Question about Dishwashers
Kitchen Aid dishwasher won't start
Two days ago, it was running fine. Then I tried to start it the same way I always do...select the cycle and press "start"....but this time when I pressed the "start" button...nothing happens. The green lights come on, but it just sits there and won't start or run. We tried disconnecting it from the power source for 5 hours, but when we reconnected it...still the same. Any ideas?
  • Dishwashers Master
  • 8,617 Answers
If the power indicator is on check the latch as alot of the kitchen aid dishwashers wont start if the latch is out of alignment.
Posted on Jul 02, 2008
Tip
Dishwasher Water Temperatures
No matter what detergent you use, the "pills", powder, or gels, they are meant to activate PROPERLY, key word PROPERLY, at a minimum of 120 degrees Fahrenheit in a dishwasher. I recommend ALWAYS using the "high temp wash, boost, etc" on ANY cycle in order to keep the water HOT! Always run the hot water in the sink prior to starting the dishwasher! The unit is tied in to the hot water line under the kitchen sink and requires very little water to fill--by the time the hot water finally reaches the dishwasher, chances are it'll be running on cold or tepid water--the detergent won't dissolve or activate the way it's supposed to. Not only that, in between fills during the cycle, especially in winter, the water will cool down in the pipes too much. Normally, the water heating selection will maintain water temps in the 130-150 degree range! If someone has been sick in the house, turn on the SANI RINSE if your unit has it! This won't stop--but it'll help prevent cross contamination--people getting sick from the dishes--this setting normally kicks the water temp up to 190 degrees during the rinse cycle.
on Sep 08, 2015 | Dishwashers
Kitchen aid dishwasher not draining....help
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Apr 05, 2010 | KitchenAid 24 in. KUDM01TJ - Multiple...
My 6 yr old Kitchen Aid dishwasher is leaving food residue
After checking all sprayer arms for clearance, and checking heating element and discharge pump, the problem was solved by replacing the small sprayer arm at the top of the washer. This small arm had popped off some time ago - obviously the water pressure was excessive for the small and unimpressive fastener. Luckily we had saved this piece, which I refastened with a strong aluminum non-corroding small bolt. Presto - now the water distribution is back to design specs, with sufficient water coming out under pressure from the mid level arm. Lesson: always look for the simplest cause first with the simplest solution. TCA
Jun 20, 2009 | KitchenAid Dishwashers
KUDI01TJWH0 kitchen aid....the clean light is blinking and wont do anything else....how do we reset or do we just need to take it in for repair?????
To invoke the diagnostic cycle, perform the following key presses in less than 6 seconds while in standby.
Heated Dry -> Normal -> Heated Dry -> Normal
Invoking the diagnostic cycle clears all status and last run information from memory and restores defaults. It also forces the next cycle to be a sensor calibration cycle. (quoted from service diagnostic cycle notes in troubleshooting guide)
Apr 16, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
My Kitchen Aid dishwasher runs for about 2 hours. Is this normal
It depends on your water pressure. Mine runs a cycle in about 25 minutes, with 92 psi water pressure. Before changing all the pipes in my house, I had about 30 psi and it took about 45 minutes. The longer it takes to fill, the longer it takes to do a wash.
Apr 06, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Not starting
Getting Started
1. Load dishwasher (See Preparing and Loading Dishes).
2. Add detergent (See Dishwasher Dispenser & Detergents).
3. Add rinse aid, if needed (See Rinse Aid).
4. Close door to latch.
5. Select desired CYCLE (See Cycle Chart).
6. Select desired OPTIONS (See Energy Options). The indicator light above the pad will glow when selected.
7. Run hot water faucet nearest dishwasher until water is hot. Turn water off.
8. To start, press START/CANCEL pad.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Kinston/154575401.pdf
Jul 14, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Dishwashers Logo
306 people viewed this question
Top Dishwashers Experts
