Big screen RCA rear projection tv will not come on
I have a RCA big screen rear projection tha t will not turn on turned it off one knight and the next day nothing it makes three sound like it will turn on but nothing I have red that it coukd be the flyback but not sure because you would still have sound right ? modlep60923BL
  • 4 more comments
  • Bear1157 Jul 03, 2008
    You said I have a short out what does this mean and were
    AS far as the paper that came with the tv it has one fuse and it is good.
    so the things you request to check are on the convergence board
    Any more assistance on whow to fix this problem
  • Bear1157 Jul 09, 2008
    When turning on tv clicking noise comes from fly back if it is the flyback any sujestions on were to get part I have tryed part number PN15128 the only one I can find is PN15128-16 is this the same part.
    when turning on tv clicking noise comes from fly back if it is the flyback any sudjestions on were to get part i have tryed part number PN15128 the onky one i can find Pn15128-16 is the same part
    Genius:
  • 1,226 Answers
try to re soldered all the connections inside. there some loss connections. during the examining try to look in the some resistors that causing the noise. examine also the regulator in the vertical and horizontal circuit board.
melnavz
Posted on Jul 10, 2008
  • 2,071 Answers
That is the oscillation sound comes from the relay,cannot continue because of protection mode,by the system.The problem is not in the convergence ,because you cannot see picture in convergence problem you ca see picture,but blotted colors,.. Your tv parts is ok.only the solder joint is crack or cold thats why function abnormally,goes off and goes on, due to the voltage trap, when voltage is there the solder is hot and connect the parts joint, when voltage extremely hot, due to prolong use it will disconnect the solder joint parts thats why you cannot see picture..its need to reheat the solder joint of all parts affected....power supply section ,,horizontal section,vertical section ..and to microprocessor ic section including jungle ic..
find a tv technician to do the works .in order to avoid high voltage shock this not cost too much because only reheating works....
Posted on Jul 03, 2008
  • 2 more comments
  • LORETO LACARON
    LORETO LACARON Jul 09, 2008
    You power on your RCA rear projection TV. It takes extra long to turn on. Lots of
    clicking and a few power cycles? Your TV is trying a few times to get that
    pesky lamp going. Finally, the process ends with the dreaded three blinking
    lights. Your lamp is probably burned out. You’ve got a replacement lamp, right?
    First, sometimes you can stretch a little more life out of a tempermental,
    but not completely dead lamp. I’ve found that sometimes if I remove the lamp
    and put it back in, it’ll work. I’ve also found that colder temperatures can
    cause a failure, even temporarily. So don’t give up on it right away,
    especially if you don’t have a replacement. Wait a while (especially if that
    allows the room to warm up some) and try again. Or, pull the lamp out and put
    it back in.
  • LORETO LACARON
    LORETO LACARON Jul 10, 2008
  • LORETO LACARON
    If it's a PTK 195 check the horizontal output transistor and if its bad, replace it and the flyback.Known issue with these RCA sets.
    Click below for replacement flyback for P60923BL.
    239111
  • LORETO LACARON
    239111 Flyback Transformer
  • 4,234 Answers
The clicking you are hearing is the main power relay that is truning on then being told to shutdown. This powerup attempt will occur three times before the electronics give up and leave the set in the "protect" mode. There can be a number of reasons for the set to behave this way. It can be anything from a bad connection inside that has changed the circuit characteristics enough to cause the failure to a defective part. Many sets will provide a code that helps to isolate the problem circuit. Does the power or standby light blink? If so is it a repeated count? Please post that number here.
Are you planning on repairing this yourself? If you are unsure, you should get a detailed repair estimate and report the results here. We can then help to decide whether or not the repair is worth it. Or we can walk you through the troubleshooting procedure and locate the exact problem.
Let me know what you choose.
Dan
  • ABRsvcs Jul 09, 2008
    The RCA part number is 239111 and costs $68.99 from tritronicsinc.com
    Hope this helps.
    Dan
    FIrst of all, this is a CRT based projection set. There is no lamp!!
    If you can solder, also check for poor solder connections on the main board around the flyback. Resolder any that appear to be grainy or have rings. That may be the only problem.
    Keep us posted.
    Dan
  • 2,334 Answers
I would suggest to start checking the B+ at IC U14101 located in the power supply.
If the B+ is present at the output and getting to the flyback transformer, you could have a defective flyback transformer or the voltage tripler could also be defective. If you have audio, the tripler could be the defective part.
NOTE: Please Be very careful when working around high voltage areas.
Let me know if you need further assistance.
    Sergeant:
    Champion:
  • 248 Answers
I could be caused by overuse,when overused it creates heat and it might have burnt small parts inside. take it to your local RCA repair shop and have it checked...
    Brigadier General:
  • 3,614 Answers
Could be the flyback, or could be some resistor, capacitor are faulty, do check the part on the convergence module and check for any one of this mentioned..
    Sergeant:
    Champion:
  • 417 Answers
THERE IS A SHORT OUT ITS EASY TO FIX
RCA projection big screen tv will not turn on lite blinks, power to tv is fine.
Check the power supply for electrolytic capacitors with the tops swollen. If you find these (should be either 2 or 4) replace them.
Oct 21, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I need a new screen protector for my older RCA big screen TV
I have a screen protector from a 1998 RCA older model big box style tv
Mar 15, 2010 | RCA P56930BL 56" Rear Projection...
52 inch rca big screen tv will not come on
ck capacitor cp150 if it is bad replace 2 other caps in same circuit 2200uf 16v -220uf35v cp111 cp114?
Dec 09, 2008 | RCA D52W19 52" Rear Projection Television
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Won't turn on
tv chassis ctc 195 , hvt transformer, digital conv, power supply,
Dec 04, 2007 | RCA P46921 46" Rear Projection Television
Dir TV projection Techcions, I own RCA Model:P52937 Chassis No.PTK195M26B. After a big flood here in Chicago, my basement got flooded and my projection TV was in water up to 1 foot. Befor I turned it on, I dreid it out perfectly, then, I turned it on, and a couple components from the power supply got burned up to the point where I am not able to read the part numbers that are on it. I was wondering if you have this kind of chassis and model service manual for this projection TV, or conponet part number i location 101 on mother boatd power supply. Thank you in advance, Darius If you prefeer, you may call my cell phone: 773-875-3926
Aug 02, 2007 | RCA P52937 52" Rear Projection Television
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
