Question about Intel Motherboard
Msi p35 neo2
i have a msi p35 neo, hd3850 graphics, 2gb corsair memory, maxtor 250gb HD, hiper 520W PSU.
1) when the mains supply is off and after turning it on, why does the computer start for a bit and then restart?
THE MAIN PROBLEMS
2) upon turning on the computer, the mother board beeps (2 short beeps). But everything is installed correctly and is recognised by BIOS (note windows is not installed yet)
3) Everytime before i enter BIOS, it shows for literally 1 second that hard drive can't be found before BIOS is loaded. But in BIOS, the correct hard drive and size is found.
the is my first build and im sure im being over cautious and paranoid.
thanks in advance!
  • kees ijpelaar
    kees ijpelaar Jan 15, 2014
    I have the P35diamond mobo, al from the beginning he did this, just one time when power was unplugged completely and replugged, now it do stop suddenly and restart 20 times or stay cycling on and off, maybe MSI has a solution.
  • kees ijpelaar
    Today I did smell something burning (cap smell) this little caps around the cpu I go replace.
  • 63 Answers
Take off all the stuff from the mobo except the processor, a stick of ram and the graphics card - will it get further now?
Posted on Jul 06, 2008
Msi p35 neo2 supports boot from pci express with revodrive 24ogb ssd?
Hello here is the home page:
http://www.msi.com/product/mb/P35-Neo2.html#/?div=BIOS
Why not connect to the sata drive ports ??
I have not heard about booting from pci express.
Pci express is a screen card slot.
Jul 07, 2013 | Computers & Internet
I was wondering if my pentium dual core E5700 would work in a msi p35 neo2??
It should work just fine - The Pentium E5700 is an LGA775 and so is the MSI P35 Neo2.
However, installing a processor into a motherboard is a bit more complicated than simply plugging it in, so I would consider having a professional install it for you.
Sep 16, 2011 | MSI P35 Neo2-FR/FIR (P35NEO2FIR)...
How would you know what type K8T Neo of motherboard you have mine just says K8T Neo
The manual is mostly the same.
MSI K8T Neo is also, MS-6702 (v1.X) ATX Main board. You'll find K8T Neo printed just in-between the first and second PCI slot.
In-between the second and third PCI slots you should see, MS-6702 ver 1.0 (Printed in white). All 5 models use the same chipsets. VIA K8T800 PRO Northbridge and VT8237R/Plus Southbridge. K8T Neo-FSR/ FIS2R Socket 939 use the same manual.
K8T Neo-V V2.0 uses a socket 754 CPU.
K8T Neo2-F V2.0 Also uses socket 754 CPU.
K8T Neo2-F-FIR Uses a socket 939 CPU
So open the link provided for drivers, bios ECT;
http://www.msi.com/index.php?func=searchresult&keywords=K8T+Neo&table=download
The most noticeable item is the SATA ports. From 2 ports and up to 4 ports. In different locations on the MB.
Did you find this helpful?
Mike
Jun 19, 2010 | MSI K8T Neo-FSR Motherboard
MSI K8N Neo V2.0 beep code problem is continous beeps.
That's usually a bad ram stick. Shut down the pc & remove one stick at a time starting with the one furthest from the cpu & work your way down to the first one. When it boots without the constant "beep", you found the bad one! You can also check www.msi.com & look in the support area for a solution if mine is wrong.(I'm never wrong though,lol)
May 16, 2010 | MSI K8N Neo Platinum, 601-7030-010,...
Hangs on testing base n extended memory
appears to be a RAM/Memory Problem.
Or Corrupt Bios.
Try swapping The Memory to different Slots, or try 1 stick in Individual Memory Slots. Also Ensure the Board Has the Correct Ram Installed i.e DDR/DDR 2 et,c.
Mike @ Compurepair.
Nov 06, 2009 | MSI P35 Neo2-FR/FIR (P35NEO2FIR)...
Problem with motherboard MSI P35 Neo2-FR
suggest not, if you really wan try, go ahead, but i suggest not.
Jun 05, 2008 | Intel Motherboard
P35 Neo2 fails to power up
try to clear cmos here is the way if u dont know:
get to the jumper next to the mainboard try to change its position for 3 seconds then put it back to its normal position.
start the computer , enter setup and save defaults.
May 26, 2008 | MSI Computers & Internet
Supported ram speed for MSI 945pl-neo f
Your motherboard MSI 945pl-neo support Supports four unbuffered DIMM of 1.8 Volt DDRII SDRAM.( Supports up to 2GB memory size.
• Supports dual channel DDR2 memory architecture.
• Supports DDR2 533/400 memory interface.)
and Supports Socket 775 for Intel® P4 5XX, 6XX, P4EE, Pentium D 8XX and Celeron D processors.• Intel® 945PL/ ICH7 Chipset
for more nformation see details od your motherboard here:
http://global.msi.com.tw/index.php?func=proddesc&prod_no=227&maincat_no=1
Dec 17, 2007 | Intel Motherboard
Intel Motherboard Logo
95 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
