Question about Bosch Dishwashers
Bosch SHV66A03uc built in
I need to replace the water valve assy. on left front where water line connects. Looks like 2 screws hold it in. It has a slow leak that is causing water to build in base and trip shut off. DO I have to remove the dishwasher and flip it to remove base? How big a job is it? Any help appreciated
  • 413 Answers
There is no easy repair on a Bosch dishwasher. I guess Bosch figured it would run forever. To replace anything (except the wash motor start capacitor) you will have to remove the dishwasher, flip it upside down to do most repairs.
Regards;
reg501
Posted on Jul 02, 2008
We have a bosch 9925uc dishwasher and water keeps leaking into the dishwasher. How do I fix this?
Welcome to FixYa.
Based on your description, " water keeps leaking into the dishwasher "... and to answer your question, the issue is likely with the inlet/water valve.
**To remedy this you will need to replace the valve, not surprising for Bosch unfortunately**
This is what to look for..i.e.
As long as your model number is indeed correct, this info below will be accurate.
Original part is # 425458. It usually retails for about $20 - $30USD at places such as "searspartsdirect.com" "repairclinic.com" to name a couple.
**Before attempting to repair the unit please turn off the power and the water supply to the dishwasher...safety first**
If you remove the lower kick plate/toe panel, you will see the inlet valve to your left...
i.e.
Replacing it or to check for debris in the filter/screen at the inlet is pretty straight forward. Here`s how...
1) undo the water line. ( here you can visually inspect the screen in the valve...if nothing noted, you'll likely need to replace it as follows )
2) Remove the two #20 torx screws fastening it in place.
3) the feed tube to the machine at the back of the valve and swap it with the new one.
and
Once the new one is in you should be good to go.
Let me know if you need any further assistance, otherwise good luck.
Thanks for visiting FixYa.
Regards,
Macmarkus
Jan 02, 2011 | Bosch SHU9925UC Built-in Dishwasher
My Bosch SHX46A02UC-23 dishwasher is continually letting in water from water supply, even when unit is turned off.
Welcome to FixYa.
Based on your description, " dishwasher is continually letting in water from water supply, even when unit is turned off "... and to answer your question, the issue is likely with the inlet/water valve.
i.e.
and
Regards,
Macmarkus :)
Dec 16, 2010 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
My bosch dishwasher is not filling up with water. Where is the inlet filter?
Welcome to FixYa.
Based on your description, " my bosch dishwasher is not filling up with water. Where is the inlet filter? "... and to answer your question, the issue is likely with the inlet/water valve.
As long as your model number is indeed SHU8805 series, this info below will be accurate.
i.e.
and
Regards,
Macmarkus :)
Nov 24, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Makes screaming as washer is being filled.
Welcome to FixYa.
Knowing what you`ve provided "Makes screaming as washer is being filled"...
the issue is likely with the inlet/water valve being noisy. To remedy this, first check your water pressure is adequate or the supply line valve is completely "open".
If you can rule out the issue of water supply pressure being the culprit, you will need to replace the valve, not surprising for Bosch unfortunately.
i.e.
As long as your model number is indeed SHU66 series, this info below will be accurate.
I say not surprising because this part has been an issue for the B/S/H/ built machines in the past and as a result the original part number 189553 now substitutes to 425458. It usually retails for about $20 - $30USD at places such as "searspartsdirect.com" "repairclinic.com" to name a couple.
Replacing it is pretty straight forward. Here`s how...
2) the two #20 torx screws fastening it in place.
and
Regards,
Macmarkus :)
Sep 29, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
There is no water getting to the dishwasher. Nothing has changed with the water line. Looks like there is a problem with the dishwasher. (Bosch Brand)
Hello, your problem is going to be with the inlet valve. Remove the panel at the front bottom of the dish washer, turn the water and power off. You will see the inlet valve normally on the left side underneath your dishwasher (sometimes on right) connected to the water supply. Remove the water supply hose/pipe and then remove the wire harness from the valve. Now you can remove the valve from the machine. Just inside the inlet there should be a screen...check this for debris. If debris found clean out and reassemble, If no debris replace the valve and then reassemble. If you have any other questions please feel free to comment again. Good Luck!!! Mike
Sep 08, 2009 | Bosch Dishwashers
HOW DO YOU REMOVE AND REPLACE WATER INLET VALVE ON FRIGIDAIRE LTF2140FS1
remove the screws holding the top panel on, they are located on the back at the top. Standing at the front of the washer, push top panel towards rear, then lift up and remove. Notice the water inlet valves on the rear left while facing the washer front. Unplug washer, then remove the mounting screws holding valve assy onto machine, on some fridg's there are 2 screws holding an inlet valve assy onto the dispenser underneath the valve assy, they are very hard to get to. Remove valve assy from washer and replace. Remember to mark wiring locations as needed.
Jul 01, 2009 | Frigidaire ATF6000ES Front Load Washer
KitchenAid KUDP01DLWH6 dishwasher filter clog
Follow the main water supply line. It goes to a solenoid valve which is normally located front left side under the dishwasher.
1. Turn off the main circuit breaker for the dishwasher.
2. Turn off Water supply to the dishwasher.
3. Remove lower front panel.
4. Remove Water supply line from solenoid.
5. remover wire connections from solenoid.
6. Remove 2 mounting screws from solenoid.
7. Take solenoid valve out.
8. Look inside the valve where the water supply line was connect to, You will be able to see the filter. it is just a screen and you can easily clean it.
Good Luck
Jun 27, 2009 | KitchenAid 24 in. KUDP01DL Built-in...
I need a diagram of the entire breaking system on a 1993 ford taurus i just replaced a rear line and i think i stripped the extention piece i had to add to the end of the break line. the one that goes into...
here is a 96 taurus
Item Part Number Description 1 2C296 Anti-Lock Brake Tube 2 2C219 Anti-Lock Brake Module 3 2005 Power Brake Booster 4 2263 Front Brake Tube 5 2B091 Brake Pressure Control Valve 6 2140 Brake Master Cylinder 7 2B547 Brake Load Sensor Proportioning Valve 8 N802191-S60 Bolt 9 2L568 RH Rear Brake Tube 10 2L569 LH Rear Brake Tube 11 2C287 Brake Fluid Distributor Tube 12 N808531-S301 Bolt 13 — Front Side Member 14 N802324-S56 Bolt 15 18124 Front Shock Absorber 16 2B121 Front Disc Brake Caliper 17 2078 Front Brake Hose 18 2264 Front Brake Tube 19 2553 Rear Disc Brake Caliper 20 2A442 Rear Wheel Brake Hose 21 N808728-S60 Bolt 22 — Side Rail 23 N802324-S60 Bolt
Item Part Number Description 1 2B547 Brake Load Sensor Proportioning Valve 2 — Body 3 N802191-S56 Bolt (2 Req'd) 4 2L568 Brake Tube Assy 5 2L569 Brake Tube Assy 6 2265 Brake Tube Assy 7 2B255 Brake Tube Assy 8 5500 Rear Suspension Arm and Bushing 9 W611634-S301 Bolt A — Tighten to 11.4-15.6 Nm
(8-12 Lb-Ft) B — Tighten to 10-14 Nm (7-10 Lb-Ft)
Brake Hose, Rear —Drum
Item Part Number Description 1 — Rear Side Rail 2 2L569 Rear Brake Tube 3 N602324-S60 Screw 4 N611193-S60 Screw 5 2C023 Left Hand Rear Hose and Connector 6 2210 Rear Drum Brake Backing Plate 7 18125 Rear Shock Absorber 8 2267 Rear Brake Tube A — Tighten to 16-20 Nm (12-15 Lb-Ft)
May 10, 2009 | 1993 Ford Taurus
Bosch SHU 4000 series dishwasher; Water keeps on filling
The inlet valve will be at the dishwasher end of the (hot) water inlet line. On this dishwasher I ~believe~ the inlet valve is near the rear of the unit. That means that you will need to pull the dishwasher out to get to it. Remove power from the dishwasher as soon as you can before messing with the unit.
Just past the connection of the supply hose and the connection on the dishwasher, there will be the valve (a solenoid valve with two wires coming out of it.) That is the little beast that has most likely failed.
Good Luck!
Jan 14, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher SHU9922UC
Sounds like you already know how to fix it. The inlet valve is only held closed by water pressure...if you have low water pressure it could be causing this. Its more likely just a bad fill valve though. The water inlet valve is accessed by removinf the lower kickplate and the sheild behind that. Then all you have to do is remove the water line from the valve, remove the 2 screws holding it and pull it out far enough to disconnect the 2(possibly 3) wires and the fill hose. Make sure to mark where your wires go, if you hook it up wrong it could continue to fill and overflow. Hope this helps!
Feb 01, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
532 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
