Have a philips(model 55pp9401) 55 in screen.just had the color (guns/chips/moduals?)changed because the blue was warping the top of the screen,also had some burned transisters.seemed to work just great then i moved it to my sisters house,still great,then some hours later it just shut off.when powered up the light blinks red several times the nothing.
  • 8,617 Answers
Unplug the convergence yoke plugs all 3 of them and then see if the set powers up. If it does the troubles in the convergence circuits if it doesnt you likely have a problem with the LSB pc board. If you need more help let me know.
Posted on Jul 03, 2008
My Philips 51PW9363 looks like someone is pinching the screen in the middle from the top and bottom. No color, sound or other problems that I've noticed.
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Apr 22, 2009 | Philips 51PW9363 51" Rear Projection...
Philips 60 inch rear projection screen is wacky!!
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 10, 2009 | Philips 60PP9202 60" Rear Projection...
Just bought the Philips 9P6034C 60 in. rear projection, used. The picture is a bit hazy. The buyer told us that we just need to "have the guns put to it". Is there a special tuning device that the tv...
Your TV most likely has one of two possible problems.
  • Screen looks 3D
Mar 07, 2009 | Philips Magnavox 9P6034C 60" Rear...
Distorted Picture and High Pitch Squeal
You may have a convergence problem. Here are some of the most common symptoms and example photos.
  • Screen looks 3D
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Jan 31, 2009 | Philips Magnavox 51MP392H Rear Projection...
Blue color is ober screen
It may be the fluid in the CRT or convergence chips are bad.
  • Screen looks 3D
2c07611.pngSolution
Jan 30, 2009 | Philips 46PP9302 46" Rear Projection...
Red and blue gun not lined up
  • Screen looks 3D
Jan 05, 2009 | Sony KP-41T65 41" Rear Projection...
5yr old philips rear projecter tv color bad 50inch
  • Screen looks 3D
Dec 01, 2008 | Philips 9P5034C 50" Rear Projection...
Warping picture and color separation
The convergence chips and resistors need to be replaced. You can get a repair kit and photo instruction guide from www.TvRepairKits.com.
Sep 09, 2008 | Philips 46PP9302 46" Rear Projection...
2001 Philips 43P8341Blue outlines on images
  • Screen looks 3D
Aug 10, 2008 | Philips 43P8341 43" Rear Projection...
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Electro Med Services...
