Question about Mintek Televison & Video
I have a Mintek 10.2" portable dvd player (MDP-1070) and it has trouble loading dvds. It will either sit there and continue saying loading or else it will say "no disc" and I know it was placed in the dvd player correctly. In the beginning it didn't do this with all discs, but now it occurs with any disc I load. Is there anything I can do?
  • truckeesnow Jul 02, 2008
    I have already used a lens cleaner and didn't make any difference.
  • truckeesnow Jul 03, 2008
    I have a Mintek MDP-1070 portable DVD player. When I place a DVD in to be played it continues to say loading or no disc like it's not reading the dvd. I've cleaned the lens several times to no avail. I've already posted this problem once and was told the lens needs cleaning, but I've done that several times. Any other ideas?????
  • 161 Answers
The lens could be dirty, but it could also mean that the ribbon connecting the lens reader to the microchips inside the dvd needs to be replaced. That is a common problem here. The thin ribbon with wires that could be loose or needs replacement is connected to the moving mechanism that pops the cd in and out, usually located directly under the cd. It can be replaced by a technician, and is pretty cheap from where I come from.
Posted on Jul 03, 2008
    Guru:
  • 1,894 Answers
If lens cleaning does not work then the lens section is dead.
you will have to replace the whole lens section.
but instead of investing so much in that player i think you can go a new one.
now a days Players are very cheaply available.
  • 2,071 Answers
You are already use the insertible cleaners like CD/DVD it cleans while playing,actually that cleaners has a brush on it and it will wipe the dust from the lense but nothings happens it won't works.
The problem of your player is in "rail roller bars"the old grease there is hardened already due to accumulated dust,this is the most common problem, error in reading because the lense set assembly is jumping or cannot reach the microswitch button ,to switch on to play the player, that's why cannot play..
You better clean that rail roller bars by brushing,use old tooth brush and a lighter fluid or alcohol to take old grease. When finish cleaning the bars ,put a little amount of type -A grease. Rail roller bars is under the tray where moving assembly moving on it back and forth bringing the lense set.When brushing don't forget to cover the lens with little paper or plastic to protect the lens .Wipe the lens with cotton buds with very little amount of plain water after that then wipe it dry cotton buds ,try this solution ,so your player will work better again....
Posted on Jul 02, 2008
  • Mintek Master
  • 13,433 Answers
The lens may be dirty, have you tried using a dvd lens cleaner disc
heres one for example
http://www.amazon.com/Maxell-DVD-LC-DVD-Lens-Cleaner/dp/B00000JPPI
if a cleaner disc doesn't fix the problem there may be damage in the optics / lens or too much dirt / dust on the lens to clean with a disk.
If you still have warranty on your product please contact your dealer or mintek directly for service.
If you are out of warranty seek a local repair man. The lens may need to be replaced.
Let me know if you need anything else or have any questions
Thanks,
Ekse.
  • Ekse Jul 03, 2008
    Your lens may be faulty or broken, you have to take it in for service then.
    Sergeant:
    Champion:
  • 347 Answers
Hello Truckeesnow,
Your DVD isnt reading the CDs propably because the lense is dirty.
That is a very common problem with all the DVDs.
Try to clean the lense of your DVD either with lense cleaner, or with some soft loth, or toilet paper.
  • 2,326 Answers
I would suggest to try using a lens cleaner and see if that restores the functionality. If the lens cleaner did not work, the lens could be becoming defective and it should be replace.
3 Suggested Answers
SOURCE: Backlight problem with a Mintek Portable MDP-1070
paper black &lines
Posted on Mar 12, 2010
  • 16 Answers
SOURCE: I need to know where
http://www.amazon.com/Dvd-1710-Dvd-5820-Dvd-5830-Dvd-5861-Mdp-1810kit/dp/B001R2ERFY/ref=sr_1_1?ie=UTF8&s=electronics&qid=1298859822&sr=8-1
Its $12.75
Posted on Feb 28, 2011
Problem with Mintek MDP-1810 Portable DVD Player that will play movie DVDs but not computer burned video DVD
The problem I think is with the burner on your pc. Try re burning on another program like Nero and pay attention to the options. It will ask you if you wish to play disc in all types of players.
Dec 25, 2013 | Mintek MDP-1810 Portable DVD Player
I was given a mintek dvd player model mdp-1770 it is say no disc when there a dvd in it i have tryed recalbreting it by sliding back forth four time then loading a cd but it still reads no disc
If the unit plays CDs but not DVDs, then the LED for DVDs is burned out. There are separate LEDs for CD and DVD operation.
If neither plays, there is a more fundamental problem. In any case, only factory service will correct the problem with your "white elephant".
I have exactly this model.
Oct 07, 2009 | Mintek MDP-1770 Portable DVD Player
Won't play some DVDs
ya try cd lens cleaner ok they sell at store its a cd with litte brushes on it cleans lazor ok thx nick
Feb 11, 2008 | Mintek MDP-1010 Portable DVD Player
Mintek MDP-1070 dvd player
Ebay! But the MDP 1030 batteries were recalled so might want to think twice. Im returning my whole unit as it continues to not read dvds.
Jan 24, 2008 | Mintek MDP-1070
Televison & Video Logo
77 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
