Question about GE WPGT9360EPL Top Load Washer
Agitates forward but not reverse.
Maytag LAT8506AAE does not agitate in both directions. Can manually spin agitator clockwise, counterclockwise with some effort.
Please advise troubleshooting steps.
Thank You.
  • 25 Answers
Lower gear box coupling has sheared
Posted on Jul 03, 2008
Maytag A412.....will not agitate....cannot turn by hand,,,,,will go through spin cycle.....agitator not stripped
Thanks for choosing FixYa and welcome. If you have a washer that has a weak agitation or no agitation at all, here are some possible solutions. You need to check your belts. Most washers have one or two belts. Check your lid switch. If a lid switch is bad, it can cause the washer to not work properly. Sometimes, they will not work at all. Make sure you check your drive motor. The drive motor controls the spinning, draining, and agitation. Most washers have the reverse motor, meaning the shaft rotates in both directions, clockwise and counterclockwise. It is possible to lose one direction and not the other. Some washers have a clutch that controls the agitation. If it is bad or worn, it may prevent the agitator to work. Most of these washers come from General Electric. You could have a bad motor coupler. They are located on the side of the motor drive inside the washer. It is also possible that you have a bad transmission. Check the agitator itself. You could have a bad spline or two. The splin accompanies the shaft and allows the movement of the agitator. If you rule out all the parts above, you may have an electrical issue or an issue with the control board. It is very important to test each part and make sure it is getting power. If a part is not working and not getting any power, the power loss may be the reason that it doesn't work. You can test the current in the wires with a voltage meter.
Apr 16, 2011 | Maytag Atlantis MAV6260AWW Top Load Washer
My Maytag washer MAV 6457 wont agitate but spins fine
Thanks for choosing FixYa and welcome to the site. If you have a washer that has a weak agitation or no agitation at all, here are some possible solutions. You need to check your belts. Most washers have one or two belts. Check your lid switch. If a lid switch is bad, it can cause the washer to not work properly. Sometimes, they will not work at all. Make sure you check your drive motor. The drive motor controls the spinning, draining, and agitation. Most washers have the reverse motor, meaning the shaft rotates in both directions, clockwise and counterclockwise. It is possible to lose one direction and not the other. Some washers have a clutch that controls the agitation. If it is bad or worn, it may prevent the agitator to work. Most of these washers come from General Electric. You could have a bad motor coupler. They are located on the side of the motor drive inside the washer. It is also possible that you have a bad transmission. Check the agitator itself. You could have a bad spline or two. The splin accompanies the shaft and allows the movement of the agitator. If you rule out all the parts above, you may have an electrical issue or an issue with the control board. It is very important to test each part and make sure it is getting power. If a part is not working and not getting any power, the power loss may be the reason that it doesn't work. You can test the current in the wires with a voltage meter.
Jan 20, 2011 | Maytag Atlantis MAV6451 Top Load Washer
Maytag will agitate instead of spin
http://allrepairmanuals.com/maytag-washer.htm?model_number=MAV7901AWW
Please download, the above, service manual, use the troubleshooting procedures, you should be able to locate and repair your problem.
May 05, 2010 | Maytag Neptune Washer
My Performa PAVT920AWW washer will fill with water, but won't agitate. It will spin but has a funny burning smell.
might b motor fault or jammed gearbox.when motor turns one way it drains and spins, when it turns other way it agitates,might b jamming when it turns for agitate.try looking under unit and remove belt, then turn main drive pulley by hand clockwise then anticlock to see if it is jamming. turn power off first dont want any accidents.please reply to see how u go.good luck
Apr 08, 2010 | Maytag Performa PAV2200
End of wash cycle, no draining or spinning, but can move to rinse cycle and it agitates again, no spinning after rinse either
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The drain and spin functions are started when the timer advances to the spin mode.
The motor is reversible. When agitating, the motor spins one way, when going to the drain / spin mode it reverses.
Since the machine agitates, the problem points to the timer.
Sep 04, 2009 | Kenmore Washing Machines
Maytag SAV5910aww will not always drain. Fills and agitates fine but will go through entire cycle without draining. Will sometimes give end of cycle buzz sometimes not. If I am in the room and lift the lid...
"I have found spinning the timer back to begining of rinse cycle first helps". The timer only rotates clockwise; counterclockwise rotation can destroy it.
May 18, 2017 | Maytag SAV5910 Top Load Washer
Washing Machine agitates only
maytag front loader washing machinne the drum agitates but does not spin
Feb 10, 2009 | Maytag MAH6500 Neptune Front Loading...
Agitator
Now is the time for service before it cost you a lot of money, and headaches!
Try these guys!
Good service for me!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Jul 10, 2008 | Maytag Performa PAV2200
Waterpump won't pump and spin cycle won't start.
one of 2 things are happpening iether hte timer is not sending down the power to operate the pump , or switch is not closing correctly to allow power to the pump
Mar 19, 2008 | Frigidaire FWS833A Top Load Washer
GE WPGT9360EPL Top Load Washer Logo
142 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
