DVD ROM cant read any cd or DVD
Once you insert any cd in the rom it appears as if it is going to be read after wards the computer sends you an acknowledgement saying that please insert a cd in the rom I had a defective dvd drive. It would not read and eject upon command from computer. The front eject button would not eject the cd. I purchased a new Sony drive and follow the setup. I have a xp system. The device manager in the control panel shows 5 IDE in the Hardware tab. #1 is INtel 8280 #2 is Intel also #3 is Primary IDE and #4is also Prim IDE and #5 id Secondary IDE. I have installed 2 new drives but the system does not detect them. When a system check is made by "Reg Cure" or "PC Fix" the system is ok. Should I uninstall some of these IDE drivers or use roll back?
    Genius:
  • 2,028 Answers
Try uninstalling the drivers and rebooting.
Posted on Jul 02, 2008
Create boot disk
Insert a blank diskette into the floppy drive. Click start click on computer you should see all of you drives.
Right-click on Drive A. You will see the option to format the drive.
Click on Format. Depending on your operating system, you will see an option that reads either "Create a system disk" or "Create a MS Dos system disk." Click the box next to this option.
Click the "Start" button to begin formatting the disk.
When completed, you will have a bootable floppy disk.
For CD Rom or DVD disks
Open the software that you use to burn or write files to the CD-rom or DVD drive.
Click on "Make a Data CD or DVD." Insert a blank CD-R or DVD-R disk into the drive.
Look for the option to "Make this disk bootable." You may have to scroll over the various icons displayed to find this option. Click on the option.
Burn the CD or DVD as usual. Once completed, this disk can be used to boot your computer.
hope this helps
Aug 22, 2012 | Seagate Computers & Internet
My lg DVD RAM GH22NS50 is reading initially and hangs for some sometime and the DVD ram disappear fro my Computer.Again after removing the CD re start the computer it will appear.My OS is XP.I'm using a...
Hello, the problem is from the cd you inserted into the dvd rom, so it mean nothing is wrong with your DVD ROM. I think what you can do to make the DVD or CD work some how, is to use a dusting powder to clean it and try again. But thier is nothing wrong with your DVD ROM. Please vote me.
Mar 27, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
My dvd rom only can read cd. dvd cant read. please help me...
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
hope this helps
Feb 16, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
I put in a blank cd and I cannot burn it because in my computer it shows that there is no cd inserted
Here you go...I hope this works for you....
CD/DVD Is Not Recognized
spacer.gif spacer.gif spacer.gif spacer.gif Many times, after inserting a disc into the CD or DVD drive, the disc is not recognized by that drive. CD-read and DVD-read issues can be caused by many sources. Perform the procedures presented in this General Computer Advice article when troubleshooting CD-read and DVD-read issues.
Begin with the first procedure and continue through the list. Try using the CD or DVD after each procedure is completed. For any procedure that requires changing current system settings, record the original settings before completing the procedure.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will haveDVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Apr 01, 2010 | LG GSA-H55N DVD-RAM Burner
Cd/dvd rom not reading
It's likely a laser alignment problem inwhich you will need to replace the hardware. However, I had a similar problem once with a notebook and found out that a tiny bread crumb was near the spindal making the cd in the drive off balance. Check liberally for any debris. Good luck!
Mar 21, 2009 | HP Compaq Presario C700T
No disc present
Try running a cleaner disc in the unit if that doesnt work try the following.
Starting at my computer... Right click on my computer icon.
Go to properties.
Then Hardware tab then go device manager. Right click on cdrom in device list. Select uninstall then reboot the computer. If this doesn't help replacing the unit will be necessary.
Jan 19, 2009 | LG GCC 4480B CD-RW/DVD-ROM Burner
Drive will not read cd rom, reads dvd and audio
CD rom drive is dead!
Time to go out and buy a new one. Rough cost is anywhere for a DVD BURNER is $25 - $40.
DVD burner are now the mainstream drives replacing CD roms.
But if you can still get a replacement CD rom from a computer in town should be cheaper than a DVD burner.
DVD burner can read and write DVD's and CD's.
Aug 14, 2008 | Pioneer Computers & Internet
Combo drive not reading DVD
my combo drive also not reading dvd :(
Dec 23, 2007 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Computers & Internet Logo
168 people viewed this question
David Payne
David Payne
