Question about Sony Playstation 3 (PS3) Console
Ps3 online hay i know alot of people have said this poblem but i feel i need to ask. well i cant seem to get my ps3 online when i try a connection test it says there is a dns error i know i put in the right dns number but it still wont work. please help. thank you :).
  • EmoNarutoFan Jul 04, 2008
    do you mean check it on my comp. or my ps3?
    oh i did that already and it dident help sorry, but thanks alot for trying =)
  • 344 Answers
When ever I get that problem it's the wirless router settings. Check the settings and make sure everything is set up right. Sorry, thats as much as I know about the DNS error on the PS3.
Posted on Jul 04, 2008
  • Wes Sydenstricker
    Wes Sydenstricker Jul 04, 2008
    You would have to check it on both. If you have a WEP secuity code on your router (which is recommended) it has to be entered into your PS3 during the the network setup. The Wep code has to be entered EXACTLY as it shows you in your router setting or it still will not work. Hope this helps!
  • Wes Sydenstricker
    I would sugest you call Sony then. They may fix the problem for free, or over the phone! Good luck to you.
When i click find game for online game at call of duty the console write that connected with matchmaking server and thats it nothing so i cant play online.
Try doing a factory reset on the modem/router, also do a connection test on your PS3 and make sure that your NAT TYPE is 2 anything other than that will give you problems playing online. Let me know if you need help with getting your PS3 to a NAT TYPE 2.
N etwork
A dapter
T ype
Mar 23, 2011 | Sony Playstation 3 (PS3) Console
Had my ps3 for year and half now, never played online (80710102)
Ok first off create a psn account online via computer, this is free of charge. Then after that connect your ps3 via cable to your modem. turn it on and access network settings. Then select internet connection settings, select easy. After it is finished select test connection. Should this time out it means you have a faulty connector somewhere, try checking your cables and the ports on the ps3 and modem. But if it states connected, back out and go to network via your ps3 dashboard then select sign in and enter your account info from your psn account.
Dec 08, 2009 | Sony Video Game Consoles & Games
Need help getting online with 80gb ps3 using ethernet cable.
Try going to the settings, then network settings, and then go to internet connection test, and then push yes when prompted. If there is an error still then maybe your connected wrong or you need to call your internet provider and let them know what is going on. They will walk through it with you.
Nov 12, 2009 | Sony Playstation 3 (PS3) Console
Just wanted to know is there any way to get my ps3 online
try opening a portal from you router to your ps3, the router will shut down all the things it need to in order to play your games more efficiently. If that doesn't work try hard wireing your ps3 to your router. If your getting online on your ps3 wirelessly then try moving your router or your ps3 closer together.
Nov 08, 2009 | Westell Wirespeed VersaLink...
I cant join an online game on call of duty 4. when i click find game or try joining friends, it says downloading game...... i know it's not my internet conection because im fine with other games online.
It may sound crazy but alot of people may not be playing when you are or they are playing something else so the the computer(connection) is searching for some players for you.
Jul 28, 2009 | Sony Playstation 3 (PS3) Console
I cant get my ps3 to hook up to my internet
Use the PS3's Internet connection test under Systems Settings to determine if you've access to the web. If this test fails you will need to do the following:
1) Reset your DSL modem.
2) Once the cycle is completed, run the Internet Setup under Systems Settings within your PS3.
3) Follow the instructions you should be able to gain access to the web and online game play.
Nov 19, 2008 | Linksys WRT300N Wireless Router
Ps3 help
OK, so i just went through this whole deal and its actually not too hard, and i gaurentee you will never have to do it again...
1) hook your ps3 as a wired connection to your router, you may need to go buy a really long cable to do this if you cant move your router in distance.
2) connect it automatically through the setup and it should work fine and connect, if not then i think your fucked.
3) go to network setting > setting and connection status list, write down all the info you can which is shows.
4) unplug the LAN cable, and go back to wireless setup.
5) do a manual setup for IP settings, and type in all the info you have, but DONT type in a WEP or WPA... EVEN IF YOU KNOW YOU HAVE ONE (mine has one but i didnt need it, but if it doesnt work the first time then hell try your passkey)
6) click enter and test connection and it should work!!
hope this helps cuz i see alot of people asking the same question and i had to spend 3 hours figuring it out for myself.
Mar 12, 2008 | Sony Playstation 3 (PS3) Console
How 2 get online with my ps3
if u are already on the net you pretty much just have to plug it in test your internet connection from within the ps3 menu and then sign up to playstation network which is free. you may also need to adjust your modem/router settings eg
1 ip from dynamic to static
2 enable UPnP
3 Eable DMZ
Feb 22, 2008 | Video Game Consoles & Games
Ps3
You can only sign into your Playstation account if you are using your own user profile on the far left of the XMB.
Do a Network test to see if you can even connect to PSN. Go to Settings, Network Settings, and do and Internet Connection Test.
if your test doesn't show your NAT type as either 1 or 2 then your router is being to restrictive. Try changing some of the settings to allow the PS3 full access to the internet.
Dec 11, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
51 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
