Question about Kingston Combo 4GB DTI USB and 4GB (KWB164G3CQ) Media
I cant format or save files to my 4gb kingston flashdrive due to a message appears that its write protected. disable write protected in volume (my usb) in device\harddisk1\dr1.... this is the message that always appears. and if i try to delete files from it it say taht cant read from the specified drive or syntax error.
    Sergeant:
  • 343 Answers
Https://www.partition-tool.com/resource/manage-partition/format-a-write-protected-usb-flash-drive.html
Posted on Dec 03, 2017
SOURCE: HOW TO FORMAT A WRITE PROTECT USB DRIVE
repair_v2.9.1.1.zip
good program. kdt100-4gb now is ok
Posted on Feb 04, 2009
  • 7 Answers
try this tool HP USB Disk Storage Format Tool!!
Posted on Feb 25, 2009
  • 8 Answers
SOURCE: Not able to format 32gb kingston usb device givin
this problem may be due to a strong virus
just go through Dos promt
by writing cmd in run place at start menu
and then cd..
till u not get c:\ prompt
then write pendrive location like g: and press enter button
then u get g:\ then write format and press enter
hope by this process u will format ur pendrive
Posted on Mar 02, 2009
rustysheriff
  • 344 Answers
SOURCE: Remove the write protection on 2GB USB Kingston Data Traveler 100
Found this on Kingston site, doesn't help much but may point you in the right direction.
Unfortunately this unit does not have any security or write protection feature. If you receive a write protection message with this drive, check for the following:
  1. Verify that you are allowed to write to removable storage devices. There may be a security setting in the OS that disables write access to removable storage devices.
  2. Make sure you have not enabled write protection on the drive by using a third party software.
  3. If none of the above apply, the drive may be defective.
Posted on Jun 02, 2009
  • 72 Answers
SOURCE: Hi ,i having 1GB of flash drive of Transcend
I sense that your usb memory is equipped with a physical write protect switch that you may have overlooked. Locate it, switch to the "non-writeprotected" (unlocked) mode and everything should work normally. Good luck!
Posted on Jun 03, 2009
How do i format the kingston datatraveler 310 256 gb to ntfs file system
Hello insert the drive in the usb port.
When you see the drive in the control panel, right click on it and choose format.
Select NTFS in the selection box, and mark quick format and click start.
This could take a while.
You just have to save ALL the previous saved files, before you format, because the files will be lost, when the the drive is formatet.
Good luck
Mar 04, 2013 | Kingston DataTraveler 310 DT310/256GB...
I HAVE A FLASH Transcend (Jet Flash V15) 4GB I CAN NOT USE IT WHEN TRY TO COPY A FILE TO IT A MESSAGE APPEAR THAT THE DESK WRITE PROTECTED AND TRY TO REMOVE THE WRITE PROTECTION I TRY FORMAT BUT NOT WORK...
1.Close all files
2.Select Transcend Pen drive-Right Click-Format-ok.
3.After formatting you can copy all files upto 4GB.
Hopethis helps. If it does, please accept and rate the solution! Contact me withany more questions you may have. Thanks for using FixYa!
May 25, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
It automatically have a a write protection and i cant save any files nor format my usb flash drive 4GB
Contact the manufacturer directly; you can find their homepage with Google. Tech support will tell you how to solve this problem for your USB key.
Some common USB vendors are:
http://www.patriotmemory.com
http://www.kingston.com
http://www.sandisk.com
ONLY the vendor can help you with this, so contact tech support right away. If your drive is actually defective, they can issue an RMA number so you can return it for a new one.
Apr 30, 2011 | Computers & Internet
Please guide me how i want to reformat my kingston 4gb data traveller USB because once i tried to format it isung window 7 its appear that write protected.please help me ..TQ
is there any data on this usb 4gb drive if so you might try opening and deleting the files separately
insert your pen drive
click start click on my computer you should see your pen drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
or you could try some of these
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start
if this does not fix the problem you might try
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver or
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Jan 23, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I can not copy enything onto the 8gb flashdrive and if copied it cant be deleted again
Do you have a write protect switch on the pen? If so switch it to the open position.
Sep 10, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Can't formated 4 gb sandisk usb drives
dear,
Follow these instruction and the work will be done..
Click start
Click Run
Type "CMD"
Hit Enter - A black screen should now appear (this function can be achieved by selecting Start---->Programes---->Accessories---->Command Prompt)
Type "diskpart"
Wait untill you get "DISKPART>" then type in "select volume (blank)" fill in the blank with the letter of the drive you are trying to remove write protection from
Now type "attributes volume clear readonly"
Remember select correct letter otherwise u will loose data of other drive..
e.g; if your Flash USB drive is F then type F there..
goodluck..
hope it will fix the issue so dont forget to rate it.....
Aug 09, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Jun 02, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
USB Drive - Write Protected
Hi.
While formatting chose default allocation unit.
If this doesnt helps the tell me.
Regards
Faraz
Oct 16, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
repair_v2.9.1.1.zip
Apr 05, 2008 | Kingston Technologies 512MB DataTraveler I...
Kingston Combo 4GB DTI USB and 4GB (KWB164G3CQ) Media Logo
115 people viewed this question
Top Kingston Electronics - Others Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
jairo sanchez
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
