Question about Proscan 32LA30Q Television
PROSCAN 32LA25Q I cannot shut off the closed caption on my new TV, can you tell me how?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 265 Answers
Hey kjr_67,
According to information provided by the manufacturer, you may toggle closed captioning on and off through the "Function" menu. You should be able to reach this menu by doing the following:
1) Press the "Menu" button on your remote control to enter the "Picture" Menu.
2) Press the "Up" or "Down" arrow key until the "Function" menu appears and is highlighted.
3) Press either the "Left" or "Right" arrow key to enter the "Function" menu.
4) Press the "Up" or "Down" button to select "CCD", and the "Left" or "Right" arrow key to change this setting from "On" to "Off".
5) Press the "Menu" button again to exit and save any changes.
If you're still not quite sure how to proceed, I would strongly suggest referring to your owner's manual documentation for further information. You should also be able to find step-by-step instructions with visual aides by visiting the following link to the manufacturer's website:
http://www.oncorpus.com/down/ENG/32LA25Q%20English%20UM.pdf
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jul 02, 2008
Proscan 32la25Q Backlight not comming on
You either have a faulty backlight or one or more of the inverter transformers is bad,
a close inspection of the picture when on will show a bad tube as it will be lighter or darker than the rest,transformers may be hot to the touch
Len..
Oct 13, 2014 | Proscan 32LA25Q 32 in. LCD TV
Don't know how to activate closed caption, and cannot find instructions
What is the TV source? For some sources (set top box), you may need to turn on the captions using the menus of the box.
Assuming you are using a source that gives captions that the TV can interpret, if you have the Proscan 26LA30Q remote, press the CC button to toggle through the caption options. Another route is to press Menu (either on the remote or the buttons on the side of the TV) then select the Feature submenu with the left/right arrows. Press Enter (menu when you use the buttons on the TV) then navigate to the Digital Closed Captions option. Here you can set the captions to on and adjust the size, style and color of the captions when they appear on-screen.
If you are using a universal remote, try the CC button. If it doesn't work, try another code for the Proscan TV on the remote. There are some codes that may not control all of the functions of the TV with the remote.
Crutchfield has the manual for the TV on the product site: http://www.crutchfield.com/S-Kaec3gBqVtM/p_68326LA30Q/Proscan-26LA30Q.html . The direct link is http://a248.e.akamai.net/pix.crutchfield.com/Manuals/683/68326LA30Q.PDF .
I hope this helps
Aug 18, 2011 | Proscan 26LA30Q 26 in. LCD Television
Can't get Satalite remote model IRC 451 to work with my tv
theres nothing much i can tell you, i searched google through maybe 5 pages, everyones having the same problems. i'll keep looking for you though
May 01, 2009 | Proscan 32LA25Q 32 in. LCD TV
How to activate "closed captioning" for a Proscan Full HD 1080P
Comcast's remote has nothing to do with closed captioning. It's on your tv remote. First, the tv has to be capable of handling closed captioning, and your's is- and second, the program must have closed captioning provided- current programs do, some older shows do not support closed captioning. Recheck your remote, and if necessary- look at the setup instructions that came with the TV- they should also be posted online at the Proscan support site.
Mar 26, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Can't get closed caption
Press the menu button on the front panel of the tv or the remote control. Use the up and down arrows to find the features section.Press the right arrow to enter the sub-menu for the features section. Use the up and down arrows to find the closed caption section. Press the right arrow to enter the closed caption sub-menu.Used the up and down arrows and the enter button to go into each of the features, use the right and left arrows to adjust each control for you preferred viewing.Press enter again to select the feature in each of the controls.When you are satisfied with you selections press menu to exit the feature. This information can be found on the PROSCAN website in the customer section under manuals. Go to www.oncorpus.com.the information can be found on pages 21 and 24 of owners manual for your model television.I hope this information helps you with your problem.
Feb 08, 2009 | Proscan 32LA30Q Television
No signal from my dvd player
Can you tell me how to connect my dvd player to my 42 inch proscan hdtv ? There are no yellow,its blue and there are two rows of the same colors.
Feb 03, 2009 | Proscan 32LA25Q 32 in. LCD TV
Need TV Code
i believe because this is a commercial television. look at the power cord -- three prongs - right?
I had to get a universal remote and program the buttons manually from the original remote to get it to work.
Dec 21, 2008 | Proscan 32LA25Q 32 in. LCD TV
Closed captions
In all situations I've seen:
A) It's an option on your cable/satellite box.
B) It's a broadcast signal and it's in the TV menu.
Sep 02, 2008 | Proscan Televison & Video
Proscan 32LA30Q Television Logo
70 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
