Question about GE AVX10AD Air Conditioner
Window unit trips circuit breaker
My window unit worked great for a couple of years. I live in a rental and the manager had sent an electrician over to replace one of the switched outlets that happened to be on the same circuit as the AC. However the replaced outlet is not the same outlet into which the AC is plugged. Since that time, the AC worked fine, but would trip the circuit breaker after tunning only a very short time. The plug end of the cord looks like it became very hot prior to tripping the breaker. It was suggested to me that the compressor overload may have been tripped and that the compressor was working too hard. I didn't think that was the case as I have been of the impression that if the compressor overload was tripped that the AC would not work at all and that the overload would need replacement.
What might be wrong with the AC unit? Is it possible that it's something to do with the particular outlet into which it is plugged and not the AC unit itself? I don't understand why it started acting up right after the electrician replaced another outlet on the same circuit.
Any advice would be greatly appreciated.
Contact between plug and outlet is loose and so there is a leakage of current. Recommend to replace the plug to fit the new outlet.If the breaker still tripping call technician to service your unit.
Posted on Mar 31, 2009
  • 828 Answers
If your Plug is getting hot there is a voltage drop where the heat is generated. On these wall outlet recepticals there are two different methods of connecting the wires. First they strip the end of the wire and plug it into the back of the receptical . The second method is to strip the wire and attach it to a screw terminal . This is the best method for any outlet with a motor running from it.
For an example draw a straight line and then draw a circle that comes in contact with the line. Look and see how much contact area you have where the circle touches the line.
Posted on Jul 02, 2008
  • 466 Answers
I agree with james...The contacts are not tight as they could be. Call them back and have them to wire it better with screws.
Posted on Aug 13, 2013
Where is the power windows fuse in 1984 gmc tk
Probably not a fuse, but, a circuit breaker. If the circuit breaker gets hot it may trip. If it trips none of the windows will work. You can also check for voltage at the circuit breaker. I have felt of circuit breakers that were hot to the touch, that particular vehicle had a bad window motor. My info for your model year isn't the best.
Jun 02, 2016 | GMC Cars & Trucks
Tripping circuit breaker
That unit shows that it takes 15 or 20 AMPS to run. What is the breaker amperage on the circuit where it is plugged in? Is the breaker a GFCI? You can tell by looking for the two buttons on the circuit breaker or the outlet.
Jul 18, 2017 | KitchenAid KCMS1555RSS Stainless Steel...
Wiring schematic for white-westinghouse window air conditioner/heater selector switch
I'm willing to bet that the heater is grounded. Probably burnt up the original switch, heater wasn't getting power, therefore not tripping the breaker. Now the switch works, heater gets power and immediately trips breaker. Unhook the switch and tape the wires, reset breaker and try in heat and cool. If no problems it's likely the heater.
Apr 20, 2017 | Heating & Cooling
When compressor kicks in the circuit breaker trips and shuts off juice to outlet; when run in "fan" mode the circuit breaker does not trip. Am I doing something wrong? It was running at this...
This appears to be a direct short internally to the compressor . you neede a ohm meter to test it .. not certain how old the unit is but if its a window unit and over 6 years old I would buy a new one. But it does no0t sound good. In the future when a unit trips the breaker and you reset it and it trips right away its best not to trip it again as it contaminate the inside of thye system and is very difficult to clean and expensive as well . those are my thoughts. It could be the outside fan but the way you decribe it tripping right away my money is on the compressor
Jul 21, 2011 | Frigidaire Compact Air Conditioner
I have a Proform XT 90 treadmill that was recently purchased. After I brought it home, I plugged into my power strip and everything worked fine. Yesterday I plugged it in and nothing lights up on the...
A couple likely issues would be:
1. Is the starter key installed correctly?
2. Has the onboard circuit breaker tripped? The breaker reset is next to the on/off switch, which is on the lower front of the unit. Press the button once firmly. If this was the problem, the treadmill should work again immediately. If the onboard circuit breaker trips repeatedly, there may be a short circuit in the machine, in which case you may be at risk of shock if the unit is not repaired properly.
3. Has the circuit breaker or fuse for the particular outlet you are using tripped? Try plugging another electrical appliance into the outlet. Does it get power? If the circuit breaker or fuse has tripped, that particular circuit may be overloaded or faulty. Only an electrician could tell you for sure.
Please followup if you need further assistance.
Apr 29, 2011 | Proform Exercise & Fitness
Circuit breaker only half working - reddish flag?
A red indicator means a circuit overload has tripped the breaker. You mentioned a heater? Does the circuit tripping coincide with the heater running? There may be too much load on that circuit.
Contact the original electrician to see if he will come check it out ( licensed, reputable electrician should have no problem with this). If he gives you the run around, find another. Was any aluminum wiring found in the home inspection?
May 01, 2010 | Bryant 40 Amp 2 Pole Br240 Type Br Ni...
Torpedo pump...I have one when I plug it trips breaker
I had the exact same issue. I left mine out for the winter and when I plug it in, the breaker trips. My warranty was up so my friend took it apart. The seal had broken alowing water to leak into the bottom the pump where the wires connect to top of motor. This is supposed to be water free and is protected by several seals.
I am currenlty trying to put sealant where the cord goes into unit to stop water from going in. I will let you know how that works.
One tip my friend recommeded is to make sure there is no stress on the cord as it appears this seal is weak and and kind of stress will break it. hope this helps -- Rob
Apr 27, 2010 | RTO Cal Torpedo Pump 7500 Gph
AD50USR Whirlpool Dehumidifier trips circuit breaker
Not very likely check your paperwork what warranty did you get when you purchased this unit? you might have completed some papers and returned them to an address for the warranty to be accepted. It sounds to me like the unit is going straight to earth when switched on, this looks like a compressor fault, but would have to be checked to be sure.
Jul 20, 2009 | Whirlpool AD70USR Dehumidifier
Exact same thing happened to me
the 20 amp circuit should more than handle a 6.5 amp load, the 6.5 is the rating of the operating AC not of the circuit that is required to be attached to it. If the "pop" noise is the breaker tripping the circuit may be miswired, the unit mayhave a short to ground, as the circuit breaker is designed to trip on an over amp situation or a situation where 20 amps is exceeded. Di you verify that the circuit voltage id correct, eg: 220 volt or 110 volts. and that it matches the unit nameplate.
Jul 20, 2009 | Goldstar KG6000R Window Air Conditioner
Heating & Cooling Logo
521 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
