Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Personality code i changed the circuit board in the back. when i plugged in the fridge it was flashing pe0000. when i try to hold the door alarm and freezer minus to set personality code for 3 seconds nothing happens. is there an alternate way to set the code?
  • amharristx Jan 18, 2009
    I am having the same problem with the PE0000 so I've gone through all the steps but when I try to enter my program code (confirmed on inside, right of unit) 1720 it beeps at me indicating an invalid program code. I've made many attempts to enter it but still it beeps without saving the code? Any ideas or alternative codes?
Drcool,
Thanks for these instructions but there is one error: it's not the Fresh Food door you open. It's the *Freezer* door.
Posted on Aug 23, 2008
  • 958 Answers
Osborne, you can try this procedure.
PROGRAMMING MODE: (FOR PROGRAMMING A NEW CONTROL)
NOTE:
The Program Code is located on the Serial Plate on this unit after the word Code.
1. Open the Fresh Food door and press and hold the Door Alarm Keypad.
2. Press and hold Freezer Temperature Down Keypad .
3. Release the Door Alarm Keypad and wait 3 seconds.
4. The control will display PE to indicate the programming mode.
DIAGNOSTIC TESTS
5. Entry is confirmed by pressing the Freezer Temperature Down Keypad once more.
6. The control will display the current Program Code. This value should be validated with the
Program Code printed on the unit serial plate.
NOTE: If the Program Code is correct, the Programming Mode is exited by closing the Refrigerator
door(s).
7. Press the Refrigerator Temperature Up Keypad or Refrigerator Down Keypad to change the
digit value with each key press.
8. The decimal point indicates the selected digit. Press the Freezer Temperature Up Keypad
to select the next digit.
9. Once the desired Program Code is entered, press and hold the Freezer Temperature Down
Keypad until the Program Code begins flashing indicating it has been saved.
NOTE: If you attempt to enter an invalid Program Code the control will not save the new code,
but will beep. (The unit will NOT run with a Program Code of 0000).Once the Program Code
has been saved, the Programming Mode is exited by closing the Refrigerator door(s). If the new
code is incorrect this process should be repeated after closing the Refrigerator door(s).
The Programming mode can be exited at any time by closing the Refrigerator Door(s) or
will exit if unattended for four minutes.
i hope i was able to fix your problem.
Posted on Jul 08, 2008
I am talking abt maytag refrigerator . New board panel and the PE0000 just keeps flashing
You need to program the new board. Programming Mode:
NOTE: The Program Code is located on the Serial Plate on this unit after the word Code.
1. Press and hold the Door Alarm Keypad .
6. The control will display the current Program CODE. This value should be validated with the
Program CODE printed on the unit serial plate.
NOTE: If the Program CODE is correct, the Programming Mode is exited by pressing Door Alarm Keypad for 3 seconds.
7. Press the Refrigerator Temperature Up Keypad or Refrigerator Down Keypad to change the digit value with each key press.
8. The decimal point indicates the selected digit. Press the Freezer Temperature Up Keypad to select the next digit.
9. Once the desired Program CODE is entered, press and hold the Freezer Temperature Down Keypad until the Program CODE begins flashing indicating it has been saved.
NOTE: If you attempt to enter an invalid Program CODE the control will not save the new code, but will beep. (The unit will NOT run with a Program CODE of 0000).Once the Program CODE has been saved the Programming Mode is exited by pressing any key. If the new code is incorrect this process should be repeated.
Oct 13, 2016 | Maytag Refrigerators
How to check for a bad sensor on my MFI2569YEWO maytag fridge? We've replaced the control board in the back and display board in the door. the display reads PE0 000. Can't get it to program. HELP ME!
Patti when you change the main control board you have to reprogram the refrigerator to understand the board there is a code just below the model number and here are the instructions you need to follow them carefully
Programming Mode:
NOTE: The Program Code is located on the Serial Plate on this unit after the word "Code."
2. Press and hold Freezer Temperature Down Keypad within 3 seconds .
6. The control will display the current Program CODE. This value should be validated with the Program CODE printed on the unit serial plate. NOTE: If the Program CODE is correct, the Programming Mode is exited by pressing Door Alarm Keypad for 3 seconds.
9. Once the desired Program CODE is entered, press and hold the Freezer Temperature Down Keypad until the Program CODE begins flashing indicating it has been saved. NOTE: If you attempt to enter an invalid Program CODE the control will not save the new code, but will beep. (The unit will NOT run with a Program CODE of 0000).
Once the Program CODE has been saved the Programming Mode is exited by pressing any key. If the new code is incorrect this process should be repeated. The Programming mode can be exited at any time by pressing Door Alarm key for 3 seconds or will exit if unattended for four minutes.
http://www.appliance911seabreeze.com/
Aug 09, 2016 | Maytag Refrigerators
Control on door has flasing lights, water and ice has stopped working
this appears to be the door switch is either bad or disconnected and has triggered an alarm mode to the display. If the unit is cooling ok then you should remove and check the switch with a meter.
May 29, 2014 | Maytag MFD2560HES Bottom Freezer French...
I just replace my control board and freezer fan. I plug the refrigerator in and I get the PE0000 code. I try to go into the program mode by pressing door alarm and then freezer down key for three seconds...
I just fixed mine. With the PE00 0000 flashing press and hold the door alarm key, press the freezer down (-) button and hold, then release the door alarm button. after about a second release the freezer down button and the display should change to a steady PE00 0000 after about 3 seconds. Using the refrigerator + - buttons you change the code. The freezer + - buttons now control the position of the decimal point to change each number position. My code was 0302 (found on the sticker on the inside of the frig, right hand upper side. I had to follow the programming code found behind the kick plate on the right side twice, the second time it worked.
Apr 08, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
When fridge/freezer door is opened the fridge starts beeping and the light constantly turns on and off until the door is closed
WHEN i OPEN MY WHIRLPOOL FRIDGE THE LIGHT FLASHES ON AND OFF AND THE COMPRESSOR APPEARS TO CUT IN AND OUT AND THE FRIDGE BEEPS UNTIL DOOR IS CLOSED. cAN ANYONE HELP?
May 23, 2010 | Whirlpool Refrigerators
Programming code not working
Go to this web page to find the text answer below: http://www.fixya.com/support/t233614-reprogram_hv_board
HERE TIS RIGHT OFF THE INSTRUCTION SHEET.  THE TECH JUST LEFT. POWER UP REF. PROGRAM CODE IS LOCATED ON SERIAL PLATE ON THIS UNIT AFTER THE WORD CODE.-1. PRESS & HOLD THE DOOR ALARM KEYPAD.-2. PRESS & HOLD FREEZER TEMP DOWN KEYPAD.-3. RELEASE DOOR ALARM KEYPAD AND WAIT 3 :WILL DISPLAY PE TO INDICATE PROGRAMMING MODE-5. ENTRY IS CONFIRMED BY PRESSING TEMP DOWN - KEYPAD ONCE MORE.-CONTROL WILL DISPLAY CURRENT PROGRAM CODE. THIS VALUE SHOULD BE VALIDATED THE THE PROGRAM CODE PRINTED ON UNIT SERIAL PLATE.-NOTE: IF PROGRAM CODE IS CORRECT, THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOOR.-7.PRESS REFRIG TEMP UP KEYPAD + OR REFRIG DOWN KEYPAD -TO CHANGE THE DIGIT VALUE WITH EACH KEY PRESS.-8.THE DECIMAL POINT INDICATES THE SELECTED DIGIT. PRESS THE FREEZER TEMP UP KEYPAD + TO SELECT NEXT DIGIT.-9.ONCE DEIRED PROGRAM CODE IS DISPLAYED, PRESS AND HOLD THE FREZZER TEMP DOWN KEYPAD - UNTIL UNIT PROGRAM CODE BEGINS FLASHING INDICATING IT HAS BEEN SAVED. *note* IF YOU ATTEMPT TO ENTER AN INVALID PROGRAM CODE, THE CONTROL WILL NOT SAVE THE NEW CODE, BUT WILL BEEP! (THE UNIT WILL NOT RUN RUN WITH A UNIT PROGRAM CODE OF 0000). ONCE THE PROGRAM CODE HAS BEEN SAVED THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOORS.
Aug 03, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag ice20
When replaceing the highvoltage control board be careful to not handle it too much as nano voltages can burn it. Unplug before repair. Simply hook it up the way you unhooked it very easy and in the left back of the fridge. Now that it's installed plug fridge in and push back to wall. Look at model tag and write down your code something like 0304 most likely. Go to digital control hold down door alarm and freezer - minus button for 3sec. then let off door alarm now you should see PE flashing the fridge wants personality code (the one you have wrote down). Let off minus now it should show 0000 now push minus once more a decimal should show up 0.000 the decimal indicates what number your about to change. Move the decimal with freezer plus button and lower or higher number setting with fridge side buttons.Once your done hold down freezer minus till the numbers are flashing then open any door and close. Now the fridge should be working properly.Hope I helped
Dec 12, 2007 | Maytag MFD2560HES Bottom Freezer French...
How do i reprogram my HV board?
HERE TIS RIGHT OFF THE INSTRUCTION SHEET.  THE TECH JUST LEFT. POWER UP REF. PROGRAM CODE IS LOCATED ON SERIAL PLATE ON THIS UNIT AFTER THE WORD CODE.-1. PRESS & HOLD THE DOOR ALARM KEYPAD.-2. PRESS & HOLD FREEZER TEMP DOWN KEYPAD.-3. RELEASE DOOR ALARM KEYPAD AND WAIT 3 SECS.-4.CONTROL WILL DISPLAY PE TO INDICATE PROGRAMMING MODE-5. ENTRY IS CONFIRMED BY PRESSING TEMP DOWN - KEYPAD ONCE MORE.-CONTROL WILL DISPLAY CURRENT PROGRAM CODE. THIS VALUE SHOULD BE VALIDATED THE THE PROGRAM CODE PRINTED ON UNIT SERIAL PLATE.-NOTE: IF PROGRAM CODE IS CORRECT, THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOOR.-7.PRESS REFRIG TEMP UP KEYPAD + OR REFRIG DOWN KEYPAD -TO CHANGE THE DIGIT VALUE WITH EACH KEY PRESS.-8.THE DECIMAL POINT INDICATES THE SELECTED DIGIT. PRESS THE FREEZER TEMP UP KEYPAD + TO SELECT NEXT DIGIT.-9.ONCE DEIRED PROGRAM CODE IS DISPLAYED, PRESS AND HOLD THE FREZZER TEMP DOWN KEYPAD - UNTIL UNIT PROGRAM CODE BEGINS FLASHING INDICATING IT HAS BEEN SAVED. *note* IF YOU ATTEMPT TO ENTER AN INVALID PROGRAM CODE, THE CONTROL WILL NOT SAVE THE NEW CODE, BUT WILL BEEP! (THE UNIT WILL NOT RUN RUN WITH A UNIT PROGRAM CODE OF 0000). ONCE THE PROGRAM CODE HAS BEEN SAVED THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOORS.
Oct 26, 2007 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
718 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
