Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
No Write permission when attaching Simpletech external drive to Mac OS 10
Attached the external drive to the Mac, and it says that I only have Read permission. I can't seem to get it to have write permission.
The Simpletech external drive is NTFS.
  • Anonymous Aug 12, 2008
    I have the same problem, and as a photographer who goes from using a MAC at work to a PC (unfortunately!) at home, I can't save anything I work on at work and continue to work on it at home! What a waste, I wish I had not purchased the drive. The box said MAC and PC compatible!
  • Anonymous Feb 24, 2009
    how to have access to save on a simpletech hard drive using a mac
    Sergeant:
  • 284 Answers
Simple just format it for PC first then it should work for both
if you format it for MAC first it will not work on the PC
simple
PC are horrible for accessing files
mac's are more user friendly
Posted on Aug 16, 2008
File permissions on My Passport for mac
check the compatibility of the external hard drive. It might not support Mac. Probabely you external hard is in NTFS format and you need to reformat/re-partition it for using it in Mac OS.
Feb 04, 2014 | Western Digital Computers & Internet
I can't delete anything on my harddrive. It says it is locked. I have a mac comp.
You appear to have a permissions issue. You can check this by highliting your drive by clicking on it. Then do a "Get Info" on the drive by clicking on Get Info under the File menu or command-I on youtr keyboard. The Get Info window will then appear. Click on the lock at the bottom, enter your admin name and password, then you can change the permissions in that window. Make sure it says read and write for all. If it says Custom permissions, then it is an OS issue and you will need to call Apple.
Apr 11, 2011 | SimpleTech 250GB USB2.0 7200 RPM External...
I am using Mac and I can not change the permission on my hard drive 320 G Signature Mini to write it only lets me read what do I ...
Ahhh, this is a common problem. The only file system that is both Windows and Apple compliant is the FAT32 file system format. You will have to back up everything and reformat to FAT32.
If you use FAT32 you are restricted to on 4GB files... That means no movies, no long recording, nothing :-/
_OR_
You can format the HDD with your Apple computer and have no restrictions. That file format is called Mac OS Extended Journalled. I reccomend this but keep in mind, it is NOT readable with all non-Mac friendly operating systems, especialy Windows :)
-Paul
Jun 23, 2010 | SimpleTech Signature Mini 250GB External...
Unable to write , only read ????
This is probably formatted with NTFS, the hard drive format used by Vista and now Windows 7.
Mac's OS can't write to NTFS but it can read it. I assume the data is important, so try another PC to transfer to another hard MAC hard drive then port that into your Mac or You can try to down convert it to FAT if you are proficient with utilities.
Mar 28, 2010 | SimpleTech Signature Mini 250GB External...
My simpletech drive is showing on my iMac but I am unable to write any files to it. It says I can only "read" but it does not alow me to change the access.
These things come formatted for PCs--you have to go into Utilities on your mac (in hard drive click on Applications, Utilities folder, then Disk Utility, then click on the simpletech (that has the gb next to it), click on the drop down to change the format (MS-DOS if you want to read on both PCs and MAC, but MAC-OS for just Macs) re-name it on the drop down below that, then click on erase and then it's re-formatted.
Jan 17, 2010 | SimpleTech Signature Mini 160GB External...
Looking for the Mac driver for a 500gb
A ahhhh Mac driver? A mac should just pick up the fact that you plug in an external drive. It might even detect if it's formatted Windows NTFS. You probably have to format it for Mac OS.
http://www.ehow.com/how_2063795_format-hard-drive-mac-os.html
Nov 23, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
My Simpletech external hard drive has the permissions set at read only. how do i change the permissions?
Ok this simple freind what you have to do is hook it the box you had it on. Now make sure you have admin rights on your box and proceed to properties in the mycomp folder on the machine. It will display imfo on the HD and Permissions you need to unchech read only and Make certain you are the admin
Oct 18, 2009 | SimpleTech Signature Mini 320GB External...
Mac not allwoing write permission to an external hard drive
As long as the Esternal is formatted correctly it should work fine, it might be that you computer wont read the hard-drive, not the files.
Jun 16, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech usb drive model 96300-40001-001 Mac OS9 compatibility
If its 9.2 it may be because your mac is usb 1 and your external HDD is usb 2. It will recognize it but sometimes it takes longer to see the drive.
Feb 12, 2009 | SimpleTech SimpleDrive Portable USB 2.0...
Permission Issues
This is a format problem, unfortunatley the mac has a different file system than a regular PC has. A mac can write PC files and mac files. PC's typically are not vice versa in writing to a mac hard disk. Only way around this one is to format the drive to be a PC drive. Then the mac and the PC should see it.
Jan 27, 2008 | SimpleTech SimpleDrive 160 GB External USB...
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
491 people viewed this question
Top SimpleTech Computers & Internet Experts
Lyle Siemens
Lyle Siemens
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
