My RCA dta800 tv digital converter stop working. It work good for a couple of days but it start turning it self off till yesterday I could not turn it on at all. Did I got a lemon?
  • Anonymous Jul 04, 2008
    I had the same problem and exchanged it for a different but identical unit. The replacement seems to be fine after more than a month of daily use.
I had to bring one back to exchange with the same symptoms. The replacement seems fine after a month or so of use.
Posted on Jul 04, 2008
RCA DTA800 TV Converter Box I need TV codes for the remote to work. The TVs are a GE, phillips magnabox
Good day,
I might be missing something, but you are describing a converter box that converts digital signals from an antenna to analog.
The converter box will be set to channel 3, and you should set your tv's to channel 3 as well.
Using the remotes that came with the tv's go into setup and if available as an option, you will find an option to select cable/antenna or automatic. Select automatic or antenna and save. If there is a selector switch on the back of the tv's, set to 3.
Connect antenna cable into input, and use supplied cable to connect from the output of the converter to your tv.
plug in power supply for converter box, tune tv to channel 3 then follow instructions to setup converter box including channel scan.
When done, the converter remote will control everything. However, the tv volume control will work even though the converter remote will have volume as well. The tv remote as well is needed to shut off or turn on tv. These functions can on most tv's be performed on the set as well.
No codes are required. The converter remote will work on any tv.
If you want to use both tv's then you will need a splitter on the output of the converter to send the signal to both tv's. Only one channel can be viewed at a time.
Viewing separate Chanel's requires a second converter box and a splitter connected to the antenna cable for viewing separate channels.
More options are possible, but I hope this helps you get started.
The converter box takes place of the tv's tuner and in essence disables it.
Nov 05, 2009 | Tablets & eReaders
How to I enter the codes for my TV into the RCA Digital Converter DTA800
You don't need to...the converter works with any tv. Read your manual for proper setup.
Oct 06, 2009 | Cameras
Scanning channels stops at 20%
the exact same thing happened to my dta800. i unplugged the ant. input at 20 percent and then plugged it back in when it resumed. i dont know why this worked, but i now get my 25 channels instead of the 4. this digital garbage is annoying all around. hope this helps. senor punko
Jun 19, 2009 | Televison & Video
I have a ILO TV and need the codes for a RCA DTA800 converter
Already found solution with codes from Orian that worked.
Thanks
Jan 04, 2009 | Hitachi 57F510 57" Rear Projection...
Need a progam code for rca dta800
I just tried their web site and it worked! They have the codes. www.1800customersupport.com/rca
or here is the direct link: http://www.1800customersupport.com/productdocuments/DTA800B1_Program_Codes.pdf
Hope this helps others who have had the same problem. Mine did not even come with these codes!!!
Jul 07, 2008 | Hitachi 57F510 57" Rear Projection...
Remote control programming codes
i have a GE t.v. and just bought the RCA DTA800 converter box. none of the codes that were in the manual worked for my t.v. can anyone help?
Jun 19, 2008 | Televison & Video
Installed and setup RCA DTA800 digital converter. Ran a channel scan and did not pick up any channels. Have an outdoor antenna with an amplifier. Need advice.
Try bypassing your amplifier. I was getting an incomplete scan, and that solved the problem. I ran the scan without the amp in the line, then turned off the TV and converter and reconnected the amp.
May 27, 2008 | RCA Televison & Video
Digital TV Converter keeps shutting off
The DTA800 has a Power Saver feature that turns the unit off after 4 hours if it is idle (no volume or channel changes).
Press MENU button, press #5 (Setting/Configuration), press #3 (Power Saver) Select OFF to de-activate this feature (no Power Saver).
This is covered on page 11 of the DTA800 user manual.
Apr 25, 2008 | Televison & Video
Connecting to an RCA DTA800 digital converter?
I got the new RCA converter box I followed the on screen info but i'm not getting a signal from my antenna so it doesn't show any channels
Mar 10, 2008 | Symphonic SC3913 13 in. Combo
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
