Question about Xerox Phaser 8560MFP Laser Printer
Xerox 8560MFP won't print first page from one tray and rest from another
We have an 8560MFP at work. I have used Word from both a Vista and an XP PC to work on the problem. Here's the problem:
The 8560MFP in question has a total of 3 trays - the manual tray and 2 automatic paper-feed trays. The users want to print the first page from tray 2, which has letterhead, and the rest of the pages from tray 3, which contains blank paper.
That seems simple enough, but I cannot get it to work. If I choose to print only the first page on tray 2 and everything else on tray 3, applying it to the whole document, everything comes out on tray 2. If I do the reverse and tell it to print only the 1st page to tray 3 and everything else on tray 2, everything prints from tray 3. Obviously, it is seeing both tray 2 and tray 3.
The XP PC that I tried has Office 2003 on it. The Vista PC has Office 2007. Both produced the same results.
Does anyone have any suggestions? Thanks!
Ummm i have the same problem , any solution ?
Posted on Sep 24, 2008
    Problem Solver:
  • 8 Answers
Microsoft word overides the print driver for page choice. Choose from within word File | Page Setup | Paper.
Tray one on this printer is the manual feed tray. tray 2 is the first drawer.
Ensure the printer driver is set up for the additional trays
Posted on Jul 05, 2008
I can't get anything to print from tray 1, the manual feed. I'm trying to print envelopes and they keep printing on 8.5x11 paper from tray 2. If I put envelopes in tray 2 it won't print
Have you already tried this? After you click print and select your printer, click properites and select your paper from 8.5x11 to Envelope.
Jun 25, 2012 | Xerox Phaser 8560MFP Laser Printer
My printer xerox phaser 8560mfp is printing landscape 1/2 page instead of a full size portrait from a pdf file. How do I get that fixed? Thanks!
You need the new driver. Goto the Xerox website and download the latest driver and save it on your C: drive. Goto Devices and Printers and remove your existing Xerox 8560MFP. Reboot your computer and go back to this screen and click on "add a printer". When you get to the screen "Install the printer driver" you will see Xerox 8560MFP PS highlighted DO NOT CHOOSE THIS! (you will simply be installing the same driver from Windows 7 back). Instead, Click on "Have Disk... and navigate to where you saved the driver. Choose that one and finish the install.
May 20, 2011 | Xerox Phaser 8560MFP Laser Printer
Printing from wrong tray
I suffered from the same problem for a long time. We got Xerox Phaser 8550 and 8560 here. I choose on computer "tray 2" but the printer just print from tray 1 which is empty.
Today i figured it out! It's some configuration at the printer. So go to "Paper tray setp" -> "Tray 1 mode" and "Tray 2 mode" -> change to "static".
I figure it's like this. Before it was "dynamic", it probably means the printer decides it's better to use tray 1 even though you choose tray 2 - and this decision is stupid. Changing it to "static" fixes this.
Let me know whether this works for you too!
Feb 12, 2010 | Xerox Phaser 8560MFP Laser Printer
Printer picking wrong tray for print
From the start menue to printers and faxes go to your printer right click and select properties label the 4 drawers as to paper type and select continue, or auto continue to off.
-Carl, please let me know if this helps.
Jun 26, 2009 | Xerox Phaser 8560MFP Laser Printer
I HAVE A XEROX 8560 THAT I AM GETTING BLURRED PRINT WITH, I DID THE CLEANING CYCLE AND THAT WORKED FOR A DAY AND A HALF. NOW THE FIRST TWO PAGES LOOK GOOD AND ALL THE REST ARE BLURRED?
Oil from the drum has ran off over the drum encoder position sensor.
Take the right cover off and find the fan. Remove it and loosen the clear plastic sensor cover underneatch. Clean the sensor and generally with Isopropyl and Q-tip.
Clean the nearby wires and anything that might be transporting more oil back to your sensor
Apr 16, 2009 | Xerox Phaser 8560MFP Laser Printer
Xerox 8560 outputs Cleaning Pages several times a week. The unit is never turned off and only goes into "sleep" mode. Last time it woke up at 1:00 AM and went through the noisy cycle and output the...
There is nothing you can do about the cleaning page. And if its only using 20% of your ink, you're luck normally its 25% of the ink. This is simply how the machine works. Nothing can be done. The Xerox employee was simply trying to give you something to try, but it won't change anything!
Mar 27, 2009 | Xerox Phaser 8560MFP Laser Printer
I have xerox phaser 8560MFP error cod 07,010.43:14059
there is a stainless steel print head block on the lower back portion of the frame that gets contaminated with spill over ink from the catch tray. That causes the print head not to move properly.
The wiper blade may also be tacked to the print head.
That code means the print head is not moving into the print position properly.
That stainless steel block is about 1 inch square.
Mar 11, 2009 | Xerox Phaser 8560MFP Laser Printer
Printing Black & White
sure..but you need to set that in the settings of the documents printing under default(use greyscale).
Try this link for more Printer Resources
Aug 19, 2008 | Xerox Phaser 8560MFP Laser Printer
WIndow vista have driver?
I have had the same issue, Try this on an xp machine with driver loaded for dc1250 share this printer and then on the vista machine brouse the network and double click the shared printer on the xp machine and the driver should load and vista will print using the xp machine as a print server.
Les
Jul 23, 2008 | Xerox DocuColor 12 Printer
Can't Feed Envelopes
That machine should still be under warranty. Call xerox and have them check it out.
I looked and that machine has a one year warranty, that includes service.
Nov 09, 2007 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8560MFP Laser Printer Logo
952 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
