Question about Sony Playstation 3 (PS3) Console
Blu-ray drive doesn't eject the game cd
Hi, I have a game cd that has got stuck in the drive, I have tried pressing the eject button for 20 seconds to do a hard reset, but to see no luck at all. Have done hard reset of the system as well (not the complete system restore though). Can you please advise the step-by-step walkthrough to fix that? Thanks a ton for this help
  • 1 more comment
  • deepsleo Jul 05, 2008
    My question was about the PS3 and not PSP
  • jojo08 Jul 05, 2008
    I have the same problem as deepleo
  • Anonymous Nov 16, 2008
    My ps3 have a Grand theft auto cd stuck inside, and when I eject it with the controller,or pushing the eject boton from the outside, the ps3 dos`nt correspond.
    Problem Solver:
  • 25 Answers
Shut it off open it the cover of it and look //// dont tuch any thing see if the disk is jamed in it if so there soude be two to four screws onthe top of the cover of the cdplayer device open it and take out the cd clean the area and put bake the cover ///// note every thing goes back the same way it goes on so// pay close attion to it when u take it off
Posted on Jul 13, 2008
I have tried stop and eject it does not open
CD slide is gear driven, gears are stuck. If any way you can give it a helping hand, such as grabbing and pulling with tweezers as you press eject might fix,
press the helpful button
Jan 30, 2016 | Televison & Video
Jvc dvd player won't open
when you hit the eject button try tapping the top above the disk drive. it may be somewhat stuck. if that doesnt fix it you might have a broken belt or a belt may have come off in it. the belt controls the movement of the drive in and out
Mar 21, 2012 | JVC DVD Recorder - VCR Combos: DVD...
The dvd drawer on my BD-HP16U is stuck in closed position. The screen display "hold" when I push the eject button.
Try inserting a small pin through the hole beneath the insertion cabin, after pressing the eject button. If you don't have such a hole, Push the eject button and tap hardly on the top of the player. The drive will come out in two or three attempts.
Apr 13, 2010 | Sharp AQUOS Blu-ray Disc Player
My samsung BD-P2500 Bluray player is stuck at a load message
First try disconnecting power cord for five minutes. On restart keep playing eject while the unit is starting up, to eject if there is a disk stuck inside.
Contact Samsung support number, listed on the owners manual. If a firmware update is available they will guide through the update.
If the firmware update does not fix the problem, then the BD player may have a defective or dirty lens.
Using lens cleaner can invalidate warranty, talk to Samsung first.
Dec 14, 2009 | Samsung BD-P2500 Blu-Ray Player
Dell xps m1330 dvd drive will not eject cd inside
Im a dell tech, and i hate those cdrom styles, but, that is what the consumer wants, so we make them. Try starting the machine, then press F2 to enter the BIOS. once in the bios, press the eject button. listen for any noises, (an attempt to eject). if you hear a sound, it means the drive should be capable of ejecting the disc, and perhaps the disc has not seated correctly. If the disc will not eject, you must contact Dell. This is from the DELL dcse site: " Optical Drive The XPS M1330 has a slot-loading optical drive instead of a conventional tray-loading module. There is no mechanical eject mechanism for the drive to eject stuck discs. This means you must replace the drive if a disc gets stuck in the drive. After replacing the drive, disassemble the old drive to remove the disc for the customer."
Jul 21, 2009 | Dell (0F146) Internal DVD Drive
DVD stuck in sony blueray player bdp s300
Step1There are a few ways to get your dvd/cd drive release itself. The first thing you should try is shut your equipment completely off for a couple of minutes allowing it to cool down. Once you turn it back on try to press the release button on your equipment. Step2If that does not work try to use a very thin flat tip screwdriver. Insert in on one of the sides of the dvd/cd drive and try to pull it out softly while pressing the eject button simultaneously. Do not force it out but give enough pressure while pressing the eject button. Step3More than likely inserting a screwdrive should release the dvd/cd drive. You can also try a butterknife as well just don't use to much force. Something else to check for is to make sure the power is acutally on for the device. If you are trying to open a drive that is not even on it will never open up for you.
Apr 03, 2009 | Sony BDP-S300 Blu-Ray Disc Player
press and hold eject button for around 15 seconds, it resets the cd drive, hope this helps
Jan 28, 2009 | Sony Playstation 3 (PS3) Console
I have an ACER 3003WLCi notaebook and there is a CD stuck the CD/DVD drive, how do I remeve the CD/DVD Drvie to remove the stuck CD.
Should be a small hole near button to open drive. Carefully take a paperclip and press slightly in hole. Should eject tray and and you can take disc out.
Be sure that power off and battery/power adapter removed.
Hope this helps!
Mar 24, 2008 | Televison & Video
PS3 Blu Ray Drive won't eject
open that **** up,have similar problem,mine was caused because of a sticker on a dvd, couldnt find my warranty,and force eject wouldnt work,i was afraid to open the bluray drive completely,just to the point where i could manually eject the disc and found a round sticky mark on the disc,the sticker is probably still in there,but keeping the ps3 horizontally seems to help,your problem however could involve with the thingies in the driver not being propperly alligned
Jan 20, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
47 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
