Question about Mitsubishi VS-55707 TV
Won't turn on
When you push the power button, the green Timer light comes on and there is a click noise and the light goes back off? could this be a fuse?
  • 2,071 Answers
Your tv parts is ok.only the solder joint is crack or cold thats why function abnormally,goes off and goes on, due to when voltage is there the solder is hot and connect the parts joint, when voltage extremely hot, due to prolong use it will disconnect the solder joint parts thats why you cannot see picture..its need to reheat the solder joint of all parts affected....power supply section ,,horizontal section,vertical section ..and to microprocessor ic section including jungle ic..
find a tv technician to do the works .in order to avoid high voltage shock this not cost too much because only reheating works....
Posted on Jul 03, 2008
    Sergeant:
    Champion:
  • 230 Answers
Try the hard reset method ,that is , unplug all the cables and then leave the tv for half an hour and then replug all the cables and then switch on the tv ,hope this will help ,and i think this is not due to fuse
  • balachander megavarnam
    balachander megavarnam Jul 03, 2008
    or there may be some discontinuity in connections, so check that and
    correct,if you have warranty then go for it,because repairing by own
    will void warranty.
My Mitsubishi hd1080 tv will not come on when i turn the power button on the green timer light comes on but the tv goes back off
The TV reset may help you. If the timer was set by accident many of these TV's that have the sleep timer have this problem. Try the factory reset initialization.
Nov 19, 2014 | Televison & Video
Mitsubishi medallion hd 1080
I would try the reset button in the front. Unplug the set push the reset and plug it back in.
Mar 27, 2014 | Televison & Video
Computer won't turn on
this is only a guess sally yoour PSU need to be replaced.
Apr 09, 2013 | HP Omni Pro 110 XZ822UT AllInOne
Hp desktop blinking green light won't come on
mine does that when it's in stand-by mode. I just push the power button and it comes on....
Assuming you've already tried that....push and hold the power-button down for 5 seconds and the power SHOULD go out. *IF* it does not, then disconnect the power cord in the back for 1min....then reconnect and try to boot. If it *DOES*, then do the same...unplug the power cord for 1min and reconnect and boot.
Tallon41
Sep 14, 2012 | HP Computers & Internet
Kindle Touch won't start
Bad battery, needs changed.
Nov 09, 2017 | Computers & Internet
I have a Sharp 32"
try checking the system for timer or sleep mode operation try to setting it off
Jul 16, 2011 | Sharp 25R-S100 25" TV
Will not come on it worked fine earlier.
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
May 17, 2011 | Sanyo DP42849 42 in. HDTV
Only have two wires to connect to
What timer are you installing?
Intermatic battery-operated timer with red, blue, black and green
Green connects to bare ground
Red is capped off.
Blue connects to one wire
Black connects to other wire
Push on-off button: if light comes on, timer wiring is correct.
If light does not come on, then reverse blue and black wires.
Other in-wall timers except Aube have red, black, white and green
Green goes to bare ground
Red connects to one wire
Black connects to other wire.
White: in back of electrical box are white wires twisted together and covered with wire nut. Connect white white to these other white wires.
If box does not have white wires described above, then connect white wire to bare ground along with green wire.
Push on-off or override switch: if light comes on, timer wiring is correct.
If light does not come on, then reverse red and black wires.
Dec 13, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Green timer light turn on tv turns off
Read the info from this link to see if that applies to your TV.
Jul 23, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi VS-55707 TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
