartridge carrier moves and stops at the loading position unless the All-In-One is busy.
  3. Grasp the tabs on the cartridge lids, and then lift the lids.
  4. Remove the old cartridges. Store them in an air-tight container or dispose of them.
  5. If you are installing new cartridges, remove the stickers and transparent tape from the bottom of the cartridges.
  6. Insert the new cartridges. Make sure the black print cartridge is secure in the right carrier and the color cartridge is secure in the left carrier, and then snap the lids closed.
  7. Lift the scanner unit and push the scanner support back while lowering the scanner unit until it is completely closed.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Aug 30, 2011 | Lexmark X1270 All-In-One InkJet Printer
Tip
How to change toner in laserjet printers
First Turn the printer's power off. Some power button is located on the control panel on the top of the printer, on the right side. Open the printer's top cover by pressing the top cover lever, which is located on the bottom side of the top cover. Lift the cover all of the way open. Locate the toner cartridge. It will be right in the center of the printer and has a handle on the top of it. Grab the handle and pull the cartridge out. Hold the replacement cartridge at its side and gently rock it back and forth. This will help to distribute the toner equally throughout the cartridge.Remove the paper cover from the top of the cartridge.Insert the replacement cartridge into the printer and close the printer's top cover.
on Mar 31, 2010 | Office Equipment & Supplies
How do i change my lexmark x4650 print cartrige?
Installing/Replacing your ink cartridges:
1. Open the printer, and then press down on the cartridge carrier levers. printmastert_52.jpg
2. Remove the used print cartridge or cartridges. 3. If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid. 4. If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid. 5. Close the printer.
May 15, 2011 | Lexmark X4650 InkJet Printer
Lexmark 7600 printer cover is not seating properly after installing printer cartridge
The two hinges are attached to the back of the printer by two screws. I removed the two screws and lifted the top off, freeing the two hinges (the one on the right was broken so part of it stayed in the printer). There is a restraining line on the right side that keeps the top from coming completely free of the printer, but it can be worked around while still attached. I removed the broken pieces and the internal spring from the right side hing. The spring is what was keeping the top from seating correctly. I assume you could order a new hing, but I reassembled the printer without the spring and the top seated properly. The printer works, but I will now need to be very careful when replacing the ink cartridges because of the missing hing on the right side.
May 10, 2011 | Lexmark International Lexmark 7600 Series
How do i insert cadrige
Turn the orinter off and follow these steps:
1) Remove the top cover by opening the top of the printer
2) Pull the older tone cartrige out, taking care of noticing how it is inserted into the printer.
3) Insert the NEW cartridge
4) Close the printer cover
Mar 31, 2010 | Samsung ML 2010 Laser Printer
Unable to remove black cartridge, it is really stuck. Help
I just changed my black toner this past week, and finally figured out why the cartridges get stuck like this.
First, you must eject the toner cartridge on the front-panel menu:
Menu->Replace Toner->Eject Toner->Black(K)
It will say "Rotating to Black Toner(K)" and then say "Black Toner(K) Ready to Eject"
Now, open the front panel and you'll see the black toner cartridge in front. You can also open the top panel if you want more light on your work area.
Lift the lock handle on the old toner cartridge to the "unlock" position, and here's the part that the Dell instructions don't have:
There are two channels for the toner cartridges -- one on each side. Run your finger down the channel on the right, and you'll feel a small, spring-loaded catch. This catch often gets sticky and won't release the cartridge without some help. Don't force it, but gently move it towards the back of the printer and it should release.
Now the old cartrdige should slide right out, and you can finish per the instructions that came with the new cartridge.
Jan 27, 2010 | Dell 3100cn Laser Printer
I keep getting a message saying Install a color print cartridge on right side. There is one installed and I have tried changing it but it still won't recognise that one is there.
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
Aug 19, 2009 | Lexmark P6350 All-In-One InkJet Printer
Ink cartrridge
its very siple.lift the front cover of the printer.then insert the cartyridges in the printer a carriage will automatically come into the position where you can insert the cartridge.just keep the printer ON.AND LIFT THE COVER.ALSO where black is inserted there it will be written B.and where colour is inserted there it will be written C.as the circuit of the cartridge should nmatch the circuit in the printer.and slowly push the cartridge in the cartridge holder the carriage.as when it gets fitted you will hear a noise click.
Feb 26, 2009 | Canon PIXMA MP190 All-In-One InkJet...
My HP1310 all in one fails to recognise the color ink cartridge. It says insert ink cartridge. We havwetried reinserting the ctg turning it onn and off , puulling the power plug etc. All get the same...
I am assuming you are using hp 27 and hp 28 ink cartrridges.
Try this:
1. use a eraser, and erased the circuit at the back of the cartridge. (Clean the oxidation of the circuit -- retry). Note that circuit on these cartridges can go bad.
2. If 1 does not work., try another cartridge that you know is good and if still fail you have a printer problem
Most probably you have a bad cartridge.
Oct 12, 2008 | HP Office Equipment & Supplies
Error code 1203
To determine whether this error is due to a cartridge failure or a hardware problem with the printer, do the following: Make sure the printer is powered on. Open the printer's top cover. The print cartridge carrier moves and stops at the loading position. Press down on the cartridge lever to raise the cartridge lid. Remove the cartridges. With the cartridges out of the printer, close the top cover. Power the printer OFF and then back ON. Check the operator panel to see if the 1203 error has returned or if a new message is displayed. If the message displayed is 1203, there is something wrong with the printer hardware. Please contact Lexmark Technical Support. If the message is Cartridge Missing, reinstall the cartridges into the printer. Insert the black cartridge in the left carrier. Insert the color cartridge in the right carrier. Snap the lids closed. Close the top cover. Check the operator panel. If the 1203 message is still present, you need to insert one cartridge at a time to determine which cartridge is producing the failure. With one cartridge in the carrier, close the top cover and check the operator panel. If the 1203 message is displayed, that cartridge is producing the error. If Cartridge Missing is displayed, the second cartridge is the defective item. Please replace the defective cartridge.
Aug 20, 2007 | Lexmark P315 InkJet Photo Printer
24 people viewed this question
Ben Johnson
