Question about RCA Audio Players & Recorders
Set the clock on my RP4801A clock/radio
That pretty much covers it.
Following are the instructions for the RP5610 which looks very similar to the 4801A (that I also have). The only difference in the instructions is that the 4801A doesn't have a clock icon, just press the SET button until the center colon dots are flashing, Press the rewind or fast forward arrows on the circle next to it to set the time. Set the alarms by pressing the set button until bell 1 or 2 is displayed. Nap is also set with the set button - not sure how to stop it yet.
To set the clock:
  1. Press the SET button until the clock icon is displayed (circle with hands at 10 and 2)
  2. Press |<< REV or >>| FWD to set the time.
  3. AM or PM icon will show besides the time.
Posted on Aug 16, 2008
HOW DO i SET MY CLOCK AND ALARM ON MODEL RP4801A
PDF]FM/AM Clock Radio - Sony
https://docs.sony.com/release/ICFC218_US.pdf Sony CorporationVarious types of alarms - radio and buzzer. Automatic time set - When you plug theclock in for the first time, the current time will be shown in the display.
[PDF]Jumbo Display AM/FM Clock Radio - TIMEX Audio
Jan 14, 2016 | Audio Players & Recorders
Set the time
I have the same clock radio and I found out that you have to hold down the button and run through the times. The hour will change with the minutes. It goes pretty fast once you hold down the button, so I stop when I get close (like within 20 minutes of where I need it to be) and then click it one minute at a time until it's at the right time.
Sep 04, 2012 | GE 7-4837 Clock Radio
Set tme 4837 clock radio
Jun 09, 2012 | GE 7-4837 Clock Radio
I got the clock from my daughter and have no manual. I keep setting the time, and it keeps changing to 2 hours earlier. I think I've pretty much figured out everything else, though this is NOT intuitive.
Hi, your clock radio is an atomic clock radio... no wait you don't need your lead underwear! it receives a signal from the atomic clock and sets the time to match it, after you set the time zone and put it on auto dst you will never have to set the time again!
ENVIRONMENTAL RECEPTION EFFECTS:
The Atomic Clock obtains the accurate time with wireless technology. Same as all wireless devices, the receiving ability may be affected by, but not limited to, the following circumstances:
  • Long transmitting distance.
  • Nearby mountains and valleys.
  • Among tall buildings.
  • Near railway, high voltage cable, etc.
  • Near freeway, airport, etc.
  • Near construction site.
  • Inside concrete buildings.
  • Near electrical appliances.
  • Near computers and televisions.
  • Bad weather locally or electrical storms between you and Colorado.
  • Inside moving vehicles.
  • Nearby metallic structures.
LOCATION PRECAUTIONS:
This clock receives a radio wave much like a TV or radio. Be sure to locate it near a window or some other location where reception is good. Avoid the following locations, which can interfere with proper reception.
Synchronization signal reception can be received in Continental USA only. In other areas, you can still use this clock by making time settings manually.
QUICKSTART
  1. Place your clock in a location with optimal signal marks on the LCD.
  2. It is recommended to put the clock near a window. Please move the clock to another location if difficulty in signal reception or unstable signal marks is encountered.
Installation
Simply plug the SkyScan clock radio into any household outlet.
Battery Back-up Operation
This clock radio is equipped with alarm time memory that can be powered with a 9-volt battery (not included).When normal household power is interrupted, or the AC cord is unplugged, the battery will power the clock to keep track of the time and set alarm. When the backup battery activates, the LCD backlight is off, however, the functions of alarm and radio still operate.
To Install the Battery
  1. Remove the battery cover at the bottom of the case.
  2. Connect a 9-volt battery to the connector plug.
  3. Insert the battery in the compartment and replace the cover.
Note: An Alkaline battery is recommended. Carbon Zinc and rechargeable (nickel cadmium) batteries not recommended.
Set the Time Zone Press the SET button in sequence until you see PST(Pacific Standard Time)blinking below the time digits on the LCD. Press UP or DOWN button to select your time zone.
Daylight Savings Time
Always slide the DST switch to ON position unless the clock is used in an area without Daylight Savings Time.
**Special attention to usage in Arizona and Indiana. **Arizona and parts of Indiana do not recognize Daylight Savings Time (DST). Turn the DST off if the clock is used in these areas.
Cheers!
Feb 16, 2010 | SkyScan 34202 Clock Radio
When I shut the radio off the clock and radio memory goes to How do I set the clock and stations so that when I tur it on I have the clock and stations.
Have you inserted 2 x AA batteries in the back where you charge the Dewalt batteries? there is a cover with a black phillips screw, this is where the AA batteries go for the memory clock & radio presets.
Nov 28, 2009 | Dewalt DC011 AM/FM Radio
Good Morning. I was given this alarm clock which is driving me crazy cause i cant figure out what to do. I tried researching the internet for a manual, but failed. It is a RCA CD Clock dual wake Radio....
To set the clock:
Dec 24, 2008 | RCA Radio Alarm Clock
Setting the alarm
I don't have mine with me, but I'm pretty sure you press cancel and then the number of the alarm you want to turn off. The bell or music symbol telling you the alarm is set should go away.
Jul 13, 2008 | RCA Radio Alarm Clock
TEAC SRL100
I need to set the clock on the srl 100
Jul 11, 2008 | Teac SRL50 Clock Radio
CD Music System Clock Radio SR-L100
Open CD Cover. In the left rear is the time set button. Depress it for at least 3 seconds and you will be in the time set mode. Use the "Skip" rotary knob to adjust the time.
Dec 25, 2007 | Audio Players & Recorders
3,533 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
