Question about Refrigerators
Hotpoint fridge freezer8496s.fridge wont chill,light on.freezer ok
  • mbherlihy Jul 03, 2008
    fridge light on freezer wont freeze, defrosted all inside. fridge side feels like it it running low or weak...hard to tell... also I hear a clicking sound every 5-10 minutes..... i have no idea what to do.
  • 61 Answers
Find a local appliance parts store..not a Sears etc...bring make/model/serial number etc...tell them what is happening and let them advise you. I recently had a problem with my Maytag stove not lighting and the guy at the local store knew exactly what the problem was...sold me the part and told me exactly how to change it myself....sure beats the big stores option of having a service guy show up for a minimum of 50.00 just to tell you that its gonna cost another 200.00 to fix. Good luck
Posted on Jul 03, 2008
  • 25 Answers
Its compressor relay. take off back cover. u will see compressor. (big black thing) little box with clip on it mounted to it. snap off clip w/ screwdriver. once inside gently pry off thing with wires connected to it. this is plugged into compressor. dont worry about wires popping off it needs to have a 3 in 1 installed on it anyway. shake that relay and if it sounds like theres pieces inside shaking around its bad
u may have a locked up compressor though in which case u need a new fridge
Where can I get a repair manual for a Hotpoint Fridge
First of all, the model number you gave is not complete. But check you defrost system in the freezer, when the refer section stops cooling, your evaporator in the freezer is possibly full of ice and the fan won't move air through ice. When the refer sections fails to cool, check for a fan in the freezer. If it works, you have a defrost problem and is occurs every 3 - 5 days. The unit should defrost once or twice a day. Good Luck
Apr 20, 2016 | Hotpoint Refrigerators
Hotpoint frost free fridge freezer the fridge not working but freezer is
Hi Reginald
Most refrigerator / freezer units chill the fridge area by venting some fraction of the very cold air from the freezer into the fridge compartment through a channel that has a mechanical air valve in it. In this way, it can control the chilled air flow, and aim for the set temperature, all the way down, in some cases, to freezing, or even colder, on the fridge side.
That vent unit, depending on your model, sill be somewhere in the wall that separates the freezer from the fridge. What can happen is that moisture condenses into the louver that slides to control the airflow, it freezes, and then system is stuck, since it's cold on the freezer side, and this keeps the louver frozen stuck. If that is the case, shutting the unit off for a while may recover function, though getting it to where ice is melting in an interior wall may be more risk of food spoilage than you'd want. Otherwise, use a search engine to look for 'how to test freezer / refrigerator vent in make/model', and you'll likely come across all sorts of youtube and step-by-step tutorials.
Good Luck!
D
Nov 30, 2015 | Hotpoint Refrigerators
Hotpoint Rfa52 fridge not working. Freezer ok.
is temp or freezer control turned all the way up? set frig / freezer control in middle and wait 24 hours. do you feel cool air going in freezer from vent? if not change control as stated and see if you have air flow. control door to frig may also be broken or stuck
Jan 30, 2014 | Hotpoint RFA51 Bottom Freezer Refrigerator
Hotpoint ff73 fridge temp unstable some times ok other times not chilling at all temp gauge showing different reading and freezer sometimes drops down to minus 30.in the cabinet
Possible that the thermostat is faulty or there is a weak connection due to frost wearing- out the connection of the thermostat. Shut down the fridge and allow time for the frost to melt off, then check the connections of the thermostat and to the defrost timer, open the freezer rear panel to check this out.
If not the main relay also must be checked, Hope there is no interuption of the mains power.
Sep 08, 2011 | Hotpoint Refrigerators
Got a hotpoint ff72 fridge freezer and the fridge is not working, light still comes on but fridge is warm. freezer is ok
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 14, 2011 | Hotpoint Refrigerators
My Hotpoint BL11 integrated fridge wont chill even with thermostat turned up full. Please help.
look for frost build up in back of freezer and if so you do have a defrost problem and the air flow is restricted causing poor cooling mm ,,
Sep 01, 2010 | Refrigerators
The fridge and freezer is not chilled
power to the house was shut off for repairs, when power was restored the freezer part of the fridge stopped working but the compressor still runs.
Mar 19, 2009 | Hotpoint HSS25GFP Side by Side...
Hotpiont ffm90 fridge not chilling
hi if the freezer appears to work and the fridge if warm,the problem is that the freezer is over frozen and blocking the vents which send cold air into the fridge when required,and the noise is the fan hitting the the ice build up,defrost (switch off)your applinace for at least 36 hours then switch back on,you will then find after the freezer reaches -12 the fridge will then start to go cold.
Mar 09, 2009 | Hotpoint FFM90 Bottom Freezer Refrigerator
Hotpoint not chilling
looks like your compressor is busted. the sound that is not healthy is the compressor trying to start, as you have said, chugging... now everything is hot since the compressor is no longer running. have a qualified tech check it to see if the compressor could still be saved...it might just be a dirty condenser.
Dec 15, 2007 | Hotpoint FFA70 Bottom Freezer Refrigerator
FFA60 Hotpoint fridge/freezer Red warning light
if i read the english right, the compressor runs but the freezer fan only runs for a short time. no fan then no cooling. there is a fan stat so that the fan only runs when the evap is down to temp. this may be faulty. also on some hotpoint, the fan switches off when door opened. check door switch operating ok. this may also explain problem with fridge lamp
Mar 11, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
110 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
