Question about Samsung Cell Phones
How could you put pictures on the computer from a samsung slider
    Brigadier General:
  • 7,752 Answers
You need to install the Samsung PC Studio Suite to the pc then connect the phone via usb cable and you can now transfer the photos from your phone to pc.
Posted on Jul 02, 2008
Tracfone customer service
TracFones are prepaid cell phones that do not have USB support. No USB support means that you cannot connect the cell phone to your computer via a USB device, to extract pictures. You have to send the pictures to an email account and retrieve the pictures from your computer
Aug 16, 2014 | Samsung Tracfone S425G Slider with Triple...
Tip
Samsung phones
Hello there Samsung slider phones LCD or screen problem. Always you have seen that samsung phone get problem like some phone doesnt have light in LCD and some times they does not turn on. Samsung slider phones like G 600 , U 600 . J 700, E250 ,D800 and D900.Slider phones always has Ribben ( slidr belt ). And this ribben always connect phone upper part ( screen ) to the mother board.when the ribben (slider belt) got damage then it gives you that problem.it happens when you use your phone roughly or when you dropped your phone on concrete or any different floor.Mostly Samsung phone model U600 , G600 AND J700 has this problem.whenever your phone gets this problem firstly check. And Do not try any flashing or any kind of software tools. it easy to change ribben (slider belt ). Just get ribben belt or some tiny screw driver and some slider opener. this tools are easy to get from any tools shop. then mostly phone has screw. firstly open the battery cover and take it out and see two hole under the battery and when you slide up your phone then you can see two screw just under your phone top keypad just hold the slider for while and open those screw and slide up then see two rubber things are both side on camera. Use any flicker type things and take out that rubber top then you can see two screw just under the screw open those screw then use the slider opener if the opener is tight if slider is loose the do not use opener just take it out so softly and remove the one side of the ribben which you can see connected of mother board just take out ribben and put new one ribben the put all things back as a normal then tight the screws and put battery then turn it on your phone will turn on.some phone like U600 ,j600,has touch panel. this type of model slider belt or ribben always comes with touch panel and its quite difficult and quite expensive to change.Samsung U600 has this problem mostly because they are very thin and then slider belt is as well thin and they get this problem so quickly.
thanks
on Jan 08, 2010 | Cell Phones
Network lock
Hi. you can get the network unlock code for a Samsung E2550 from Mobile-Unlocker.com at affordable cost.
..........UNLOCKING INSTRUCTIONS..........
Method 1:
1 - Switch ON your Samsung E2550 Monte Slider with a NOT ACCEPTED SIM Card.
2 - Samsung E2550 Monte Slider will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung E2550 Monte Slider shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung E2550 Monte Slider.
3 - Compose : #0111*CODE#.
Jul 07, 2014 | Samsung GT-E2550 Cell Phone
When i slide up my mobile,it doesnot work..
what kind of phone is it ? you need to buy the tool to open it. most phone that slide have a wire that could come off when you open and close to much so you need to put it back were it belongs. like in this picture! if you look close. http://www.instructables.com/id/Disassemble-your-Samsung-A737-slider-phone/
Nov 09, 2010 | Cell Phones
Instructions to replace the samsung sgh-a877 lcd screen?
needs major work. Do it at your own risk. Did everything right but messed up and broke the tab on the touchscreen cable connector on my daughter's phone. Feel crappy. Will post with pictures later on.
1. remove battery/ Sim 2. remove all screws from the back on the black plastic cover. (6 of them) Leave the ones below the battery. 3. Use the pry tool to remove the back case. 4. remove the motherboard, three connectors, one on bottom left, antenna and top right below the board. board comes off. You also have to remove the power connector (transparent plastic) to what appears to be some hf component (cylinder). there are two wires (red, black), red goes to side marked +. remove with pry tool. 5. Remove all small screws you can see. 6. Remove the shiny plate, keyboard button layer. 6a. Remove the lcd connector screw and the connector. 7. Remove screws from the bottom of the lcd portion of the slider. You can access all screws from the back side. Use the slider to get the back of the phone. There are 5 screws. 8. Use the pry tool to take out the back slider. Be careful with the lcd connector. 9. pull up the black tab on the digitizer connection from the screen 10. remove the lcd 11. use a hair dryer to loosen the glue around the broken digitizer. 12. put the new one in 13. Put all the screws back.
Apr 10, 2010 | Samsung SGH-A877 Impression Cell Phone
The keys on the slider don't work properly. I press them but nothing happens. So the arrow keys and two side buttons (call and hangup) don't work. Also, when I slide the phone shut, the white lights on the...
it is the slider problem which is called ribben problem. u 600 phone is so thinn and samsung they putted so thinn ribben in that it goas damage so quickly. try to change slider or ribben.
Dec 30, 2009 | Samsung SGH-U600 Cellular Phone
SGH G 600
is strip problem ok plz change rs200 only any more info sent me mail okkkkkkkk
Aug 29, 2009 | Samsung SGH-G600 Cellular Phone
I need a backup pass word for a samsung
i'm sorry to say but the only way to unlock the locked phone is to enter "*2767*3855#." onto it and it will factory reset everything so your pictures will be gone...
May 08, 2009 | Samsung SGH-a737 Cellular Phone
Samsung SGH-E800 nodisplay
Can u Help me.
How to remove slider.
In my mobile the display ribbon connector was cut so i do not know how to remove slide to change the ribbon connector.
Can you sent picture regarding servicing (to remove circute board and slider.
Thanks
Jan 27, 2008 | Samsung SGH-E800 Cellular Phone
Cell Phones Logo
56 people viewed this question
Top Samsung Cell Phones Experts
kenneth njonjo
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
