Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA KV-24FS100 24" TV On/Off problems
Several people seem to have this problem. Mine is the same: "standby light" blinking when tv is off and it takes several tries to get tv to power on. Today it took about 20 tries to turn tv on. Help!! I'm no techie so please keep in mind us simple folks. Standby light blinks 7 times in a row. Attempts to power up fail each time. Unplugged TV after first hitting the power button but before TV turned itself off again without success (this was suggested by people at Sony). Still can't get TV to power up.
  • 4,234 Answers
Since this seems to recover there are 2 possibilities:
1) There are a number of poor solder connections on the main board that are causing enough of a circuit disruption to be detected as a problem. When the set "warms up", this seems to correct itself.
2) There are some defective capacitors in the horizontal circuit that again work sufficiently after warm up to allow the set to function.
If you are comfortable working inside the set and can solder, you should be able to fix this yourself.
Let me know if that is what you would like to do and I'll provide details.
If not, the parts required should not be more than $20. Add in the local labor rate for the total repair cost.
Dan
Posted on Jul 02, 2008
    President:
  • 357 Answers
Hi there
Try replacing the electrolytic capacitors in the power supply section. I started with replacing (2) 860uf 180v caps just after the bridge rectifier and continued along the circuit. Some (15) or so capacitors later,it finally cleared the the horizontal bars and lines and the high pitched noise. It also fixed another intermediate problem of no video, when turning on the power.
Here is a picture of what they look like:
Thank you for using FixYa. Have a nice day and please remember to rate this solution as FixYa if it helps you.
Thanks
Dustin Ellse (BearWeb)
    Genius:
  • 1,665 Answers
Perhaps power on switch is faulty
2 Suggested Answers
SOURCE: Sony FD Trinitron WEGA KV-24FS100 24" TV On/Off problems
check your lamp cover and make sure it is not loose. of so take a philips screwdriver an tighten the cover screw.
Posted on Oct 01, 2007
Sony FD Trinitron WEGA..won't turn back on TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of an
Visit this site for details. All information about this type of fault [2 blinks of standby light to sony Trinitron]; are described here in detail.
"Electro-help", is the name of the site.
Search for it on Google.
May 02, 2012 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Jul 11, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony trinitron not working
The power supply has failed which are very expense and your better off Getting a new T.V.
May 23, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blinks
The blinking standby light should be in a repeating pattern of a fixed count of blinks. Please post that count here as that will indicate the circuit in which a problem was detected. Armed with that info, we can then tell you the problem and probable solution.
Thanks,
Dan
Dec 23, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Please post the blink count. The standby light should be blinking a repeated count. That will indicate the circuit where the problem resides.
Thanks,
Dan
May 19, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony WEGA KV 32FS100
No picture. Standby light blinks 5 times. Tried unplugging and restarting. Same problem
Dec 22, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
KV-32FS120
Seven Blinks: High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into shutdown. Check power supply and horizontal circuits.
Culbert Communications
New Brunswick, Canada
Nov 23, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Oct 01, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
195 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
