Question about Lexmark JetPrinter Z25 InkJet Color Printer
The printer won't print even the test page. Everything is connected properly though I've noticed two things of worry. The "Form Feed" light keeps blinking and when I lift the top of the printer to check the cartridges they won't slide over so I can check them. Any assistance would be much appreciated.
    Genius:
  • 2,785 Answers
Plz disconnect the printer from the pc and check if the cartridge carrier is moving when you open the printer front door, if not then your printer needs servicing
Posted on Jul 03, 2008
Hdmi out won't work
It'd be more helpful to know what kind of computer you're using and what operating system you have, eh hem, but still consider the following tip. Sometimes when Windows reports that a device is working properly (even though it isn't), it can be forced to deal with the issue by uninstalling the device. For something built in to the actual motherboard (such as HDMI), just go into your Device Manager and track down the controller. Right click and select Remove. Don't worry that you're 'removing' the device. When you reboot your computer the BIOS will notice the difference in state and will load the drivers for the device anew. Then it should work.
Mar 04, 2013 | Toshiba Satellite A665-S5179 Laptop PC...
How do I make a test page for my printer to check color.
You need to clarify :
1. Your printer cannot print color even though it prints color well from a test page;
2. Your printer cannot print color in a test print page.
If it is the first one, then you have to set it properly in Window Print Configuration page of that printer;
If it is the second one, then you have to check whether you have installed the color ink cartridge properly in the printer. If the color ink cartridge is installed properly, try to replace another new color ink cartridge. Finally it is still not work, then you have to bring back to the repair center.
Jan 19, 2013 | Dell V715w All-in-One Wireless InkJet...
My cyan colour won't print : tried aligning page, everything, can you help?
Try to do the Deep Clean Printhead function on your printer to force ink through the nozzles and clean possible clogs and dirt.
Feb 11, 2012 | Lexmark Office Equipment & Supplies
It seems like the computer and printer are not communicating. I do all the moves on the PC but when I command "print" nothing . I've checked all the cables and even changed USB ports, still...
hi,
  • Is the printer properly installed?
  • Have you set it as your default printer?
  • On the start menu, click on printers and faxes.
  • Is the printer checked[ticked]? Right click on the printers icon and select properties.
  • Check the printers connections by clicking on ports.Had you used same ports connection?
  • If not set them right.
  • Click on print test page.
  • Restart your PC and try printing now.
Sep 16, 2011 | Lexmark Office Equipment & Supplies
The black ink on my Brother DCP-130C won't print and it's a brand new ink cartridge. I thought it was a defected cartridge so I bought another one, same thing. The other 3 colours print ok though....
I have the same problem. Everything on the printer is working just fine. It'll do a test page just fine, so everything's working right. The %$^ thing just won't print. It makes noise like it's printing when you give it a print job, but it spits out blank pages.
Sep 08, 2011 | Brother DCP-130C InkJet Printer
My printer simply wont print, I just get blank pages even when printing the test page. I have tried cleaning, deep cleaning nozzle alignment, everything!
HI there,
It sounds like you've done everything right, and it still won't print. Your printer is dead - and you need a new one.
May 19, 2011 | Office Equipment & Supplies
My Dell V505 printer won't print documents from the computer, when I press print the printer prints a page of dash's and ticks. there is ink in the cartridges. i've disconnected the power....
Turn the printer off.
Disconnect the AC power.
On your computer, click Start
Click Control Panel
Click Printers
Select the Dell Printer
Uninstall it
Restart your computer
Turn the printer on
Allow the computer to reinstall the device-device for the printer.
Print a test page.
May 09, 2011 | Dell AllinOne Multifunctional (v515w)...
My HL5140 will not print even the test page
check out the connections between pc and printer.remove and refit that connection and check out.
Mar 23, 2009 | Brother HL 5140 Laser Printer
Trendnet TE100-P1U won't print
open the print server utility and the doc can be cancelled or deleted from there. (this is the server utility inthe toolbar at the bottom of a windows screen. failing this go to the printer shortcut and from control panel>printers> select printer and faxes>select the printer (open) >select "printer" from menu bar, pause printing,then cancel all documents. Afterthis you can delete printers that are excessivly created, or delete all of them and start again with only the one or two printers you need. even if one is for network use and the ther is direct connect. You canuse direct connect to verify proper printer operation until te100 is working properly
Mar 31, 2008 | Trendware TRENDnet TE100-P1U Print Server
Printer Ignoring Black Text
Assuming the print tests you've done so far are built into the printer: Could be worth printing a test page from the printer properties box (which you can get in XP from the START menu, Settings, Printers & Faxes, then Right click on the printer you want and select Properties from the dropdown. If the test page is OK, I'd try printing from a few different applications to see if that narrows the problem down. If the test page has the same problem, then you might try reinstalling the printer driver. A.
Feb 01, 2007 | Canon PIXMA iP5000 InkJet Photo Printer
Lexmark JetPrinter Z25 InkJet Color Printer Logo
29 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
