Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Reassemble inside parts to kenmore 596.75529400
We bought our "NEW" but, previously used home. It came with the above li9sted refridge. It looks as though they took it apart to clean it and never put the parts back. Do you have or can I obtain a copy of that part of the manual or perhaps a picture diagram of where everything goes.
5 Suggested Answers
  • 17 Answers
SOURCE: Disassembled inside-Kenmore 53602
You have the capability to assemble the entire refrig by roving the internet, there was one refrigerator parts site that had pictures of most of the parts of the liste model. Others will have a parts breakdown diagram indicating the general location of most parts. Also one, can order lthe service manual which has the parts listed and lists a diagramatic layout. This will make so you can reassemble unit, based on your ability to interpret the schematic layouts. Another method is to lay it out in the garage, and take a picture of it all, and including close-ups. With these photos one could instruct you to assemble unit. Regards ,,,fmauka
Posted on Sep 22, 2007
  • 8 Answers
SOURCE: kenmore side by side model 596.55662500
have you tried pouring bleach water through the drains in the fridge?
Posted on Nov 08, 2007
  • 146 Answers
SOURCE: Kenmore Side-by-side Ice Maker
The only cleaning that can be done is at the inlet valve. If it is anything else you will need to replace it.
Posted on Dec 18, 2007
SOURCE: Kenmore side by side refridge is making clicking sounds
Yes.. it will fix it..
Posted on Jun 21, 2008
Bought a new power supply since the previous power supply looked burned and short circuited. Installed the new power supply and sparks flew inside the Tv right when I plugged it in.
If you look around at where the sparks came from or for evidence of burnt parts inside the TV - not in the power supply - then you will find the fault that probably caused you bad looking power supply in the first place!
Oct 20, 2015 | Samsung UN37EH5000FXZA 37in Led 1080p 60hz...
The polyethylene tubing fell/broke off the air button under my jacuzz. It's a clear tube with a black connector inside. Can I glue it, do I need to to buy a new connector, or do I need a new air button?...
i would tr to glue it, clean all parts with alcohol and sand with sand paper, making sure parts are dry apply epoxy, and let fully cure, carefully reassemble..vote if'n I was of help.. jay the pool pump motor repair guy in longwood florida
Aug 04, 2013 | Jacuzzi Pool & Spa
I have an old kenmore washer, on which I cannot find the model number. It needs a new drive belt. The only information that I have is that it is marked as a Kenmore Heavy Duty 80, and inside the door is...
Go to a local Sears or Whirlpool store and tell them you have an old "belt drive" Kenmore washer that needs a new belt. All of these were built by Whirlpool Corporation and I believe used a common belt.
Good luck.
Mar 25, 2011 | Washing Machines
One of the grinder broke inside the unit, is this a replaceable part?
If disposal has loose parts inside, you have to replace the disposal.
If disposal still work and doesn't vibrate and loosen pipes under sink, then it's ok.
The don't sell replacement parts for disposals.
I wrote tips for replacing disposals:
When I worked apartment maintenance, we replaced disposal with same brand disposal.
That way we didn't have to change out sink basket or move pipes around under the sink.
How to: Disconnect 2 nuts on p-trap and trap falls loose.
Rotate steel connector disk that holds disposal to sink basket, and disposal comes off.
Before installing new disposal.
Attach electric wire to new disposal.
Attach dishwasher tube to new disposal. Knock out plug inside dishwasher opening.
Push new disposal up into place, and attach to old sink basket.
Use new connector washer.
Attachment ring catches at three points, all three have to connect.
Re-assemble tubular pipe.
If this is your home, you want new sink basket that comes with new disposal because it looks shiny and new.
Buy a tub of plumbers putty also.
Remove old sink basket and clean sink opening.
Put finger-size roll of plumbers putty around sink opening, and then push new strainer basket into plumbers putty.
Tighten basket from below, wipe away excess putty around sink opening.
Install new disposal as described above.
Tips for tubular pipes:
When taking apart tubular pipes, start at p-trap and take apart as few pieces as needed to do job.
On image above, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Any tubular drain pipe that gets moved while working under sink needs to be disassembled, cleaned and re-assembled.
Metal pipes have rubber washer >> always use new rubber washers.
Plastic pipes have plastic washers > plastic washers can be cleaned and re-used.
Plastic washers have flat side that goes toward nut, tapered side away from nut.
When reassembling tubular pipe, we use rectorseal on washers and joints.
Slap a good amount on washer just before pushing washer in place and attaching nut.
Rectorseal will ensure tubular drain pipes won't leak.
Jan 01, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Kenmore refrigerator model 106 will not cool fridge or freezer
is your refridge leveled if not level it and stable. Try turn it off for a couples of hours and then put it back. does the refridge move a lot when u open it fix this refridge doesn't has to be moving when opening when on and moving this agitates the freon creates more pressure so it has a pressure switch and turns off the compressor to protect it from over or under pressure
Jul 24, 2009 | Kenmore Refrigerators
Freezer is not cooling properly
Look inside the fresh food section behind and inside the control panel for a defrost timer and circuit board. Let me know when and what you find. Please unplug first, Thanks, Sea Breeze
E. Cold Control & Defrost Timer/Automatic Defrost
Control
These parts can produce a snapping or clicking sound
when turning the refrigerator on and off. The timer also
produces sounds similar to an electric clock.
Mar 27, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Remove the sheet metal panel from Whirlpool refridge
the rear panel is not removable. you need to clean the drain from inside the freezer compartment.
  • 1 remove food from freezer
  • 2 remove shelving and icemaker if equipped
  • 3 remover rear access cover in freezer usually 2 or 3 screw
  • 4 clean ice out from underneath the coil you will uncover the drain hole
  • 5 force hot water thru drain hole i use a turkey baster or large syringe
  • 6 reassemble in reverse order.
if you have any further questions please ask here and I'll be glad to assist any way I can. thanks Peyton
Mar 05, 2009 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Need to remove the big piece of sheet metal on whirpool refridg
Sep 21, 2007 | Kenmore 53642 / 53644 Side by Side...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
94 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
