Question about Technics Audio Players & Recorders
I have an SL-1950 turntable that has sat around for a while. When I set it up , the cueing support that rides under the arm will not lower when I start the player. How do I get it to lower? It did work ok the last time I used it but it might have gotten jiggled during a move. Everything else works fine.
2 Suggested Answers
  • 518 Answers
SOURCE: Cueing Problems on Technics SL-1300MK2
Usually the damping fluid is to let the tone arm lower slowly, lifting is usually a mechanical link. Read THIS.
Hope that helps...
Geno
Posted on Apr 01, 2008
How do I get the Autocue function to work on the Technics SL-D202 direct drive turntable?
When you say that the auto cue does not function properly,do you mean that the arm will not lift from the rest onto the record or do you mean that the set down point of the arm on the record is not correct? Or does it not work at all?
Jun 29, 2014 | Technics Audio Players & Recorders
Needle doesn't make contact with album-can I adjust it myself?
The weight at the end of the arm should be adjusted so that it applies pressure to the stylus. However sometimes the cueing leaver can get stuck or break, not allowing the stylus to come down on to the record. If the weight has numbers trying setting it to around 2 or 3. If it does come down, adjust it till that it neither rumbles or slips across the record. It's a question of trial and error doing this.
Oct 22, 2013 | Technics SL-BD22 Turntable
Tone arm cueing problem on technics sl 1210
The turntable may not be level and consequently beyond the ability of the balance and antiskate adjustments to correct
Jun 26, 2013 | Panasonic Technics SL-1210MK2 Turntable
Need to know what settings the anti-skate and the counterwieght on the back of the tone arm should be set to. Also when pressing start tonearm will not move at all. Can still cue it manually...
The counterwieght should be set the tracking force for the cartridge/stylus fitted. These are expressed in grams. Typical about 2 to 3 grams. If the weight has numbers on it these will match the grams. There's no right setting for the skate. Should the stylus start to skate accross the record increase the force. Start low!
On the arm movement, has the arm moved before after pushing start taking it to a record? As many turntables just don't.
Jan 01, 2011 | Technics SL-1200MK2 Turntable
Technics 1210 tonearm skates when cueing vinyl backwards
I've seen this on technics turntables before. Try tightening the screw on the arm.
May 20, 2009 | Technics SL-1210 Turntable
Tone arm cueing problem on Technics SL-BD27.
the auto stop mechanism needs adjusting
Apr 07, 2009 | Technics SL-BD22 Turntable
Tonearm lifter in UP position - how to fix
I have also had this problem with the same model turntable. I opened mine up and the problem seems to have been that the grease on the arm lift and cueing lever was gumming up the linkage between the two. (I suspect that my turntable hadn't been used in some time.) I managed to free up the parts by manually working the the arm lift (pressing it down) several times. I'm not sure that I needed to open up the chasis for this fix but it did help me to see what was going on. Good luck with yours.
Tim Orange
Mar 20, 2009 | Technics SL-BD20D Turntable
Hope that helps...
Geno
Apr 01, 2008 | Audio Players & Recorders
Panasonic turntable sl h205
Check the belt and the cueing mech, could have siezed.
John w
Feb 12, 2008 | Audio Players & Recorders
44 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
